Catalog
🛠️ Preparation
1
Unboxing & Inventory
Tonneau Cover Box Contents
2
Prep the Truck Bed
  • ● Remove Original Parts: If the truck is equipped with bed-mounted utility tracks, remove them now using a 10mm wrench or socket. The utility tracks will not be reinstalled. Also, remove any reinforcement brackets located at the front corners of the bed.
  • ● Install Threaded Inserts: If your truck does not have threaded inserts installed in the bed sides, identify the mounting points and install the supplied 6mm inserts using the included threaded insert installation tool. Each side of the bed will require six (6) inserts (two per mounting location).
  • ● Apply Seals: Clean the top of the plastic bed caps and front bulkhead. Install the front bulkhead seal (hard foam seal) across the top of the front bulkhead.
  • ● Install the water-resistant seals (soft foam seals) on top of the front bulkhead seal and the plastic bed caps. Position them as close to the inner edge as possible and trim off any excess.
  • ● Mastic Tape: Cut a piece from the included mastic tape roll, rub it into a strip, and press it firmly into the front bulkhead corners to improve water resistance.
3
INSTALL MOTOR
4
INSTALL SIDE RAILS
5
INSTALL CANISTER COVER PLATE
⚡Wiring & Routing
6
CONNECT WIRE HARNESS
7
ROUTE THE POWER HARNESS
Routing Step 1 Routing Step 2 Routing Step 3 Routing Step 4 Routing Step 5 Routing Step 4
    The tonneau cover power harness will be routed out through the hole near the top driver side of the bed.
    From there the harness will travel down the length of the vehicle frame, up into the engine bay, and to the vehicle battery on the passenger side.
    Open the fuse holder cap, remove the fuse, and then connect the positive power harness connector to the main power harness. Do not connect power harness to the vehicle battery at this time.
🔌Bed Installation & Alignment
8
INSTALL TONNEAU COVER
    Grab a buddy and carefully lift the entire tonneau cover assembly onto the truck bed. Do not slide it along the bed rails, or you'll tear up those foam seals you just applied!
    Set it down leaving about a 1-foot gap from the front bulkhead.
    Plug the main power harness into the ECU connector.
    Carefully lift and nudge the cover as far forward as possible. Make sure to leave a slight gap between the canister and the front of the bed so they aren't rubbing.
9
INSTALL MOUNT BRACKETS
Insert T-Blocks1 Hardware Setup Bracket Install Bracket Install4
    Insert three (3) 6mm T-channel blocks into the bottom channel of each side rail. Slide them into position directly above the front, center, and rear bed mounting points.
    Identify the front, center, and rear mount brackets, and place them at their corresponding locations on the bed side.
    Use two (2) 6-1.00mm x 20mm Torx bolts to loosely attach each mount bracket to the bed side.
    Use one (1) 6-1.00mm x 16mm Torx bolt to loosely attach the mount bracket to the T-channel block inside the side rail.
    Attach the double nut support brackets to the main mount brackets using the remaining two (2) 6-1.00mm x 20mm Torx bolts. Important: Leave all hardware loose at this time. Repeat for the passenger side.
10
ALIGN THE SIDE RAILS
🔩Finalizing & Powering Up
11
INSTALL DRAIN TUBES
12
FINISH INSTALLATION
2021 Ram 1500 Install (See Manual for Specifics)
Install Guide
Download
What's Included
Download
How to Use
Download
