Cold mornings can be harder on a GM full-size pickup than warm summer days. Lower temperatures make engine oil thicker, so a battery that started a 5.3L V8 without trouble in July may struggle on an early October morning. Fall trips can also take trucks farther from busy roads, where getting help from another vehicle is not always easy.
That is where the WOLFBOX MegaVolt24 can come in handy. It delivers up to 4000A of peak current and works with gasoline and diesel engines up to 10L, so it covers the main Silverado and Sierra engine options, from the 2.7L turbo to the 6.6L Duramax [1].
How Much Starting Power Do GM Trucks Need?
The exact amount depends on the engine and battery fitted to the truck. GM's original battery specifications help show what each model is designed to use.
On the 2019-2022 Silverado 1500 and Sierra 1500, the 5.3L V8 uses a 720 CCA battery. Models with stop/start, including the 2.7L, 5.3L and 6.2L engines, use a 730 CCA AGM battery [4].
CCA, or cold cranking amps, measures how much current a 12V battery can provide at 0°F for 30 seconds while maintaining at least 7.2 volts [2]. In simple terms, it helps show how well a battery can handle a cold start.
The larger GM trucks have similar ratings. The 6.6L L5P Duramax diesel in the Silverado 2500 HD and 3500 HD uses a 730 CCA battery, while the 6.6L L8T gasoline V8 is rated at 720 CCA [4]. The 3.0L Duramax in the Silverado 1500 has the highest rating of the group, at 850 CCA and 95 Ah [4].
Battery requirements also change with engine size and temperature. Our sizing guide places 4.0-6.2L gasoline V8 engines in the 650-800 CCA range, while 6.0-10L diesel engines may need 900-1,200 CCA or more. In climates that regularly fall below 0°F, we recommend allowing an extra 20-30% of capacity [2].
Peak Amps vs. CCA: What's the Difference?
Peak amps and CCA are often mentioned together, but they do not measure the same thing.
The 4000A figure on the MegaVolt24 refers to peak current, or the short burst of power the unit can deliver when the engine needs to crank. There is no single standardized test used to measure peak amps [2].
CCA works differently. Cold cranking amps are measured under the SAE J537 standard, using a fixed temperature and test duration [2]. That makes CCA more useful when you want to compare the cold-start performance of different batteries.
So, a 4000A peak rating should not be read as the equivalent of 4000 CCA. Think of it instead as the amount of starting power the jump starter has available for short periods.
For a full-size gasoline truck, WOLFBOX recommends around 800 to 1000 peak amps or more. Heavy-duty diesel engines can need between 1500 and 4000 peak amps [3]. The MegaVolt24 sits at the top of that range with its 4000A rating [1].
In practical terms, that gives a Silverado 1500 with a 5.3L V8 plenty of room. A 6.6L Duramax asks more from a jump starter, but it is still within the range the MegaVolt24 is rated to handle [1][3].
Why Cold Weather Is Hard for Truck Batteries?
Cold weather can quickly expose a weak battery. At 0°F, a battery may lose around 60% of its power compared with normal conditions [3]. At the same time, colder temperatures make engine oil thicker, so the engine can need up to twice as much cranking current to start [3].
For a GM V8, that combination can make a big difference on a cold morning. If the battery is already weak, there may not be enough power left to turn the engine over properly.
The MegaVolt24 is designed to operate between -4°F and 140°F, so it can be used through fall and into winter in most parts of the United States [1].
Cold temperatures also affect the lithium battery inside the jump starter. Below 0°F, lithium cells can provide less usable capacity [2]. If very low temperatures are expected, keeping the MegaVolt24 inside the cab or bringing it indoors overnight can help preserve more of its charge for the next start.
How Much Can the MegaVolt24 Do on One Charge?
The MegaVolt24 uses a 24,000 mAh, 88.8 Wh lithium battery and is rated for up to 40 jump starts on a single charge [1][8]. In independent testing, TechGearLab measured 82.3 Wh of usable capacity. It also started a completely drained 2010 Ford Explorer three times in a row, using about 3% of the battery for each start [5].
