Vantrue’s N4 Pro S uses three Sony STARVIS 2 sensors, while WOLFBOX’s G900TriPro pairs a STARVIS 2 front sensor with an OmniVision PureCel Plus rear sensor.[1][5] The more useful comparison is form factor, storage ceiling, and which third-camera layout fits the vehicle.
Two Three-Channel Systems, Two Different Shapes
WOLFBOX’s G900TriPro is a 12-inch mirror-format unit that mounts over the factory rearview mirror, recording front, rear, and either cabin or bumper footage depending on the version.[1][6] Vantrue’s N4 Pro S is a compact windshield-mounted unit with a small onboard screen, built around the same three-channel concept without a mirror-replacement design.[3][5] The two systems differ chiefly in their physical layout, sensor mix, and storage ceiling.
Spec Comparison
Attribute |
WOLFBOX G900TriPro |
Vantrue N4 Pro S |
Front sensor |
Sony STARVIS 2 IMX678[1] |
Sony STARVIS 2 IMX678[4] |
Cabin sensor |
1080P cabin camera (Cabin version)[6] |
Sony STARVIS 2 IMX662 with automatic IR LEDs[4] |
Rear sensor |
OmniVision OS04J10, 2.5K[1] |
Sony STARVIS 2 IMX675, waterproof (IP67), 2.5K[5] |
Display format |
12-inch mirror display[1] |
Compact onboard screen[5] |
Max microSD |
512GB[2] |
Up to 1TB[7] |
Regular price |
Check current official product page[1] |
Check current official product page[5] |
Why the Rear Camera Detail Actually Matters
Vantrue markets the N4 Pro S rear camera as waterproof (IP67-rated), which matters specifically for anyone mounting it externally near the rear bumper or license plate area where it's exposed to road spray and weather[3][5]. WOLFBOX offers two configurations: the Cabin version uses an interior-facing third camera, while the Bumper version uses an externally mounted third camera.[1][6] That lets buyers select the coverage angle that matches their vehicle and use case.
Storage Headroom Is a Real Practical Difference
The N4 Pro S supports microSD cards up to 1TB, while the G900TriPro supports up to 512GB.[2][7] That difference matters most for drivers who want more room before reviewing or exporting recordings.
Price Difference Reflects More Than Just the Sensor Count
Current prices and promotions change, so compare the official product pages before buying and factor in the accessories needed for the intended installation.[1][5] The more durable choice is whether a mirror-format display and configurable third camera, or a compact unit with three STARVIS 2 sensors and higher storage capacity, better fits the intended use.
Which Setup Fits Which Driver
- Choose WOLFBOX's mirror-format triple-channel system if a persistent, always-visible in-car display matters more than squeezing every channel onto Sony's latest sensor
- Choose a compact triple-channel unit with STARVIS 2 on all channels if cabin-camera night clarity or extended microSD storage is the priority
- Rideshare and delivery drivers who need a rear camera mounted externally near the plate should confirm the weatherproofing rating of whichever unit they choose, since exposure to road spray differs by mounting position
Do the G900TriPro and N4 Pro S use the same front camera sensor?
Yes. Both use the Sony STARVIS 2 IMX678 sensor for the front channel.
What's the difference between the Cabin and Bumper versions of the G900TriPro?
The Cabin version places the third camera inside the vehicle facing the interior, while the Bumper version mounts it externally.
How much storage does each system support?
The G900TriPro supports microSD cards up to 512GB, while the N4 Pro S supports up to 1TB.
Is the WOLFBOX mirror display better than a small onboard screen?
It depends on the use case. A 12-inch mirror display works as a functional rearview mirror with live footage, while a small onboard screen is mainly for quick settings checks rather than continuous viewing.
[1] WOLFBOX G900TriPro Bumper Version 4K Sony STARVIS 2 Mirror Dash Cam — Official Product Page, https://wolfbox.com/products/wolfbox-g900tripro-bumper-version-4k-sony-starvis-2-mirror-dash-cam
[2] G900TriPro Bumper vs Cabin: Which Three-Channel Setup Fits Your Vehicle — WOLFBOX Official Guide, https://wolfbox.com/blogs/dash-cams/g900tripro-bumper-vs-cabin-which-three-channel-setup-fits-your-vehicle
[3] Reviewing and Testing the Vantrue N4 Pro S — DashcamTalk Forum, https://dashcamtalk.com/forum/threads/reviewing-and-testing-the-vantrue-n4-pro-s.53519/
[4] Best 3-Channel Dash Cam for Long Spring Road Trips — Vantrue Official Guide, https://www.vantrue.com/en-jp/blogs/news/best-3-channel-dash-cam-for-long-spring-road-trips-2026-guide
[5] Nexus 4 Pro S — Vantrue Official Product Page, https://www.vantrue.com/products/n4-pro-s
[6] WOLFBOX G900TriPro Cabin Version 3-Channel Dash Camera — Official Product Page, https://wolfbox.com/products/wolfbox-g900tripro-cabin-version-3-channel-dash-camera
[7] N4 Pro S Product Manual, Firmware, and FAQs — Vantrue Official Support, https://www.vantrue.com/pages/n4pros-manual-firmware
