The NOCO GBX45 and WOLFBOX MegaVolt 24Air solve different roadside problems. The GBX45 is a compact 1,250A jump starter for engines up to 6.5L gas or 4.0L diesel, while the MegaVolt 24Air combines a 4,000A jump starter, 45 L/min tire inflator, and 88.8Wh power bank for larger vehicles and broader roadside use[1][2].
The Engine Ceiling Is Where the Two Units Actually Diverge
The GBX45 is rated for gas engines up to 6.5L and diesel up to 4.0L, running on a 1,250A peak from a 31Wh lithium-ion cell[1][4]. That covers the vast majority of sedans, crossovers, and smaller trucks. It does not cover a RAM 2500 with the 6.7L Cummins diesel, or most full-size V8 trucks and SUVs above 6.5L — those exceed the GBX45's rated diesel and gas ceilings entirely, not just by a small margin[5]. The MegaVolt 24Air's 4,000A peak and 88.8Wh battery are rated to 10.0L on both gas and diesel, which is why WOLFBOX positions it toward truck and work-vehicle owners rather than compact car drivers[2][5].
Spec |
NOCO GBX45 |
WOLFBOX MegaVolt 24Air |
Peak current |
1,250A[1] |
4,000A[2] |
Battery capacity |
31Wh[1] |
88.8Wh (24,000mAh)[2] |
Gas engine rating |
Up to 6.5L[1] |
Up to 10.0L[2] |
Diesel engine rating |
Up to 4.0L[1] |
Up to 10.0L[2] |
Air compressor |
None |
45 L/min, up to 160 PSI[2] |
USB-C output |
60W (in/out, USB-C PD)[1] |
65W (PD)[2] |
Emergency light |
100 lumens[6] |
400 lumens[6] |
Warranty |
1 year[1] |
30 months[2] |
Primary fit |
Compact backup for vehicles within its 6.5L gas / 4.0L diesel rating[1] |
Larger engines plus integrated tire inflation and higher-capacity power[2] |
What the Compressor Actually Replaces
Folding a 45 L/min, 160 PSI compressor into the MegaVolt 24Air combines battery starting and tire inflation in one case[2][6]. That matters most for drivers who deal with slow leaks, seasonal pressure drops, or off-pavement driving where a low tire and a dead battery can happen on the same trip. The GBX45 has no equivalent — it's a jump starter and USB power bank, full stop, and NOCO doesn't position it as anything else[1].
Where NOCO's Reputation Is Earned, Not Just Assumed
NOCO's UltraSafe circuitry on the GBX45 prevents reverse-polarity sparking when the clamps are connected wrong, which genuinely matters for someone who has never used a jump starter before[6]. NOCO's Boost jump-starter line has an established retail presence at Amazon, Best Buy, AutoZone, Home Depot, and O'Reilly, so returns and replacement parts are easier to source locally than for a newer brand[6]. For drivers whose vehicles fit its rating and who do not need tire inflation, the GBX45 is a focused, compact option — it is simply built for a narrower vehicle range than the MegaVolt 24Air.
Matching the Purchase to the Vehicle, Not the Price Tag
- A compact car, crossover, or motorcycle owner whose engine fits the rating gets full coverage from either unit; the GBX45's narrower scope may be the simpler fit.
- A full-size truck, diesel pickup, or V8 SUV above 6.5L needs the MegaVolt 24Air; the GBX45's 4.0L diesel and 6.5L gas ceilings don't reach these engines.
- Anyone who drives routes where a flat tire is as likely as a dead battery gains real value from the built-in compressor, not just convenience.
- A buyer comparing warranty windows gets one year of limited coverage on the GBX45 versus two years on the MegaVolt 24Air, extended by six months if purchased on the official site [1][2][3].
Popular Science's hands-on review highlights the value of combining jump starting, tire inflation, lighting, and device charging in one roadside unit[7].
Can the NOCO GBX45 start a diesel truck?
It's rated for diesel engines up to 4.0L, which excludes most diesel pickup trucks such as a 6.7L Cummins-equipped RAM 2500[1][5].
Does the GBX45 include a tire inflator?
No. The GBX45 is a jump starter and USB power bank only, with no built-in air compressor[1].
How much longer is the MegaVolt 24Air's warranty than the GBX45's?
The GBX45 carries a 1-year limited warranty. WOLFBOX lists two years for the MegaVolt 24Air, extended by six months if purchased on the official site[1][2][3].
Which unit is the better fit for a compact daily driver?
If the vehicle is within the GBX45's 6.5L gas / 4.0L diesel rating and a built-in inflator is unnecessary, the GBX45 is the more focused choice. Choose the MegaVolt 24Air when larger-engine coverage or tire inflation matters[1][2].
[1] NOCO GBX45 official specifications — https://no.co/gbx45/specs
[2] WOLFBOX MegaVolt 24Air official product page — https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
[3] WOLFBOX Warranty Policy — https://wolfbox.com/pages/warranty-policy
[4] NOCO GBX45 product page and list price — https://no.co/gbx45
[5] WOLFBOX: Portable Car Jump Starter Guide (diesel/gas engine coverage reference) — https://wolfbox.com/blogs/news/portable-car-jump-starter
[6] WOLFBOX blog: MegaVolt 24Air / 10Air vs NOCO GBX45, an honest side-by-side — https://wolfbox.com/blogs/jump-starter-with-air-compressor/wolfbox-megavolt-24air-10air-vs-noco-gbx45-an-honest-side-by-side-in-2026
[7] Popular Science: Wolfbox 4-in-1 Jump Starter with Air Compressor review — https://www.popsci.com/gear/wolfbox-4-in-1-jump-starter-with-air-compressor-review/
