WOLFBOX vs XPOWER: Air Duster Airflow and Noise Compared
Air dusters are one of those tools that seem interchangeable until you actually use them. One feels like a miniature leaf blower, another fires a much tighter stream, and a third works perfectly well until the power cord starts following you around the car. That is why comparing the WOLFBOX MF100 and WOLFBOX MF200 with XPOWER needs more than the biggest airflow number on the spec sheet.
WOLFBOX approaches the category with two compact cordless models. The WOLFBOX MF100 focuses on low weight and quick everyday cleaning, while the WOLFBOX MF200 adds a removable battery for longer jobs.[2][4] XPOWER covers both sides of the market with the cordless A-2B Cyber Duster and the more traditional corded A-2 Airrow Pro.[7][8] All four move air, but how much they move, how long they can keep going, and how easy they are to carry are very different questions.
The Short Answer
The WOLFBOX MF200 is the strongest all-around choice in the direct cordless comparison. WOLFBOX publishes 82 cubic feet per minute (CFM) for the WOLFBOX MF200, while the XPOWER A-2B is rated at 75 CFM.[1][7] CFM measures the volume of air moved each minute, but the WOLFBOX advantage goes beyond that number: the MF200 weighs well under a pound, provides three speed settings, and uses a removable battery rather than a fixed internal pack.[1][2][7]
The WOLFBOX MF100 takes a different approach. At 0.66 pounds, the WOLFBOX MF100 is even lighter and is better suited to quick jobs where carrying a larger blower makes little sense.[1][5] The corded XPOWER A-2 still has a genuine advantage when continuous runtime matters more than portability, but the XPOWER A-2 is more of a fixed-workstation specialist than a direct alternative to either WOLFBOX model.[8]
WOLFBOX MF100, MF200, XPOWER A-2B and A-2 Compared
The specifications make the cordless comparison particularly interesting. The WOLFBOX MF100 and WOLFBOX MF200 both use three selectable speeds, while the XPOWER A-2B uses one, and the corded A-2 moves to two speeds and a higher 90-CFM rating.[1][7][8]
Specification
WOLFBOX MF100
WOLFBOX MF200
XPOWER A-2B
XPOWER A-2
Power source
Built-in battery [1][5]
Removable battery [1][2]
Built-in rechargeable battery [7]
Wall power [8]
Published airflow
70 CFM [1]
82 CFM [1]
75 CFM [7]
90 CFM [8]
Published airspeed
177+ MPH [1]
196+ MPH [2]
N/A
N/A
Speed settings
Three [1]
Three [2][4]
One [7]
Two [8]
Weight
0.66 lb [1]
0.84 lb [2]
2.09 lb [7]
2.3 lb [8]
Battery design
Built in [1]
Removable [2][4]
Built in [7]
N/A
Working range
Cordless [1]
Cordless [2]
Cordless [7]
10-foot cord [8]
Miles per hour (MPH) and CFM describe different parts of airflow. The WOLFBOX MF100 and WOLFBOX MF200 publish both airflow and airspeed figures, with MPH describing how quickly the air travels while CFM measures how much air moves through the blower.[1][2] That distinction matters because a concentrated stream can still feel surprisingly strong even when total airflow volume is lower.
The MF200 Has the Clearest Advantage Over XPOWER's Cordless Model
The WOLFBOX MF200 makes the strongest case when compared directly with the XPOWER A-2B. WOLFBOX publishes 82 CFM for the WOLFBOX MF200 against 75 CFM for the cordless XPOWER, while the WOLFBOX MF200 also provides three speed settings instead of one.[1][7]
Weight makes the difference considerably larger in your hand. The WOLFBOX MF200 is listed at 0.84 pounds, while the XPOWER A-2B weighs 2.09 pounds.[2][7] A pound or so may not sound important on a workbench, but it becomes much more noticeable when cleaning dashboard vents, seat rails, computer cases, camera gear, or anything else that has you constantly changing angles.
