Help & Support
WE'VE GOT YOUR BACK.
WOLFBOX LIMITED WARRANTY
Wolfbox stands behind every off-road accessory and component we build. This limited warranty is provided to the original purchaser to ensure peace of mind on every adventure.
We warrant that the products listed below will be free from defects in materials and workmanship under normal use for the specified periods. The warranty period begins on the date of original purchase. For full details on coverage and how to submit a claim, please refer to the terms and conditions below.
This warranty applies only to products purchased directly from Wolfbox or an authorized dealer in the United States. This warranty ends when the original purchaser sells or otherwise transfers the product (or the vehicle it is installed on) to another party. For complete details and exclusions, please refer to our full warranty policy.
5-Year Limited Warranty
Power Running Boards
WOLFBOX warrants the main structure, step boards, motors, and electronic components of its power running boards against defects in materials and workmanship for five (5) years. Damage caused by off-road hazards, improper installation, or misuse is not covered.
3-Year Warranty
Truck Steps
We stand behind the toughness of our truck steps. This policy covers defects in materials and workmanship for three (3) years from the date of original purchase, provided the product is installed in accordance with the official instructions. It does not cover damage caused by off-road impacts, severe rock crawling, neglect, or improper maintenance.
Powered Retractable Bed Cover
WOLFBOX warrants the main structure, cover panels, motor system, and electrical components of its retractable truck bed covers against defects in materials and workmanship for five (5) years. This warranty does not cover any damage, defects, or malfunctions resulting from misuse, abuse, accidents, improper installation, unauthorized modifications, improper maintenance or lack of maintenance, or on-road and off-road hazards.
5-Year Warranty
NomadRover/NomadPixel Series LED Pod Lights
Built to light up the darkest trails, our NomadRover series is backed by a five (5) year warranty. This warranty covers water ingress, complete failure to illuminate, and excessive lumen depreciation (light decay exceeding 70% of original brightness). Normal cosmetic wear on the outer lens is not covered.
3-Year Warranty
Side Mirrors
Our wide-view side mirrors are warranted to be free from defects in materials and workmanship for three (3) years from the date of original purchase. This coverage applies to the hardware and components included in the original kit. Accidental glass shattering, collision damage, or trail impacts are not covered under this policy.
2-Year Warranty
Air Compressor
WOLFBOX Air Compressors are backed by a limited warranty from the date of original purchase. The HyperFlow 60D comes with a two (2) year warranty, while the HyperFlow X is covered by a three (3) year warranty. This policy covers manufacturing defects in materials and workmanship under normal use. It does not cover damage caused by misuse, accidents, improper operation, unauthorized modifications, or improper maintenance.
2-Year Warranty
Light Mounts & Brackets
We stand behind the rock-solid stability of our WOLFBOX light brackets. This policy covers defects in materials and workmanship for two (2) years from the date of original purchase, provided the product is installed according to the official instructions. It does not cover damage caused by off-road impacts, severe rock crawling, neglect, or improper maintenance.
5-Year Warranty
ToughFold T1 Hard Tri-Fold Flip Up Tonneau Cover
WOLFBOX warrants its hard folding truck bed covers against defects in materials and workmanship for five (5) years from the original purchase date. This excludes normal wear of weather seals, and damage caused by misuse, accidents, improper installation, exceeding the rated load capacity, or road/off-road hazards.
MTB-R1 Modular Overland Truck Bed Rack
WOLFBOX warrants the main 304 stainless steel structure and MOLLE panels of our modular overland truck bed racks against defects in materials and workmanship for five (5) years from the date of original purchase. This policy applies provided the product is installed in accordance with the official instructions. It does not cover damage caused by overloading beyond the stated weight capacity, extreme off-road impacts, severe rock crawling, vehicle collisions, unauthorized modifications, or improper maintenance.
3-Year Warranty
SSB-8 Smart Switch Panel
Designed for maximum off-road reliability, our SSB-8 Smart Switch Panel System is backed by a three (3) year limited warranty from the date of original purchase. This policy covers manufacturing defects in the switch panel, aluminum control box, and internal circuit boards. Coverage does not apply to damage caused by exceeding specified electrical load limits, improper wiring/installation, short circuits, severe trail impacts, or unauthorized disassembly.
1-YEAR LIMITED WARRANTY
Retractable Ratchet Straps (1" & 2" Models)
WOLFBOX retractable ratchet straps come with a 1-year limited warranty from the date of original purchase, covering manufacturing defects in the retraction mechanism, ratchet, webbing, and rubber-coated S-hooks.
