Wolfbox vs Viofo: What Changes When You Move From a Windshield Unit to a Mirror Display
VIOFO's A229 Pro and WOLFBOX's G900 Pro both use the same front-facing Sony STARVIS 2 IMX678 sensor, so the usual debate over which brand has better night vision doesn't really apply here. The actual choice comes down to something more practical: do you want a compact windshield unit with a small screen, or a 12-inch display that replaces your rearview mirror.
Matching Sensors, Different Philosophies
VIOFO's A229 Pro pairs an 8MP Sony STARVIS 2 IMX678 front sensor with a 5MP Sony STARVIS 2 IMX675 rear sensor, delivering 4K front and 2K rear recording with HDR on both channels[1][2]. WOLFBOX's G900 Pro uses the same IMX678 front sensor at 4K, paired with an Omnivision Purecel® Plus OS04J10 2.5K rear camera[3]. Both companies made the same engineering choice — spend the premium sensor budget on the front camera where detail matters most for the widest range of driving scenarios — but VIOFO ships this in a compact windshield unit with a 2.4-inch screen, while WOLFBOX builds it into a 12-inch mirror-format display[1][4].
Spec Comparison
Attribute
WOLFBOX G900 Pro
VIOFO A229 Pro (3CH)
Front sensor
Sony STARVIS 2 IMX678, 4K[3]
Sony STARVIS 2 IMX678, 4K[1][2]
Rear sensor
Omnivision Purecel® Plus OS04J10, 2.5K[3]
Sony STARVIS 2 IMX675, 2K[1][2]
Cabin/interior channel
Available on G900TriPro variant, 1080P
Optional 1080P interior camera, Sony STARVIS IMX307[2]
Display
12-inch mirror-format IPS[3][6]
2.4-inch LCD screen[5]
Max microSD
512GB[3]
512GB[2]
Current price
Check current official product page[3]
Check current official product page[1]
The Cabin Camera Sensor Gap Worth Knowing About
VIOFO's optional interior camera on the A229 Pro uses an older Sony STARVIS sensor (IMX307), not the STARVIS 2 generation used on its front and rear channels, meaning interior low-light footage doesn't get the same sensitivity boost as the other two cameras[2][5]. This is a detail worth checking on any triple-channel camera, from either brand, since manufacturers sometimes reserve the newest sensor for the highest-priority channel and use an older one for interior or supplementary cameras.
Storage and Screen Size Are the Real Trade-offs
The VIOFO A229 Pro and the WOLFBOX G900 Pro each support microSD cards up to 512GB[2][3].
Installation Differences Worth Knowing Before You Buy
VIOFO's A229 Pro mounts with adhesive stickers directly to the windshield and requires separate cable runs for the rear and interior cameras if running the 3-channel configuration[1][8]. WOLFBOX's mirror units mount with adjustable rubber straps over the factory mirror instead of adhesive, which some drivers find easier to reposition or remove without leaving windshield residue[3][4][7]. Anyone planning to move the camera between vehicles should factor this difference in, since strap-based mounts are generally faster to relocate than adhesive-mounted units.
Which Setup Fits Which Driver
  • Choose VIOFO's A229 Pro if keeping the smallest possible windshield footprint matters most
  • Choose WOLFBOX's G900 Pro if a persistent, always-visible rearview display and strap-based mounting matter most
  • If a triple-channel setup is the goal, check the interior camera's sensor generation specifically, since it may not match the front and rear channels on either brand
Do the WOLFBOX G900 Pro and VIOFO A229 Pro use the same front camera sensor?
Yes. Both use the Sony STARVIS 2 IMX678 sensor for 4K front recording.
Does the VIOFO A229 Pro's interior camera use the same sensor generation as its front and rear cameras?
No. The optional interior camera uses an older Sony STARVIS IMX307 sensor, while the front and rear cameras use STARVIS 2 sensors.
Which camera supports more storage?
The VIOFO A229 Pro and the WOLFBOX G900 Pro each support microSD cards up to 512GB.
How does the WOLFBOX G900 Pro mount compare to VIOFO's adhesive mount?
The G900 Pro uses adjustable rubber straps over the factory rearview mirror, while the A229 Pro uses adhesive stickers directly on the windshield.
[1] VIOFO A229 Pro 4K UHD 3-Channel Dash Cam — BlackboxMyCar Product Page, https://www.blackboxmycar.com/products/viofo-a229-pro-4k-uhd-3-ch-dash-cam
[2] VIOFO A229 Pro Review: 3-Channel Dash Cam With Great Video — Dashboard Camera Reviews, https://dashboardcamerareviews.com/viofo-a229-pro/
[3] WOLFBOX Unveils G900 Pro Dash Cam with STARVIS 2 IMX678 Sensor and Advanced Safety and Navigation Features — WOLFBOX Official Product Page, https://wolfbox.com/products/wolfbox-2024-g900-pro-wifi-touch-screen-parking-monitoring-dash-cam-smart-mirror-with-starvis-678-sensor
[4] WOLFBOX Official Site — Product Homepage, https://wolfbox.com/
[5] Viofo A229 Pro 3-Channel Dash Cam Hands-On Review — The Drive, https://www.thedrive.com/guides-and-gear/viofo-a229-pro-dash-cam-hands-on-review-video
[6] WOLFBOX G900 Pro — Newegg Product Listing, https://www.newegg.com/p/0PD-00UZ-00012
[7] WOLFBOX G900 Pro Dash Cam Manual, https://www.scribd.com/document/941224247/Wolfbox-G900-Pro-20241107
[8] VIOFO A229 Pro — DashcamTalk Product Database, https://dashcamtalk.com/viofo-a229-pro/
Wolfbox vs Vantrue: Mirror Display or Compact Triple-Channel, and Why That's the Real Choice
The 12-Inch Mirror Display: Why Screen Size Became a Real Buying Criterion
