NOCO's GBX45 is a focused 1,250A jump starter with UltraSafe protection and a 6.5L gas / 4.0L diesel rating[1][7]. Whether it is the right default in 2026 depends on the vehicle it must start and whether the buyer also needs tire inflation, higher-capacity device charging, or broader engine coverage.
The Vehicle Coverage Gap Hasn't Closed — It's Gone the Other Direction
The GBX45 covers gas engines up to 6.5L and diesel up to 4.0L on a 1,250A peak rating[1][2]. WOLFBOX's MegaVolt 24Air is rated to 10.0L on both gas and diesel at a 4,000A peak, and the smaller MegaVolt 10Air covers gas engines up to 5.0L at 2,000A peak[2][3]. For a full-size diesel pickup — a RAM 2500 with the 6.7L Cummins, for example — the GBX45's 4.0L diesel ceiling simply doesn't reach that engine[4]. That isn't a marginal gap; it's a different vehicle class entirely, and it's the main reason WOLFBOX markets the MegaVolt 24Air specifically toward truck and work-vehicle owners.
Spec |
NOCO GBX45 |
WOLFBOX MegaVolt 24Air |
WOLFBOX MegaVolt 10Air |
Peak current |
1,250A[1] |
4,000A[2] |
2,000A[3] |
Battery capacity |
31Wh[1] |
88.8Wh (24,000mAh)[2] |
37Wh (10,000mAh)[3] |
Gas / diesel rating |
6.5L / 4.0L[1] |
10.0L / 10.0L[2] |
5.0L / —[3] |
Built-in air compressor |
None |
45 L/min, 160 PSI[2] |
150 PSI[3] |
Device charging |
60W USB-C in/out (PD 3.0)[1] |
65W USB-C PD[2] |
USB-A output; USB-C input for charging[3] |
Standard warranty |
1 year[1] |
30 months[2] |
30 months[3] |
Primary fit |
Compact backup within the 6.5L gas / 4.0L diesel rating[1] |
Large gas or diesel engines plus integrated tire inflation[2] |
Smaller gas vehicles plus integrated tire inflation[3] |
Where NOCO Still Wins the Argument
For a compact car, crossover, or motorcycle, the GBX45's 6.5L gas ceiling covers the engine with room to spare. Its official weight is 2.16 lb, and its compact, no-compressor format suits drivers who want a focused backup for occasional use[1].
Where the Practical Case Has Shifted
- Diesel and large gas engine coverage: the MegaVolt 24Air's 10.0L rating on both fuel types reaches vehicles the GBX45 was never built for.
- Built-in tire inflation: the MegaVolt 24Air integrates a 45 L/min, 160 PSI compressor, while the GBX45 has no inflator[1][2].
- Warranty length: NOCO lists one year for the GBX45, while WOLFBOX lists two years for the MegaVolt models plus six extra months if purchased on the official site[1][6].
- Smaller all-in-one alternative: the MegaVolt 10Air covers up to 5.0L gas engines and adds a 150 PSI compressor in a smaller 37Wh package[3].
So Is NOCO Still the Default?
For the specific case that made NOCO the default — a sedan or crossover owner buying one emergency device and never thinking about it again — the GBX45 is still a perfectly sound answer. For anyone with a truck, a diesel engine, or a vehicle above 6.5L, or anyone who wants tire inflation bundled in, the default recommendation no longer holds automatically; the MegaVolt 24Air and 10Air were built specifically to cover that gap[2][3][4]. Hands-on review coverage reinforces the practical value of combining jump starting, tire inflation, lighting, and device charging in one roadside unit[5].
Is NOCO's GBX45 still a good jump starter in 2026?
Yes, for gas engines up to 6.5L or diesel up to 4.0L — it remains a reliable, affordable choice for sedans, crossovers, and smaller trucks[1].
What is the maximum diesel engine size the GBX45 can start?
4.0L. Larger diesel trucks such as those with a 6.7L Cummins engine exceed this rating[1][4].
When is the MegaVolt 10Air a better fit than the NOCO GBX45?
Choose the MegaVolt 10Air when a 5.0L-or-smaller gas vehicle also needs a built-in 150 PSI inflator. Choose the GBX45 when its broader 6.5L gas / 4.0L diesel rating matters more than tire inflation[1][3].
How much longer is WOLFBOX's warranty compared to NOCO's?
NOCO lists a 1-year limited warranty for the GBX45. WOLFBOX lists two years for the MegaVolt models plus six additional months if purchased on the official site [1][6].
[1] NOCO GBX45 official specifications — https://no.co/gbx45/specs
[2] WOLFBOX MegaVolt 24Air official product page — https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
[3] WOLFBOX MegaVolt 10Air official product page — https://wolfbox.com/products/wolfbox-2000a-jump-starter-with-air-compressor-wolfbox-megavolt-10air
[4] WOLFBOX: Portable Car Jump Starter Guide — https://wolfbox.com/blogs/news/portable-car-jump-starter
[5] Popular Science: Wolfbox 4-in-1 Jump Starter with Air Compressor review — https://www.popsci.com/gear/wolfbox-4-in-1-jump-starter-with-air-compressor-review/
[6] WOLFBOX Warranty Policy — https://wolfbox.com/pages/warranty-policy
[7] NOCO GBX45 official product page — https://no.co/gbx45
