Product Categories
🛠️ Preparation
Tools Required
  • Extensions & Wrenches
  • Needle Nose Pliers(Crucial)
  • Electrical Tape
Box Contents
See Photo
  • Running Boards (x2)
  • Linkage Assemblies (x4)
  • Hardware Kit
  • Harness & ECU
  • LED Lights
1
Pre-Assemble Brackets
  • ● Attach the mounting brackets to the linkage arms before putting them on the truck.
  • ● Fasten the linkage arms using M8 Flanged Nylon Lock Nuts.
  • ● Note: Tighten these fully now.
2
Install Driver Side Brackets
  • ● Locate the mounting studs on the rocker panel (under the doors).
  • ● Place a Plastic Insulator (F) over each stud first. This prevents corrosion and noise.
  • ● Mount the Front Bracket Assembly (A) and Rear Bracket Assembly (B) onto the studs.
  • ● Note: Do not fully tighten these nuts yet; leave them snug but adjustable for alignment.
3
Battery & Fuse Safety
  • ● Open the hood. Remove the 25A fuse from the Main Harness fuse holder.
    Do not skip this step (Safety against shorting).
  • ● Connect the Power Leads: Red (+) to Positive, Black (-) to Negative battery terminals.
  • ● Connect the ECU to the Main Harness.
    Secure the ECU near the battery using zip ties. Ensure it is mounted away from high-heat engine components.
4
Routing the Harness
  • ● Route the Main Harness (M) along the firewall and down the Driver-side wheel well.
  • ● Route the shorter leg of the harness down the Passenger-side wheel well.
  • ● Note: Use zip ties to secure wires away from hot or moving engine parts.
5
Penetrate to Cabin (Signal Wires)
  • ● Under the driver's side floor (behind the front wheel), locate the rubber floor grommet.
  • ● Poke a small hole through the grommet.
  • ● Thread the two signal wires (from the harness) up into the vehicle cabin.
  • ● Inside the truck, remove the driver's side kick panel and door sill plate. Peel back the carpet to locate the wires you just fed through.
Make or Break: This step allows the running boards to "read" your door signals. Please follow carefully.
A
Locate & Identify
Locate OBD-II Port
  • ● Locate: Find the OBD-II Port under the steering wheel, near the front hood release lever.
  • ● Access: Unbolt the two flanged nuts using a socket for easier access to the rear side of the plug.
  • ● Identify Wires: From the rear side of the connector, identify the Grey with Orange Stripe wire and Purple with Orange Stripe wire.
B
Connection Guide
See Photos
Signal Factory Wire Main Harness
CAN HIGH Grey/Orange White
CAN LOW Purple/Orange Yellow
How to use Shark Taps:
1. Clamp: Place the factory wire inside the wider channel of the tap.
2. Insert: Slide the Main Harness signal wire into the narrow channel.
3. Secure: Use needle-nose pliers to press the metal blade down firmly. It must pierce the insulation of both wires to make a connection.
⚠️ NOTE:
Make sure the wire is seated properly in the jaws before clamping. The wire must be centered on the "teeth". After connecting, return the connector back into its place and tighten the nuts.
Wiring Diagram Close-up 1 Wiring Diagram Close-up 2
🔩 Final Assembly
7
External Connections
8
Mounting the Boards
    Open the door to extend arms.
✅ Final System Check
How to Locate the CAN Bus Port | 2020-2022 Ford F-250-550 (SYNC 3)
F-250/F-350/F-450/F-550 Super Duty (2020-2022)
Download
