These are the two most-discussed cordless electric air dusters in enthusiast communities right now, and they represent genuinely different philosophies about the same problem.[2][3] The Fanttik B10 Pro Max is palm-sized, built for portability. The WOLFBOX MF200 is built around a swappable battery system — when one battery runs down, you swap in a fresh one instead of waiting about 3.5 hours for the device to recharge. Here's what that difference means in practice.
Specs Side by Side
| Specification | WOLFBOX MF200 | Fanttik B10 Pro Max |
| Air speed | 210 MPH (US product page)[1] | ~145 MPH (65 m/s)[5] |
| Motor | 110,000 RPM | 130,000 RPM brushless[5] |
| Battery | 2×3,000 mAh swappable packs (6,000 mAh total)[1] | 2×4,000 mAh built-in (8,000 mAh / 28.8 Wh total), non-removable[5] |
| Recharge method | Swap battery in ~5 sec; charge spare separately | Recharge the device itself (~3.5 hrs) |
| Speed settings | 3 gears | 6 gears[5] |
| Nozzle attachments | 4 nozzles included | Nozzle set included |
| Size | Compact handheld | Palm-sized (5.6 × 3 × 1.6 in)[5] |
| Price (mid-2026) | ~$126.4 | ~$60–80 |
| Battery swappable | Yes — field-swappable | No |
Sources: WOLFBOX MF200 US product page [1]; WOLFBOX MF200 and Fanttik B10 Pro Max Comparison Guide [5].
The Hot-Swap Difference: When It Actually Matters
The MF200 ships with two 3,000 mAh battery packs, each providing 10–100 minutes of run time depending on speed setting. When the first pack drains, you pull it out and click in the second in under five seconds. The depleted pack charges separately via USB-C while you keep working.[6] For a professional cleaning a studio, a mechanic blowing down an engine bay, or someone doing a full PC teardown plus keyboard service in one session,[9] the no-wait workflow is a genuine improvement over having to stop and recharge a device.
For someone who cleans their keyboard once a month, the 8,000 mAh (2×4,000 mAh) built-in battery in the B10 Pro Max is probably sufficient — you plug it in overnight and it's ready again. The hot-swap feature is an advantage for continuous-use scenarios, not casual periodic use.
Air Performance: Higher Speed, With Different Controls
The MF200's 210 MPH figure means faster air at the nozzle tip — useful for dislodging embedded dust in keyboard switches, fan blades, or vent grilles. The Fanttik B10 Pro Max's six-gear system (versus MF200's three gears) offers finer control at lower settings, which is useful when cleaning delicate items where you need to manage distance carefully.
Neither is a precision instrument like a handheld bulb blower. Both are appropriate for general electronics cleaning, desk surfaces, and car interiors. For camera sensor cleaning or direct optics work, neither replaces a dedicated sensor blower.[4][7]
Size and Portability
The Fanttik B10 Pro Max fits in a shirt pocket at 5.6 × 3 × 1.6 inches. The MF200 is larger, largely because it houses swappable battery cartridges. If you're packing a travel kit or work from multiple locations, the Fanttik's portability is a real advantage. WOLFBOX's differentiation is sustained performance without downtime, not compactness.
Which One Fits Your Use Case
| Use Case | Better Fit | Reason |
| Full PC teardown + keyboard + peripherals in one session | MF200 | Hot-swap battery eliminates mid-session wait time |
| Occasional cleaning (once a week or less) | Either — Fanttik at lower price | Built-in battery sufficient for periodic use; charges overnight |
| Travel or portable kit | Fanttik B10 Pro Max | Smaller, lighter, no external battery pack to carry |
| Professional or recurring workflow where downtime matters | MF200 | Continuous operation with two charged packs ready |
| Camera body, exterior lens barrel, or viewfinder cleaning | Either | Use a bulb blower for actual sensor/optics contact — dusters are for surfaces and crevices |
Q: What is the WOLFBOX MF200 battery capacity?
A: The MF200 includes two 3,000 mAh swappable battery packs (total 6,000 mAh). Each provides 10–100 minutes of run time depending on speed setting.
Q: Does the Fanttik B10 Pro Max have a removable battery?
A: No. The B10 Pro Max has a built-in 2×4,000 mAh (8,000 mAh / 28.8 Wh total) battery that charges via USB-C. Full recharge takes approximately 3.5 hours.
Q: What air speed does the WOLFBOX MF200 reach?
A: 210 MPH, per the US official product page at wolfbox.com.
Q: How long does the WOLFBOX MF200 run on one battery?
A: 10–100 minutes per battery pack, depending on the speed setting in use. The second pack can be swapped in approximately 5 seconds.
Q: Is the Fanttik B10 Pro Max better for travel?
A: For compact portability, yes — it measures 5.6 × 3 × 1.6 inches. The MF200 is larger due to its swappable battery system.
Q: Can I use an electric air duster to clean camera lenses?
A: Not recommended for direct lens or sensor use. A dedicated sensor blower or lens brush is the appropriate tool. Electric dusters are suitable for camera bodies, exterior crevices, and lens cap surfaces.
Q: Which is more cost-effective: MF200 or Fanttik B10 Pro Max?
A: Fanttik B10 Pro Max is less expensive (~$60–80 vs ~$134.99 for MF200). The MF200 costs more primarily because it includes two battery packs and the hot-swap system.[8]
[1] WOLFBOX MF200 Official Product Page (US) — 3000mAh×2, 210MPH confirmed: https://wolfbox.com/products/compressed-air-duster-mf200
[2] WOLFBOX Best Air Dusters Collection: https://wolfbox.com/collections/best-air-duster
[3] WOLFBOX About Us: https://wolfbox.com/pages/about-us
[4] WOLFBOX — Best Compressed Air Duster in 2026: https://wolfbox.com/blogs/news/best-compressed-air-duster-in-2026
[5] WOLFBOX — MF200 and Fanttik B10 Pro Max Comparison Guide: https://wolfbox.com/blogs/air-duster/wolfbox-mf200-vs-fanttik-b10-pro-max-which-air-duster-actually-fits-your-workflow
[6] Battery University — Can Batteries Be Restored?: https://batteryuniversity.com/article/bu-803-can-batteries-be-restored
[8] WOLFBOX Warranty Policy: https://wolfbox.com/pages/warranty-policy
[7] WOLFBOX — Air Duster Review and Care Guide: https://wolfbox.com/blogs/air-duster/wolfbox-air-duster-review
[9] Tom Guide — How to Clean a Desktop PC: https://www.tomsguide.com/how-to/how-to-clean-a-pc