The warranty excludes normal wear and tear, misuse, accidents, improper handling, exceeding rated load limits, unauthorized disassembly, and damage caused by hazardous road or off-road conditions.
1-Year Warranty
Dash Cams
WOLFBOX Dash Cams are backed by a one (1) year limited warranty from the date of original purchase. This policy covers defects in materials and workmanship under normal use. It does not cover damage caused by improper installation, misuse, accidents, unauthorized modifications, or improper maintenance.
2-Year Warranty
Air Dusters
WOLFBOX Air Dusters are backed by a two (2) year limited warranty from the date of original purchase. This policy covers manufacturing defects in materials and workmanship under normal use. It does not cover damage caused by misuse, accidents, improper handling, unauthorized modifications, or improper maintenance.
2-Year Warranty
Car Inflators
WOLFBOX Car Inflators are backed by a two (2) year limited warranty from the date of original purchase. This policy covers defects in materials and workmanship under normal operating conditions. It does not cover damage caused by misuse, improper operation, overheating, unauthorized modifications, or failure to follow the recommended operating instructions.
2-Year Warranty
WOLFBOX Jump Starters with Air Compressors are backed by a two (2) year limited warranty from the date of original purchase. This policy covers manufacturing defects in materials and workmanship under normal use. It does not cover damage caused by misuse, improper charging, accidents, unauthorized modifications, or improper maintenance.
2-Year Warranty
Jump Starters
WOLFBOX Jump Starters are backed by a two (2) year limited warranty from the date of original purchase. This policy covers defects in materials and workmanship under normal operating conditions. It does not cover damage caused by improper charging, misuse, accidents, unauthorized modifications, or improper maintenance.
Lifetime Warranty
Truck Bed Mats
3W Truck Bed Mats are backed by a lifetime limited warranty against defects in materials and workmanship. This policy covers manufacturing defects under normal use and proper installation. It does not cover damage caused by misuse, improper installation, excessive wear, unauthorized modifications, or improper maintenance.
5- YEAR LIMITED WARRANTY
Truck Bed Organizer System
WOLFBOX warrants its truck bed organizer system, including the bed mat and all cargo blockers, against defects in materials and workmanship for five (5) years from the date of original purchase, provided the product is installed in accordance with the official installation instructions.
This five (5)-year limited warranty does not cover damage caused by neglect, misuse, accidents, improper installation, unauthorized modifications, improper maintenance or lack of maintenance, or normal wear and tear resulting from everyday use.
2-Year Warranty
Camping Light
WOLFBOX Camping Lights are backed by a two (2) year limited warranty from the date of original purchase. This policy covers defects in materials and workmanship under normal use. It does not cover damage caused by misuse, accidents, improper charging, unauthorized modifications, improper maintenance, or exposure to environmental conditions beyond the product's specified protection rating.
1-Year Warranty
Electric Wagon
WOLFBOX Electric Wagons are backed by a one (1) year limited warranty from the date of original purchase. This policy covers defects in materials and workmanship under normal operating conditions. It does not cover damage caused by overloading beyond the rated weight capacity, improper operation, accidents, collisions, unauthorized modifications, improper maintenance, or failure to follow the instructions and safety guidelines provided in the user manual.
Our Product Warranty
This is our direct promise to you. We stand behind the materials and workmanship of every piece of gear that bears the WOLFBOX name.
What This Warranty Covers
WOLFBOX Gear will cover any defects in the material or workmanship of your product, provided you are the original purchaser and can supply valid proof of purchase.
How to Make a Claim
To start a warranty claim, please contact our support team with the following information:
  • A valid order number from the WOLFBOX Gear official store or an authorized retailer.
  • A sales invoice or order confirmation email that clearly shows the product description, its price, and the sales channel.
  • Photos or a video clearly showing the alleged defect.
Warranty Exclusions (The Fine Print)
This warranty is built on fairness, but it cannot cover issues outside of our control. This warranty does not cover:
  • Products that have been lost, stolen, or fully refunded.
  • Damage, defects, or malfunctions caused by improper installation, modification, or any use outside of the product's intended purpose.
  • Damage caused by misuse, abuse, accidents, improper or inadequate maintenance.
  • Damage from on-road or off-road hazards, such as rock impacts, submersion, or other environmental factors.
  • Normal wear and tear (e.g., cosmetic scratches, fading of finishes over time).
  • Any costs associated with product installation, removal, or re-installation (labor costs).
  • Products purchased without valid proof of purchase or products where the warranty period has expired.
This warranty is provided to the original purchaser and is non-transferable. The warranty period for gift products is not covered. Warranty terms and durations may vary by country according to local laws and regulations.
