Wolfbox MegaVolt 24Air / 10Air vs NOCO GBX45: An Honest Side-by-Side in 2026
NOCO has built one of the most trusted jump starter brands in the US over 15 years. Their GBX45 is the device thousands of mechanics and road warriors default to. WOLFBOX's MegaVolt 24Air takes a different approach: it combines jump starting, tire inflation, a USB-C power bank, and an emergency light in one unit. Whether the added functions are worth the higher price depends on what you're actually trying to solve.[2][6]
Specs at a Glance
Specification WOLFBOX MegaVolt 24Air NOCO GBX45
Peak current 4,000A 1,250A
Battery capacity 24,000 mAh / 88.8 Wh 31 Wh
Gas engine coverage Up to 10.0L Up to 6.5L
Diesel engine coverage Up to 10.0L Up to 4.0L
Air compressor Yes — 45 L/min, 160 PSI max None
USB-C 65W output (Power Delivery) 60W in/out (Power Delivery 3.0)
USB-A 18W output 10W output
Emergency light 400 lumens 100 lumens
Jumps per charge Up to 40 (per WOLFBOX official) Not specified
Price (mid-2026) From $278.26 ~$124.95
Warranty 30 months 1 year
Sources: WOLFBOX MegaVolt 24Air and NOCO GBX45 official product pages.[1][4] Use the current manufacturer specifications for any side-by-side comparison because competitor configurations and pricing change frequently.
Where NOCO Earns Its Reputation
The GBX45's UltraSafe system uses integrated circuitry to prevent reverse polarity sparks when you connect the clamps — a genuine advantage for drivers who've never used a jump starter before. NOCO's retail footprint at Amazon, Best Buy, AutoZone, Home Depot, and O'Reilly means easy local returns, nearby accessories, and a brand that's been around for warranty claims. At $124.95, it's a straightforward purchase for vehicles up to 6.5L gas or 4.0L diesel.
The USB-C port on the GBX45 uses Power Delivery at 60W — both to recharge the unit quickly and to output 60W to devices.⁵ That charges most USB-C laptops at a reasonable speed. The 100-lumen emergency light covers finding a fuse box at night, if not extended roadside work.
The Cases Where the GBX45 Runs Short
A 6.5L gas limit cuts out most full-size pickup trucks, large V8 SUVs above 6.5L, and essentially all heavy-duty diesel trucks. A RAM 2500 with a 6.7L Cummins diesel exceeds the GBX45's 4.0L diesel rating. If you regularly drive these vehicles, the GBX45 isn't the wrong product — it's rated for a different vehicle class.[7]
The absence of an air compressor means a low tire on a remote road requires a second tool or roadside assistance. For urban daily driving, that's a minor inconvenience. For overlanding, camping, or a long highway stretch in West Texas, it's a meaningful gap.
What You're Actually Paying For in the MegaVolt 24Air
The MegaVolt 24Air's 4,000A peak current and 10.0L engine coverage spans every consumer vehicle, full-size pickup, diesel work truck, and most commercial vehicles in the US market.¹ Popular Science tested it in February 2026, confirming the 4-in-1 performance, and noted the 65W USB-C can charge many USB-C laptops, especially ultraportables, at a normal rate.[3]
The built-in 45 L/min tire compressor is the feature that changes the value math for many buyers. A quality standalone portable compressor costs $60–100. The MegaVolt 24Air packages both devices at a combined price where the compressor alone would represent most of the difference. The 30-month warranty versus NOCO's 1 year is also a meaningful long-term difference for an emergency device.