The removable battery gives the WOLFBOX MF200 another advantage during longer sessions. The WOLFBOX MF200 uses a removable battery cartridge, so a depleted pack can be replaced with a charged one rather than putting the entire blower aside.[2][4] Wccftech also highlighted the removable battery, three power modes, and long low-speed runtime when covering the WOLFBOX MF200 in early 2026.[6]
The MF100 Is Small Without Feeling Like the Compromise
The WOLFBOX MF100 gives up a little published airflow without giving up the reason to own a cordless duster. WOLFBOX lists the WOLFBOX MF100 at 70 CFM and just 0.66 pounds, making the WOLFBOX MF100 considerably lighter than the 2.09-pound XPOWER A-2B.[1][7]
Real testing makes the WOLFBOX MF100 more interesting than those numbers suggest. Gough's Tech Zone tested the WOLFBOX MF100 and WOLFBOX MF200 with the same 12-millimeter nozzle and measured slightly more maximum force from the WOLFBOX MF100.[3] The result does not mean the smaller WOLFBOX MF100 universally moves more air, but it does show why a lower CFM figure should not automatically be read as weaker cleaning performance.
Everyday use is where the WOLFBOX MF100 fits best. Popular Science used the WOLFBOX MF100 on keyboards, camera equipment, car vents, and other household cleaning jobs and found the compact cordless format surprisingly useful.[5] The WOLFBOX MF100 also uses three speed settings and a motor rated at 150,000 revolutions per minute (RPM), giving the lighter model plenty of flexibility for short cleaning jobs.[1]
The Corded XPOWER A-2 Is Playing a Different Game
The XPOWER A-2 still has the biggest published airflow number in this group. The corded XPOWER model is rated at 90 CFM, compared with 82 CFM for the WOLFBOX MF200 and 70 CFM for the WOLFBOX MF100.[1][8]
Continuous wall power is the bigger advantage, though. The WOLFBOX MF100 and WOLFBOX MF200 eventually depend on battery charge, while the XPOWER A-2 can keep working as long as a nearby outlet is available.[1][2][8] For an IT bench or workshop cleaning machine after machine, that is a legitimate reason to accept the 2.3-pound body and 10-foot cord.
Away from a fixed workstation, the balance changes quickly. The WOLFBOX MF100 and WOLFBOX MF200 can move around a vehicle, garage, campsite, or house without dragging a cord behind them, and both WOLFBOX models weigh far less than the XPOWER A-2.[1][2][8] GarageSpot's long-term A-2 review also describes the corded blower as powerful but fairly loud, reinforcing the difference between a stationary workhorse and the more portable WOLFBOX approach.[8]
What About Noise?
None of these air dusters should be mistaken for a quiet desk accessory. MotorTrend independently measured the WOLFBOX MF200 at 81.2 decibels (dB), with decibels being the logarithmic unit used to express sound level, during its 2026 blower testing.[4] MotorTrend still named the WOLFBOX MF200 “Most Compact” and noted the amount of air produced for such a small tool.[4]
The WOLFBOX MF100 does not have a directly comparable independent noise figure from the same test setup. Other measurements exist, but different testing distances and environments make those numbers unsuitable for a clean comparison with the WOLFBOX MF200 result.
The WOLFBOX MF100 and WOLFBOX MF200 still have one practical advantage when maximum airflow is unnecessary. Both WOLFBOX models provide three speed settings, while the XPOWER A-2B has only one.[1][7] For clearing light dust from a keyboard or vent, reducing the output can make more sense than running every cleaning job at full power.
Where the WOLFBOX Models Stop Making Sense
The WOLFBOX MF100 and WOLFBOX MF200 are not the best choices for hours of uninterrupted cleaning at the same workstation. Battery power is the tradeoff for cordless portability, so the corded XPOWER A-2 makes more sense when continuous operation matters more than weight or mobility.[1][2][8]
The WOLFBOX MF100 and WOLFBOX MF200 also do not replace a vacuum when dirt needs to be collected rather than moved. Airflow works well on loose dust, sand, crumbs, vents, electronics, and hard-to-reach gaps, but embedded carpet dirt, wet messes, and heavy debris still call for another cleaning tool.