It is also compact enough to keep inside the truck. TechGearLab measured it at 3.2 lb and 9.3 x 3.9 x 1.5 inches [5]. That makes it easy to store in a center console, door pocket or other small compartment. A 3.8-inch LED screen shows the remaining charge and current status [8].
The MegaVolt24 can also be used as a power bank. Pro Tool Reviews measured 65W output from the USB-C port and 10W from the USB-A port. In its test, a phone reached 90% charge in as little as 30 minutes [6]. The USB-C port also supports 65W PD input, allowing the MegaVolt24 to recharge in about 1.5 hours [1][5].
For added protection, the MegaVolt24 has an IP64 rating, which helps protect it from dust and water splashes [6]. It also includes 10 safety protections, including reverse polarity, over-current, short-circuit and over-temperature protection [7].
A built-in LED flashlight is also available for roadside use at night, with steady, strobe and SOS modes [1].
How to Jump-Start a Silverado with the MegaVolt24?
Using the MegaVolt24 on a Silverado follows the same basic steps as on any other 12V vehicle. Connect the red clamp to the positive battery terminal, then attach the black clamp to an unpainted metal ground, such as the engine block [7].
Turn on the MegaVolt24 and wait about 2 to 3 minutes before trying to start the engine [7]. If the engine does not start on the first attempt, wait another 5 minutes before trying again. A deeply discharged battery may need 10 to 15 minutes before it has enough charge to crank [7].
Once the engine starts, disconnect the clamps in reverse order. Remove the black clamp first, then the red one, ideally within about 30 seconds [7].
WOLFBOX MegaVolt24 Specifications
Specification |
WOLFBOX MegaVolt24 |
Peak current |
4000A |
Battery capacity |
24,000 mAh / 88.8 Wh |
Engine compatibility |
Gas engines up to 10L, diesel engines up to 10L |
Jump starts per charge |
Up to 40 |
Measured capacity |
82.3 Wh (TechGearLab) |
USB-C |
65W input and output |
USB-A |
10W output |
Display |
3.8-inch LED screen |
Flashlight |
Steady, strobe and SOS modes |
Water and dust resistance |
IP64 |
Safety features |
10 protection systems |
Operating temperature |
-4°F to 140°F |
Recharge time |
About 1.5 hours with 65W PD |
Weight |
3.2 lb |
Dimensions |
9.3 x 3.9 x 1.5 in |
Warranty |
30 months |
Source: WOLFBOX MegaVolt24 official product page and jump starter collection [1][8]. Capacity, weight and dimensions were measured independently by TechGearLab [5].
When You May Need a Different Option
The MegaVolt24 is designed mainly as a jump starter, so it does not include a tire inflator. If you want one device that can handle both a dead battery and a low tire, this may be a limitation. TechGearLab also pointed to the lack of a compressor as one of the main drawbacks of the MegaVolt24 [5].
For that type of use, the MegaVolt 24Air may be a better fit. It offers the same 4000A peak current and 24,000 mAh battery, but also includes a 160 PSI, 45 L/min air compressor and a 400-lumen light [9].
The clamps are another detail to consider. TechGearLab found that the copper teeth grip well, but the larger clamp design can be harder to position in tight engine bays [5]. This may be more noticeable on heavy-duty trucks with limited space around the battery.
Storage also deserves some attention. TechGearLab noted that the power button can sometimes be pressed accidentally during transport, which may slowly drain the battery over time [5]. Checking the charge level every few months can help make sure the MegaVolt24 is ready when you need it.
Who Is the MegaVolt24 Best For?
The MegaVolt24 can be a useful choice for several types of GM truck owners:
- Silverado 1500 and Sierra 1500 owners with the 5.3L or 6.2L V8. These trucks use batteries rated around 720 to 730 CCA, while the MegaVolt24 provides up to 4000A of peak current [1][4].
- Drivers with the 3.0L or 6.6L Duramax diesel. These engines need more power to crank than most gasoline engines. WOLFBOX places heavy-duty diesels in the 1500 to 4000 peak amp range, and the MegaVolt24 reaches 4000A [3].
