A dead battery is already inconvenient in a small car, but it’s downright problematic in a full-size truck. A larger engine means higher electrical demands and much greater pressure on a jump starter. Therefore, not just any old unit will do. You need something with a bit of grunt.
In this guide, we’ll dive into the ideal requirements for a jump starter, why trucks need something a little more powerful than most, and the best products for the job.
What Makes a Jump Starter Compatible with a Full-Size Truck?
Several factors determine whether a jump starter can jump-start a full-size truck.
Starting Power
Starting power is a great place to start when choosing the best jump starter for your full-size truck. At a minimum, it needs to have adequate peak amps and starting/cranking amps.
Peak amps measure the ‘burst’ of power a jump starter can provide in milliseconds, while the cranking amps describe the continuous power the unit supplies to turn over the engine.
Larger engines require more starting power because they have higher resistance, larger displacement with more and larger cylinders, and higher compression ratios for a starter motor to overcome to rotate. These factors mean a jump starter must have enough power, or it won’t start the engine.
That’s why many people choose to store a WOLFBOX MegaVolt24 in their full-size truck. With a peak current of 4000A, it delivers an effortless start for all 10L/12V vehicles.[1]
Battery Capacity
Battery capacity is as important as starting power, so it's a key consideration when choosing the best jump starter for your truck. For example, when a truck battery is deeply discharged, you may need to jump-start it more than once until the engine roars to life. When a jump starter has minimal battery capacity, this may not be possible.
You may also use your jump starter as a portable power bank, but it can only do double duty if it has larger-than-average capacity. Rest assured, the WOLFBOX MegaVolt24 has a 24,000 mAh capacity. This means its internal battery stores enough energy to supply 24,000 milliamperes of current for an hour or smaller amounts for longer. As a result, the WOLFBOX MegaVolt24 can easily revive 12-volt vehicles under 10L up to 40 times on a single charge.[2]
Gas and Diesel Engine Compatibility
You can’t just assume that every jump starter will work with every engine size and type. Confirm that the product you intend to buy is gas and diesel-compatible. The WOLFBOX MegaVolt24 works with both gas and diesel vehicles, and can jump-start 12V petrol and diesel engines up to 10L. Its 4000A peak current suits cars, SUVs, trucks, and boats. It’ll even start your lawn mower.[1]
Safety Protection
A lot can go wrong when jump-starting a full-size truck, such as voltage spikes, reversed polarity, overheating, and even battery explosions. So, any jump starter you buy for your truck should have safety features.
The WOLFBOX MegaVolt 24 boasts a number of safety measures for truck owners’ peace of mind, including:[1]
- Reverse charge protection
- Reverse polarity
- Aluminum software protection
- Overcurrent protection
- Temperature protection
- Overload protection
- Overvoltage protection
- Short circuit protection
- FCC certification
Why Full-Size Trucks Need More from a Jump Starter
Sure, you could buy a jump starter based only on cost, but most full-size trucks need more than what entry-level models provide.
Larger Engines
A larger engine calls for more startup power. Whether you own an F-Series Ford, a GMC Sierra, a Toyota Tundra, a Ram, or another full-size pickup truck, you’ll know that it has a larger engine than your average car. The more startup power a jump starter has, the more likely it is to jump-start a full-size truck.
With a peak current of 4000A, the WOLFBOX MegaVolt 24 is a standby solution for every 10L/12V vehicle.[3]
Isolated Locations
Most people aren’t simply commuting or shopping in their pickup trucks; they’re also using them for farming, construction, hunting, off-roading, long-distance towing, and more. It’s not uncommon for drivers to end up in isolated, remote locations, with assistance hours away if they ever need it. Rather than waiting for help to arrive if their battery goes flat, they can invest in a truck-compatible jump starter that functions as the independent backup they need.
Demanding Diesel Engines
Because diesel engines operate under higher internal pressures, temperatures, and heavy load requirements, they are typically more demanding than petrol/gasoline engines. Therefore, a jump starter that works perfectly for a small gasoline engine isn’t automatically the right fit for a heavy-duty diesel pickup truck.
The WOLFBOX MegaVolt 24 is a suitable jump-starting solution for a variety of engine types, whether you have a demanding 3L Ram or a 400cc lawn mower.[4]
WOLFBOX MegaVolt24: A Convenient Glove Compartment Addition to Your Pickup Truck
If the worst happens and you’re in the middle of nowhere with a flat battery, the WOLFBOX MegaVolt24 is the saving grace tucked away in your glove compartment. It meets the demands of your full-size truck and is a handy addition to the garden shed for your ride-on lawn mower.
Real 4000A Peak Starting Power
You’ll never be kept waiting with the WOLFBOX MegaVolt24, as it effortlessly starts 10L/12V vehicles with a peak current of 4000A.[5] This high peak power rating gives the jump starter the initial surge it needs to break through the resistance of a dead battery.
