The useful question is not whether Wolfbox or NOCO is the bigger name. It is whether the jump starter matches the vehicle, the battery problem, and the extra gear you actually carry.
If you drive a compact gas car and only want a small emergency booster, the NOCO GBX45-style category can make sense. If you drive a diesel pickup, a large gas SUV, a work truck, or you want one device that can also charge a laptop at a campsite, the Wolfbox MegaVolt24 is the more practical fit because Wolfbox rates it for larger engines and gives it 65W USB-C Power Delivery.[1]
The Decision in One Sentence
Choose MegaVolt24 when the jump starter needs to cover larger engines or double as road-trip power. Choose a smaller compact booster only when storage size and simple emergency use matter more than engine headroom, USB-C output, or off-grid flexibility.
That framing matters because many buyers compare peak amps first. Peak current is useful, but it is not the whole buying decision. A jump starter that looks powerful on paper can still be the wrong match if the vehicle, storage habits, or charging needs do not line up.
Quick Comparison
Wolfbox MegaVolt24 |
NOCO GBX45 |
Peak current |
4,000A |
Lower published peak class |
Rated engine coverage |
Up to 10.0L gas / 10.0L diesel |
Better suited to smaller gas and diesel engines |
Battery capacity |
24,000 mAh / 88.8 Wh |
Smaller portable jump-starter class |
USB-C output |
65W USB-C PD |
Not the reason to choose this model |
Good fit |
Trucks, diesel vehicles, road trips, camping, laptop charging |
Compact carry and simpler emergency use |
Peak-current numbers are useful for comparison, but they do not replace vehicle fit. Cold-start performance depends on battery condition, temperature, engine size, cable connection, and how long the vehicle has been sitting. SAE J537 defines cold-cranking-amp testing for lead-acid batteries, but many portable lithium jump starters market peak output rather than CCA.[2]
When MegaVolt24 Makes More Sense
Choose MegaVolt24 if you drive a full-size truck, a diesel vehicle, a large gas SUV, or any vehicle where the starter battery is harder to recover in cold weather. Wolfbox lists MegaVolt24 for gas and diesel engines up to 10.0L, which makes it a better match for heavy-duty pickups and large-displacement vehicles than a compact jump starter.[1]
It is also more useful if you want the jump starter to double as a power bank. The 65W USB-C PD output can support many laptops, tablets, and higher-draw USB-C devices, so the unit is not only a dead-battery tool. For camping, roadside work, and long drives, that matters more than a spec sheet suggests.
The most common MegaVolt24 buyer is not someone who jumps cars every week. It is someone who does not want to carry separate devices: one booster for the truck, one USB-C power bank for a laptop, and one emergency battery for a road trip. MegaVolt24 combines those jobs better than a basic compact booster.
Where NOCO GBX45 Still Has a Place
NOCO’s advantage is simplicity and compactness. If the vehicle is a small gas car, a crossover, or a light-duty vehicle with modest starting needs, a smaller jump starter can be easier to store and easier to hand to another driver in an emergency. Some buyers also prefer NOCO because they already know the brand.
That does not make it the better choice for every vehicle. It means the buyer should match the unit to engine size and use case instead of treating every lithium jump starter as interchangeable.
Where MegaVolt24 Can Be Overkill
MegaVolt24 is not automatically the right purchase for every driver. If you own a small commuter car, rarely leave town, and already carry a separate power bank, the extra capacity may sit unused. A larger jump starter also takes more space and needs the same battery-care habits as any lithium device.
That is the honest trade-off: MegaVolt24 gives more room for larger vehicles and more uses outside jump starting, but that only matters if you will actually use those capabilities.
Battery Life and Storage
Any lithium-based jump starter ages faster when stored fully charged in a hot vehicle for long periods. Battery University recommends avoiding sustained high heat and extreme charge states for lithium batteries.[3] In practice, that means checking charge before road trips, storing the unit somewhere cooler when possible, and not treating the trunk as a permanent summer storage spot.
Wolfbox’s value case is stronger if you expect the jump starter to be part of a broader road-trip kit: jump starting, phone charging, laptop charging, and emergency backup power. For a glovebox-only emergency device, a smaller model may be enough.
What to Check Before Buying
Before choosing either unit, check three things. First, match the jump starter to the largest engine you expect it to start, not just the car you drive every day. Second, decide whether USB-C output is a real need or just a nice extra. Third, think about storage: a jump starter only helps if it is charged, reachable, and not degraded from months of hot storage.
Who Should Buy Which?
Driver situation |
Better fit |
Why |
Diesel pickup or HD truck |
Rated for larger gas and diesel engines |
Large gas SUV or V8 truck |
More headroom for higher starting demand |
Laptop charging on road trips |
65W USB-C PD output |
Compact car emergency kit |
Smaller jump starter may be enough |
Lower starting demand and easier storage |
Buyer who wants the simplest unit |
NOCO-style compact model |
Fewer power-bank features to manage |
Power and storage checks
- A lithium jump starter should be charged and checked before use; Clore’s lithium jump-starter guidance treats state of charge as a practical reliability factor.[4]
- USB-C laptop charging is only useful if the wattage matches the device, so USB-IF Power Delivery context matters when comparing a booster with a regular power bank.[5]
- AAA notes that heat is hard on vehicle batteries, which supports the article’s advice to think about summer storage and maintenance habits.[6]
- For lithium battery safety, CPSC guidance supports avoiding overheating and using proper charging and storage habits.[7]
Is Wolfbox MegaVolt24 better than NOCO GBX45 for diesel trucks?
For large diesel pickups, MegaVolt24 is the better match because Wolfbox rates it for diesel engines up to 10.0L.
Does MegaVolt24 charge laptops?
Yes. MegaVolt24 includes 65W USB-C Power Delivery, which can charge many USB-C laptops and tablets.
Are peak amps the only number that matters?
No. Engine size, battery condition, temperature, cable connection, and rated vehicle coverage all matter.
Can I leave a lithium jump starter in the car all summer?
It is better not to use a hot trunk as permanent storage. High heat speeds lithium battery aging.
Who should choose a smaller jump starter instead?
Drivers of compact gas cars who only want a basic emergency tool may prefer a smaller, simpler model.
[1] Wolfbox MegaVolt24 product page — https://wolfbox.com/products/wolfbox-megavolt24-jump-starter
[2] SAE J537 Battery Standard — https://www.sae.org/standards/content/j537_201906/
[3] Battery University: How to Prolong Lithium-based Batteries — https://batteryuniversity.com/article/bu-808-how-to-prolong-lithium-based-batteries
[4] Clore Automotive: Lithium Jump Starters Usage Tips — https://cloreautomotive.com/lithium-jump-starters-safe-smart-and-effective-usage-tips/
[5] USB-IF: USB Charger/Power Delivery — https://www.usb.org/usb-charger-pd
[6] AAA: How to Prevent Heat Damage to Your Car Battery — https://mwg.aaa.com/via/car/prevent-heat-damage-car-battery
[7] CPSC: Lithium-Ion Battery Safety — https://www.cpsc.gov/Safety-Education/Safety-Education-Centers/Fire-Safety-Information-Center/Lithium-Ion-Battery-Safety