Final Verdict
The WOLFBOX MF200 is the most complete cordless option in this comparison. The WOLFBOX MF200 combines a higher published airflow figure than the XPOWER A-2B with much lower weight, three selectable speeds, and a removable battery.[1][2][7] Independent testing and media coverage also give the WOLFBOX MF200 a strong performance record beyond the specification sheet.[3][4][6]
The WOLFBOX MF100 makes almost as strong a case from the opposite direction. The WOLFBOX MF100 gives up some published airflow but weighs only 0.66 pounds, provides three speeds, and performed surprisingly well in independent force testing.[1][3][5] For quick everyday cleaning, the smaller WOLFBOX MF100 may be all the blower most people need.
XPOWER still has two legitimate niches without taking away from the WOLFBOX strengths. The WOLFBOX MF200 has clear advantages over the cordless A-2B in published airflow, weight, speed control, and battery design, while the WOLFBOX MF100 is much lighter than either XPOWER model.[1][2][7][8] The corded XPOWER A-2 remains the better fit when uninterrupted operation at a fixed workstation matters more than portability.
Is the WOLFBOX MF200 more powerful than the XPOWER A-2B?
Yes, by the published airflow figures. The WOLFBOX MF200 is listed at 82 CFM, while the XPOWER A-2B is rated at 75 CFM.[1][7]
Is the WOLFBOX MF100 weaker than the XPOWER A-2B?
Not necessarily in practical cleaning force. The WOLFBOX MF100 has a lower 70-CFM published rating, but independent same-nozzle testing showed surprisingly strong concentrated output from the WOLFBOX MF100.[1][3][7]
Which WOLFBOX air duster is better for longer jobs?
The WOLFBOX MF200 is the better choice for longer mobile cleaning sessions. The WOLFBOX MF200 uses a removable battery, allowing a depleted pack to be replaced rather than stopping the entire tool for charging.[2][4]
Is the WOLFBOX MF200 quieter than XPOWER?
No direct numerical conclusion can be made from the available testing. MotorTrend measured the WOLFBOX MF200 at 81.2 dB, but the XPOWER models do not have directly comparable independent measurements taken under the same conditions.[4]
When does the corded XPOWER A-2 make more sense?
The XPOWER A-2 makes more sense for long, repeated cleaning at a fixed workstation. The WOLFBOX MF100 and WOLFBOX MF200 offer much greater portability, while the corded XPOWER can continue running without waiting for a battery.[1][2][8]
[1] WOLFBOX, “Best Electric Air Duster for a Gaming PC in 2026: MF100 vs MF200” https://wolfbox.com/blogs/air-duster/best-electric-air-duster-for-a-gaming-pc-in-2026-mf100-vs-mf200
[2] WOLFBOX, “WOLFBOX MF200 Compressed Air Duster” https://wolfbox.com/products/compressed-air-duster-mf200
[3] Gough's Tech Zone, “Generic Air Duster vs WOLFBOX Super Power Turbofan MF100 & MF200” https://goughlui.com/2026/05/22/quick-review-generic-air-duster-vs-wolfbox-super-power-turbofan-mf100-mf200/
[4] MotorTrend, “Best Air Blowers of 2026, Tested” https://www.motortrend.com/gear-reviews/best-air-blowers-2026-tested
[5] Popular Science, “This Rechargeable Wolfbox Air Duster Is the Most Surprisingly Useful Gadget I Didn't Know I Needed” https://www.popsci.com/gear/wolfbox-compressed-air-blower-review/
[6] Wccftech, “Keep Your Favorite Consumer Electronics Free of Dust With the WOLFBOX MF200 Portable Air Duster” https://wccftech.com/wolfbox-mf200-portable-air-duster-long-battery-life-multiple-attachments-for-85-45-on-amazon/
[7] JB Tools, “XPOWER A-2B Cyber Duster Cordless Multi-Use Rechargeable Air Duster Blower” https://www.jbtools.com/xpower-a-2b-cyber-duster-cordless-multi-use-rechargeable-air-blower-a-2b-black/
[8] GarageSpot, “XPOWER Airrow Portable Electric Duster, Blower, and Inflator” https://garagespot.com/xpower-airrow-portable-electric-duster-blower-inflator/
Best Air Duster for TVs and Home Theater
Best Air Duster for HVAC Vents and Furnace Filters Before Heating Season