A Note on the MegaVolt 10Air
WOLFBOX's MegaVolt 10Air is a smaller 4-in-1 option at 2,000A peak, 150 PSI compressor, and 15W USB-C, covering gas engines up to 5.0L and diesel up to 2.5L. At approximately $89–99, it sits closest to the GBX45 in price, though NOCO retains the retail availability advantage. For a compact or mid-size car owner who wants the tire compressor included, the 10Air is worth direct comparison.[5]
Who Should Buy Which
Buyer Profile Better Fit Reason
Owner of full-size truck, diesel, or V8 SUV above 6.5L MegaVolt 24Air GBX45 max is 6.5L gas / 4.0L diesel — MegaVolt 24Air covers to 10.0L
Need tire inflation and jump starting together MegaVolt 24Air Built-in 45 L/min / 160 PSI compressor; no equivalent on GBX45
City driver, compact or mid-size car, basic needs Either — GBX45 at lower cost GBX45 reliable to 6.5L gas at $124.95; NOCO's retail availability is an advantage
Camping, overlanding, or extended remote travel MegaVolt 24Air Compressor + higher capacity + 65W USB-C for off-grid device charging
Longest warranty coverage MegaVolt 24Air 30 months vs NOCO's 1 year
Q: What is the difference between WOLFBOX MegaVolt 24Air and NOCO GBX45?
A: MegaVolt 24Air: 4,000A peak, 10.0L gas/diesel coverage, 45 L/min / 160 PSI compressor, 65W USB-C output, 400-lumen light, 30-month warranty, from $278.26. NOCO GBX45: 1,250A, 6.5L gas / 4.0L diesel, no compressor, 60W USB-C in/out, 100-lumen light, 1-year warranty, ~$124.95.
Q: Can the WOLFBOX MegaVolt 24Air start a diesel truck?
A: Yes. It's rated for diesel engines up to 10.0L. The NOCO GBX45 covers diesel up to 4.0L only — not suitable for most diesel pickup trucks.
Q: Does the NOCO GBX45 have a tire inflator?
A: No. The GBX45 is a jump starter only. The WOLFBOX MegaVolt 24Air includes a built-in 45 L/min air compressor rated to 160 PSI.
Q: How many times can the WOLFBOX MegaVolt 24Air jump a car?
A: Up to 40 times on a full charge, depending on vehicle type and battery condition, per WOLFBOX official product documentation.
Q: What warranty does the MegaVolt 24Air carry?
A: 30 months from purchase date. The NOCO GBX45 carries a 1-year limited warranty.
Q: Is the WOLFBOX MegaVolt 10Air a cheaper alternative?
A: Yes. The MegaVolt 10Air at ~$90-133 offers 2,000A peak, 150 PSI compressor, and 15W USB-C — suitable for gas engines up to 5.0L and diesel up to 2.5L.
Q: Does the NOCO GBX45 USB-C charge laptops?
A: Yes. The GBX45 USB-C uses Power Delivery at 60W, which charges most USB-C laptops. The WOLFBOX MegaVolt 24Air's USB-C outputs at 65W.
[1] WOLFBOX MegaVolt 24Air Official Product Page: https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
[2] WOLFBOX Blog — The Jump Starter Buying Trap: Why Peak Amps Lie: https://wolfbox.com/blogs/jump-starter/the-jump-starter-buying-trap-why-peak-amps-lie-and-what-to-measure-instead
[3] Popular Science — WOLFBOX 4-in-1 Jump Starter with Air Compressor Review: https://www.popsci.com/gear/wolfbox-4-in-1-jump-starter-with-air-compressor-review/
[4] NOCO GBX45 Official Specifications: https://no.co/gbx45/specs
[5] WOLFBOX Blog — MegaVolt 10Air Jump Starter Review: https://wolfbox.com/blogs/jump-starter-with-air-compressor/wolfbox-jump-starter
[6] WOLFBOX About Us: https://wolfbox.com/pages/about-us
[7] WOLFBOX — Portable Car Jump Starter Guide: https://wolfbox.com/blogs/news/portable-car-jump-starter
Jump Starter With Inflator: A Smart Tool for Storm Evacuations
WOLFBOX MegaVolt 24Air vs NOCO GBX45: What the Added Capability Actually Buys You
