The Wolfbox MegaVolt 10Air is a 4-in-1 portable device combining a jump starter, air compressor, USB power bank, and LED flashlight in a single unit. At the time of this review, it leads the under-$100 jump starter category.[1] Popular Science tested it in-field and confirmed its 4-in-1 performance delivers on its promises.[2]
Wolfbox MegaVolt 10Air: Quick Specs
Specification
Detail
Peak jump start current
2,000A
Battery capacity
37 Wh
Engine compatibility
Up to 5.0L gasoline / 2.5L diesel
Air compressor max pressure
150 PSI
Inflation time (29 to 36 PSI)
~1 minute
USB-C output
15W
USB-A output
12W
LED flashlight
200 lumens
Operating temperature
-4°F to 140°F
IP rating
IP64
Jump starts per charge
Up to 30
Warranty
24 months
Jump Start Performance
The MegaVolt 10Air delivers 2,000A peak current, handling gasoline engines up to 5.0L and diesel engines up to 2.5L.[1] It delivers up to 30 jump starts per full charge.[1] The IP64 rating seals the internals against dust and water splash from any direction.[1]
It operates reliably from -4°F to 140°F, covering extreme winter and summer conditions.[1] Reverse-polarity protection alerts you with a beep and refuses to complete the circuit if clamps are attached incorrectly.[1]
Air Compressor: 150 PSI in 1 Minute
The integrated air compressor reaches 150 PSI maximum and inflates a standard car tire from 29 to 36 PSI in approximately 1 minute.[1] Preset inflation modes auto-stop at your target pressure, preventing over-inflation. Included adapters cover the most common valve types.
Popular Science noted in their review that the air compressor "works great and inflated a completely flat tire to 36 PSI" during real-world testing.[2]
Power Bank: 15W USB-C
In power bank mode, the MegaVolt 10Air outputs up to 15W via USB-C and 12W via USB-A.[1] The 37Wh battery capacity provides roughly 2–3 full smartphone charges.
LED Flashlight: 200 Lumens
The built-in LED delivers 200 lumens with normal, strobe, and SOS modes — bright enough for hood work at night or roadside emergencies.[1]
Wolfbox vs NOCO Jump Starter
NOCO GB40
Peak amps
2,000A
1,000A
Air compressor
Yes (150 PSI)
No
Battery capacity
37 Wh
~15 Wh
USB-C output
15W
5W
IP rating
IP64
IP65
Engine compatibility (gas)
Up to 5.0L
Up to 6.0L
Engine compatibility (diesel)
Up to 2.5L
Up to 3.0L
Warranty
24 months
1 year
LED flashlight
200 lumens
100 lumens
The NOCO GB40 carries a higher IP65 waterproof rating and slightly larger gasoline engine displacement coverage. The Wolfbox MegaVolt 10Air delivers double the peak amps, integrates an air compressor, provides more USB-C power, and carries a longer warranty.[1]
Wolfbox vs Tacklife Jump Starter
Typical Tacklife models in the $50–$80 range deliver 800A–1,200A peak with no integrated air compressor. The Wolfbox MegaVolt 10Air's 2,000A and 4-in-1 design represent a significant capability step-up at a competitive price.[1]
Who Should Buy It?
- Drivers who want one device for jump starting, tire inflation, power banking, and lighting
- Truck and SUV owners with engines up to 5.0L gasoline
- Budget-conscious buyers seeking maximum value under $100
- Cold-weather drivers who need reliable -4°F operation
- Road trippers who want a compact emergency kit
Q: What is the Wolfbox jump starter 2000A capable of starting?
A: The Wolfbox MegaVolt 10Air's 2,000A peak handles gasoline engines up to 5.0L and diesel engines up to 2.5L, with up to 30 jump starts per full charge.[1]
Q: Does the Wolfbox jump starter have a built-in air compressor?
A: Yes. The MegaVolt 10Air includes a 150 PSI air compressor that inflates a car tire from 29 to 36 PSI in approximately 1 minute, with preset inflation modes and auto-stop.[1]
Q: What is the warranty on the Wolfbox jump starter?
A: The Wolfbox MegaVolt 10Air comes with a 24-month manufacturer warranty.[3]
Q: Can I use the Wolfbox jump starter as a power bank?
A: Yes. It outputs up to 15W via USB-C and 12W via USB-A — roughly 2–3 full smartphone charges from its 37Wh battery.[1]
Q: What is the IP rating of the Wolfbox MegaVolt 10Air?
A: IP64 — fully sealed against dust and protected against water splashing from any direction.[1]
Q: Why is my Wolfbox jump starter not charging?
A: Verify the USB-C cable is fully seated and the charger delivers at least 10W. Try a different cable. If the issue persists after 30 minutes, contact Wolfbox 24/7 support — covered under the 24-month warranty.[3]
Q: Is a jump starter better than jumper cables?
A: For most drivers, yes. The Wolfbox MegaVolt 10Air works without a second vehicle, adds air compressor and USB power bank functions, and eliminates the need to find another car.[1][2]
[1] Wolfbox MegaVolt 10Air Official Product Page —https://wolfbox.com/products/wolfbox-2000a-jump-starter-with-air-compressor-wolfbox-megavolt-10air
[2] Popular Science — Wolfbox 4-in-1 Jump Starter with Air Compressor Review — https://www.popsci.com/gear/wolfbox-4-in-1-jump-starter-with-air-compressor-review/
[3] Wolfbox Warranty Policy — https://wolfbox.com/pages/warranty-policy
[4] YouTube — Wolfbox MegaVolt 10Air Full Video Review — https://www.youtube.com/watch?v=9KHUQcAHrWE
[5] TechGearLab — Wolfbox MegaVolt24 Review — https://www.techgearlab.com/reviews/tools/jump-starter/wolfbox-megavolt24