- Drivers who keep their truck outside in colder months. The MegaVolt24 can operate from -4°F to 140°F and carries an IP64 rating, so dust and occasional water splashes are not a problem [1][6]. If temperatures drop well below freezing, though, it is worth bringing the unit indoors overnight. Lithium batteries can lose some usable capacity in extreme cold [2].
- Drivers who only need a jump starter. The MegaVolt24 does not include a tire inflator. If you want both functions in one device, the MegaVolt 24Air adds a 160 PSI, 45 L/min compressor while keeping the same 4000A peak output [5][9].
Will the WOLFBOX MegaVolt24 start a 6.6L Duramax?
Yes. The 6.6L Duramax falls within the MegaVolt24's 10L diesel limit [1]. It is a demanding engine to crank, especially in colder weather, but the MegaVolt24 offers up to 4000A of peak current. That matches the upper end of the 1500 to 4000 peak amp range recommended for heavy-duty diesel engines [3]. For reference, the 6.6L L5P Duramax uses a 730 CCA battery from the factory [4].
How many times can the MegaVolt24 start a Silverado on one charge?
WOLFBOX rates it for up to 40 jump starts per charge [1][8]. Real-world use will vary depending on the battery and engine, of course. In TechGearLab testing, three starts of a fully drained vehicle used about 3% of the battery each time [5].
Is 4000A too much for a Silverado 1500?
No. The Silverado will only draw the current it actually needs [3]. The 4000A figure simply gives the jump starter more reserve power when the battery is weak or the engine is harder to crank. The MegaVolt24 also includes protection against problems such as reverse polarity and over-current [7].
Can I leave the MegaVolt24 in my truck during fall and winter?
You can, but very low temperatures can reduce the usable capacity of lithium batteries. The MegaVolt24 has an operating range of -4°F to 140°F [1], although performance can drop below 0°F [2]. If the truck is going to sit outside during a hard freeze, bringing the jump starter indoors is a better option. It is also worth checking the charge every few months [5].
Does the WOLFBOX MegaVolt24 inflate tires?
No. There is no built-in compressor, so the MegaVolt24 is mainly a jump starter and power bank [5]. If you want a unit that can also handle a low tire, the MegaVolt 24Air adds a 160 PSI, 45 L/min compressor [9].
How long does the MegaVolt24 take to recharge?
With a 65W PD charger, a full recharge takes about 1.5 hours through the USB-C port [1][5]. That same port can also provide up to 65W of output for compatible devices [6].
[1] WOLFBOX MegaVolt24 4000A Jump Starter - Official Product Page: https://wolfbox.com/products/wolfbox-megavolt24-jump-starter
[2] WOLFBOX - Jump Starter Buying Guide: Peak Amps vs CCA, Lithium vs Lead-Acid, and How to Size the Right Unit: https://wolfbox.com/blogs/jump-starter/jump-starter-buying-guide-peak-amps-vs-cca-lithium-vs-lead-acid-and-how-to-size-the-right-unit
[3] WOLFBOX - How Many Amps to Jump Start a Car: Choose the Right Jump Starter: https://wolfbox.com/blogs/jump-starter/how-many-amps-to-jump-start-a-car
[4] GM TechLink - GM Original Equipment Battery Ratings 2019-2022: https://gm-techlink.com/wp-content/uploads/2021/06/TechLink-Battery-Ratings-2019-2022-062021A.pdf
[5] TechGearLab - WOLFBOX MegaVolt24 Review: https://www.techgearlab.com/reviews/tools/jump-starter/wolfbox-megavolt24
[6] Pro Tool Reviews - Wolfbox MegaVolt 24 Jump Starter Review: https://www.protoolreviews.com/wolfbox-megavolt-24-jumpstarter-review/
[7] WOLFBOX - How to Use a Jump Starter: A Step-by-Step Guide: https://wolfbox.com/blogs/news/how-to-use-a-jump-starter-a-step-by-step-guide
[8] WOLFBOX - Jump Starter Collection: https://wolfbox.com/collections/jump-starter-1
[9] WOLFBOX MegaVolt 24Air 4-in-1 Jump Starter with Air Compressor & Tire Inflator - Official Product Page: https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
