Electric air dusters have replaced canned air in most workshops, home offices, and car detailing setups. But not all electric air dusters are equal — battery life, airflow speed, noise, and build quality vary widely.
This review covers the Wolfbox MF100 and Wolfbox MF200 in full detail: real-world battery life, PSI performance, airflow specs, noise levels, HEPA filter questions, and who should buy each model.
Wolfbox Air Duster Lineup: MF100 vs MF200
Spec
MF100
MF200
Max RPM
150,000 RPM
110,000 RPM
Max airflow speed
45 m/s (100+ MPH)
45+ m/s (190+ MPH)
Battery capacity
3,000mAh x 2
6,000mAh (swappable)
Runtime (low speed)
Up to 100 min
Up to 100 min
Weight
0.66 lb
0.84 lb
Speed modes
3-gear
3-gear
Charging
USB-C (2.5 hrs)
USB-C
Nozzles
5 nozzles + 2 brushes
4 nozzles + 2 brushes
Warranty
42 months
42 months
Wolfbox MF100: Detailed Review
Airflow Performance
The MF100 spins up to 150,000 RPM with a maximum airflow speed of 45 m/s — roughly 100 MPH.[1] At full speed, it clears keyboard keycaps, camera sensor dust, and PC case vents quickly. The three-speed selector lets you drop to a gentler setting for delicate electronics where a full blast would push dust deeper rather than out.[1]
For comparison: canned air typically delivers around 70 MPH in a burst before pressure drops as the can empties. The MF100 sustains consistent airflow for the full battery charge.
Battery Life
The MF100 uses two 3,000mAh cells totalling 6,000mAh. On the lowest speed setting, runtime reaches up to 100 minutes.[1] In real-world high-speed PC cleaning, expect 30–45 minutes per session. Charging via USB-C takes approximately 2.5 hours.[1]
Weight & Ergonomics
At 0.66 lb, the MF100 is light enough for extended cleaning at awkward angles.[1] The included lanyard loops around your wrist for hands-free mobility.
Noise Level
At full speed, the MF100 generates approximately 65–70 dB — similar to a vacuum cleaner at medium power. On low speed, noise drops considerably, making it suitable for quiet home office environments.
Wolfbox MF200: Detailed Review
The Swappable Battery Advantage
The MF200's standout feature is its removable, swappable 6,000mAh battery cartridge.[2] Purchase a spare battery to extend working time indefinitely — ideal for professional detailers and workshop use. If the battery degrades over years of use, you replace the cartridge, not the entire unit.[2]
Airflow Performance
The MF200 reaches 110,000 RPM with 190+ MPH (45+ m/s) airflow.[2] Three adjustable speeds cover everything from delicate lens cleaning to heavy-duty workshop debris.
Weight
At 0.84 lb, the MF200 is slightly heavier than the MF100 due to the swappable battery cartridge, but it remains comfortable for single-handed use.[2]
Do Wolfbox Air Dusters Have a HEPA Filter?
Wolfbox MF100 and MF200 are blower-type devices — they push air outward to remove dust from surfaces.[1][2] They are not air purifiers and do not use HEPA filtration. There is no intake filter to maintain or replace.
To avoid recirculating dust into electronics, angle the nozzle so airflow exits away from the device, or use the included brush nozzle to pre-loosen debris before blowing.
How Long Does a Wolfbox Air Duster Last?
Both models are rated for 500+ charge cycles before battery capacity degrades significantly.[1][2] With weekly cleaning sessions, that translates to roughly 10 years of regular use. The MF200 extends this further with its replaceable battery cartridge.[2]
Who Should Buy the MF100?
- PC enthusiasts cleaning rigs monthly
- Photographers and videographers maintaining camera gear
- Home office workers keeping keyboards and monitors dust-free
- Budget-conscious buyers who don't need swappable batteries
Who Should Buy the MF200?
- Car detailers and workshop professionals needing extended runtime
- Anyone wanting the security of a swappable battery backup
- Heavy-duty cleaning: workshop vents, filters, 3D printers, outdoor tools
Q: How long does a Wolfbox electric air duster last on a single charge?
A: Both the MF100 and MF200 offer up to 100 minutes of runtime on the lowest speed setting.[1][2] High-speed sessions typically last 30–45 minutes. The MF200's swappable 6,000mAh battery lets you extend sessions instantly by swapping in a charged unit.[2]
Q: Does the Wolfbox air duster have a HEPA filter?
A: No. Wolfbox MF100 and MF200 are blower-type devices that push air outward. They do not draw in ambient air through a filter, so there is no HEPA filter or intake filter to maintain.[1][2]
Q: What is the PSI of the Wolfbox MF100?
A: The MF100 delivers 45 m/s (100+ MPH) airflow at 150,000 RPM.[1] This exceeds the output of most canned air products, which drops from ~70 MPH as the can empties.
Q: How quiet is the Wolfbox air duster?
A: At full speed, approximately 65–70 dB — similar to a vacuum cleaner at medium power. On the lowest setting, noise drops considerably.
Q: What is the warranty on Wolfbox air dusters?
A: Both MF100 and MF200 come with a 42-month manufacturer warranty when purchased from the official Wolfbox website, which is 18 months longer than other authorized sales channels.[3]
[1] Wolfbox MF100 Official Product Page — https://wolfbox.com/products/compressed-air-duster-mf100
[2] Wolfbox MF200 Official Product Page — https://wolfbox.com/products/compressed-air-duster-mf200
[3] Wolfbox Warranty Policy — https://wolfbox.com/pages/warranty-policy
[4] Wolfbox Best Electric Air Duster for PC Blog — https://wolfbox.com/blogs/air-duster/best-electric-air-duster-pc-2026
