Catalog
🛠️ Preparation
1
Unboxing & Inventory
Tonneau Cover Box Contents
2
PREP & DRILLING
Remove Front Utility Track Insert Threaded Blocks Front Drain Holes Power Harness Hole Rear Drain Holes Rear Drain Holes
  • ● Remove Front Utility Track: Remove the front bed utility track (7 T30 bolts + plastic tabs). Pull back firmly to pop it out. It will not be reinstalled.
  • ● Install Threaded Blocks: Remove the plastic cap at the end of the side mounted utility track and slide in six (6) 8mm threaded mount blocks per side.
    *(If your truck doesn't have side tracks, install the included replacement tracks first).*
  • ● Front Drain Holes: Measure 4" (100mm) from the side and 3 1/4" (85mm) up from the base. Use a 19mm hole saw to drill the holes into the raised vertical ribs on both sides.
  • ● Power Harness Hole: (Driver Side Only) Measure 4" (100mm) from the side and 6 1/8" (155mm) up from the base. Use a 16mm (5/8") drill bit to drill the hole. Caution: Use a drill stop!
  • ● Rear Drain Holes: Drill one 19mm hole on each side, located in front of the raised section at the rear of the bed.
3
APPLY WEATHER SEALS
  • ● Clean Surfaces: Thoroughly clean the top of the plastic bed caps and the top of the front bed bulkhead of any dirt or debris.
  • ● Hard Foam Seal: Install the front bulkhead seal (hard foam seal) straight across the top of the front bulkhead.
  • ● Soft Foam Seals: Install the water-resistant seals (soft foam seals) across the top of the front bulkhead (right on top of the hard seal) and along the plastic bed caps. Position them as close to the inner edge of the bed as possible and trim off any excess.
  • ● Mastic Tape: Cut a piece from the included mastic tape roll, rub it into a strip with your hands, and press it firmly into the corners of the front bulkhead to improve water resistance.
4
INSTALL MOTOR
5
INSTALL SIDE RAILS
6
INSTALL CANISTER COVER PLATE
⚡Wiring & Routing
6
CONNECT WIRE HARNESS
7
ROUTE THE POWER HARNESS
Routing Step 1 Routing Step 2 Routing Step 3 Routing Step 4 Routing Step 5 Routing Step 6
    Dedicated Routing Hole: The tonneau cover power harness must be routed out through the 16mm (5/8") hole on the driver side of the bed that was drilled previously in Step 2.
    From there, the harness will travel down the length of the vehicle frame, up into the engine bay, and to the vehicle battery on the passenger side.
    Open the fuse holder cap, remove the fuse, and then connect the positive power harness connector to the main power harness. Do not connect the power harness to the vehicle battery at this time.
🔌Bed Installation & Alignment
9
INSTALL TONNEAU COVER
    HEAVY LIFTING: With assistance, carefully lift the tonneau cover assembly and place it on top of the truck bed.
    Do not slide the tonneau cover along the bed as this will damage the foam seals you installed earlier.
    Leave the front of the tonneau cover about 1ft from the front of the bed and connect the power harness to the connector on the ECU main harness.
    Carefully lift the tonneau cover and position it as far forward as possible. Be careful not to pinch the wire harness. Leave a small gap between the canister and the front of the bed.
10A
BRACKETS (FACTORY TRACKS)
Factory Tracks Bracket Install 1 Factory Tracks Bracket Install 2 Factory Tracks Bracket Install 3
    Start on the driver side. Insert three (3) 6mm T-channel blocks into the bottom channel of the side rail and space them evenly.
    Position the three (3) mount brackets to align with the 8mm threaded blocks you slid into the factory utility track during Step 2.
    Use one (1) 6-1.00mm x 16mm T30 Torx bolt to attach each mount bracket to the side rail.
    Use two (2) 8-1.25mm x 25mm T40 Torx bolts, lock washers, and flat washers to attach each mount bracket to the 8mm threaded blocks inside the utility track.
    Important: Leave all hardware loose. Position the front bracket as far forward and the rear bracket as far backward as possible. Repeat for passenger side.
10B
BRACKETS (NO FACTORY TRACKS)
No Factory Tracks Bracket Install 1 No Factory Tracks Bracket Install 2 No Factory Tracks Bracket Install 3 No Factory Tracks Bracket Install 4
    Start on the driver side. Insert three (3) 6mm T-channel blocks into the bottom channel of the side rail.
    Align the blocks with the mount points on the replacement tracks (installed during Step 2).
    Use one (1) 6-1.00mm x 16mm T30 Torx bolt to attach each of the three (3) mount brackets to the side rail.
    Attach each mount bracket to the bed side using two (2) 8-1.25mm x 25mm T40 Torx bolts, flat washers, lock washers, and two (2) 8mm threaded mount blocks.
    Important: Leave all mount bracket hardware loose at this time. Repeat this process for the passenger side.
11
ALIGN THE SIDE RAILS
🔩Finalizing & Powering Up
11
INSTALL DRAIN TUBES
12
FINISH INSTALLATION
Install Guide
Download
What's Included
Download
How to Use
Download