Diesel and Gasoline Engine Compatibility
Whether your full-size truck runs on gasoline or diesel, the WOLFBOX MegaVolt24 will confidently jump-start the engine up to 10 liters, whether you have an off-road machine, a small commercial truck, your prized boat, or another vehicle.[6]
24,000 mAh Capacity
When you want jump-starting reliability again and again and again, the WOLFBOX MegaVolt24 has you covered with its 24,000 mAh capacity. This 12V portable jump starter can start a car approximately 40 times on a single charge.
Portable for a Truck Emergency Kit
You can’t carry around a fuel bowser, but you can certainly carry around the WOLFBOX MegaVolt24. This compact device comes in a durable EVA storage bag with:
- 65W USBC wall charger
- USB-C to USB-C cable
- Heavy-duty precision battery clamps
- User manual
It’s small, lightweight, and comfortably fits in an average glove compartment with room to spare.
WOLFBOX MegaVolt24 Specifications At a Glance
If you need to know what you’re working with, review the WOLFBOX MegaVolt24 specifications below.
Specification |
MegaVolt24 |
Peak power |
4000A |
Engine rating |
10L diesel and gasoline |
Battery capacity |
24,000 mAh |
Operating temperature |
Down to -4°F and up to approximately 140°F |
Warranty |
30 months |
Additional features |
IP64 waterproofing, LED screen, 10-point safety system, and 200+ lumen LED flashlight with SOS, strobe, and high-beam modes |
When to Use a Jump Starter As a Truck Owner
It’s natural to question whether you need any car accessory, but many situations call for a jump starter as a truck owner.
You’ve Left Accessories Running
It’s easier than you think for a battery to run flat after you leave accessories, electronics, or lights on while the engine is off. If you turn the key and nothing happens, it’s time to haul your jump starter out of storage.
It’s Cold
Like us, engines can struggle to start when the mercury plummets. A jump starter can help your truck get going. However, a jump starter isn't suitable if a battery is completely frozen from being out in freezing temperatures. Applying a high current to a frozen battery can cause it to crack or explode.
You Work in a Remote Location
If you’re a contractor, farmer, camper, hunter, outdoor worker, or off-road driver, you’ll likely be where the masses aren’t. A jump starter offers peace of mind when you’re isolated or off the beaten track.
How to Use a Jump Starter On a Full-Size Truck
It’s easier than you think to use a jump starter on your full-size truck to bring its battery back to life:
- Make sure the vehicle and all unnecessary electronic accessories are turned off.
- Plug the precision battery clamp singular end into the WOLFBOX MegaVolt24.
- Clamp the negative clamp onto the battery terminal, followed by the positive clamp.
- Turn your vehicle on.
- Remove the clamps in the same order you attached them.
Always follow the instructions in the WOLFBOX MegaVolt24 user manual.
What to Look for Before Buying a Truck Jump Starter
Here is a helpful checklist to help you choose the best jump starter for your needs as a truck driver.
- Engine compatibility
- Peak and starting current
- Gas and diesel compatibility
- Cable and clamp quality
- Safety protections
- Operating temperature range
- Portability
- Warranty
1. Is the WOLFBOX MegaVolt24 the best jump starter for a full-size truck?
The WOLFBOX MegaVolt24 is an excellent option for jump-starting a full-size truck, with a 24,000 mAh battery capacity and 4000A.
2. Can a portable jump starter start a diesel truck?
Yes. A portable jump starter such as the WOLFBOX MegaVolt24 can start a diesel truck or a gasoline truck up to 10L.
3. Can I keep a jump starter in my truck?
Yes. You can keep a jump starter in your truck, as long as the internal temperature stays within that model’s operating range. The MegaVolt24 Jump Starter can be stored between -4° - 140°F. [10]
4. Will a jump starter start a lawn mower?
Yes. While not all jump starters will, the WOLFBOX MegaVolt24 can start cars, trucks, boats, lawn mowers, and other vehicles up to 10L/12V.
5. How many amps should a jump starter have for a truck?
The output depends on your truck’s engine type, battery condition, displacement, temperature, and other factors. However, the WOLFBOX MegaVolt24 confidently starts trucks with 4000A.
- WOLFBOX MegaVolt24 Jump Starter – https://wolfbox.com/products/wolfbox-megavolt24-jump-starter
- WOLFBOX MegaVolt24 – YouTube Video https://www.youtube.com/watch?v=zMWO0ktMZzg&feature=youtu.be
- BuzzFeed – Father’s Day Gift Guide https://www.buzzfeed.com/samar_hadri/wonderful-fathers-day-gifts-deserves#138693377
- Sunset – Road Trip Essentials https://sunset.com/travel/road-trips/road-trip-essentials
- MySA – WOLFBOX Car Jump Starter Deal https://www.mysanantonio.com/shopping/article/wolfbox-car-jump-starter-deal-20825751.php
- SlashGear – Jump Starter Brands Ranked https://www.slashgear.com/1944212/jump-starter-brands-ranked-worst-best/
