Best Jump Starter With Air Compressor for Fall Camping and Trailers
Fall camping brings some well-needed change after a long and hot summer, but the seasonal shift also introduces some operational issues for those who are into overlanding. As the temperatures drop, the 12V battery becomes less efficient, and tire pressures begin to drop more. While these are issues, there is a solution.
Jump starters with air compressors are considered a powerful tool to have with you on the trail. A dead battery or a deflated tire is something you don’t want to have, so getting one before your trip is a wise choice.
In today’s article, we’ll help you choose which is the best jump starter with an air compressor for you and your autumn adventure.
Quick Overview of The Best Jump Starter With Air Compressor for Fall Camping and Trailers
Jump starters with air compressors come in all shapes and sizes, so let's go over the one we chose for today briefly to get an idea of what you’re getting.
WOLFBOX MegaVolt 24 Air
WOLFBOX MegaVolt 16 Air
LOKITHOR JA302
DeWalt DXAEJ14
JF.EGWO 4000A
Peak Current
4,000A
3,000A
2,500A
1,600A
4,000A
Max PSI
160 PSI
160 PSI
150 PSI
120 PSI
150 PSI
Engine Capability
Up to 10.0L gas and diesel
Up to 8.0L gas and 6.0L diesel
Up to 8.5L gas and 6.5L diesel
Up to 8.0L gas
Battery Specs
24,000 mAh / 88.8Wh
16,000 mAh / 59.2Wh
76Wh / ~23,800 mAh
~19 Ah
28,000 mAh / 103.6Wh
Standout Advantage
65W bidirectional USB-C and fast tire inflation
Full 160 PSI compressor in a compact package
Low-vibration turbo motor and excellent gauge accuracy
Onboard alternator tester and rugged build
Extended reach air hose and dual charging
The WOLFBOX MegaVolt 24 Air is built specifically for heavy-duty vehicle recovery, remote expeditions, or demanding trailer setups. It can deliver 4,000A peak current from a 24,000 mAh lithium battery pack, meaning it’s rated to crank gasoline and diesel engines up to 10.0 liters. This capability can easily turn high-displacement engines on tow rigs even in sub-freezing temperatures. [1]
The area where the WOLFBOX MegaVolt 24 Air excels for trailer owners is the integrated 160 PSI air compressor. It’s capable of delivering up to 45 liters of air per minute, meaning it can inflate high-pressure trailer or truck tires with ease. The incorporated bidirectional USB-C allows you to use it for recharging other electronics. As part of the package, you’re also getting an LED work light for when you need to use it in the dark. [1]
Pros
  • 4,000A peak output
  • Built-in 160 PSI air compressor
  • Bidirectional USB-C
Cons
  • Not the most competitively priced
The WOLFBOX MegaVolt 16 Air is a compact and streamlined version of the previous model, offering balanced recovery power for mid-size tow vehicles, SUVs, and smaller trailers. It provides 3,000A of peak cranking power and is backed by a 16,000mAh lithium battery. It’s rated for gasoline engines up to 8.0 liters and diesel engines up to 6.0 liters. The smaller battery and overall dimensions mean it’s a model that won’t sacrifice a ton of cargo room. [2]
Even though the WOLFBOX MegaVolt 16 Air is a smaller model, it’s equipped with the same air compressors as the larger one, meaning you’re looking at 160 PSI at an airflow rate of 45 liters per minute. The built-in screen shows you real-time pressure readings, meaning it eliminates any guesswork. It also features a bidirectional USB-C port as well as an LED work light, making it a compact and capable companion on the trails.[2]
Pros
  • Compact and capable jump starter
  • 160 PSI air compressor capable of delivering 45 L/min of airflow
  • Bidirectional USB-C to charge additional electronics
Cons
  • The smaller size means it can provide fewer starts or tire inflations
LOKITHOR JA302
The LOKITHOR JA302 takes a different approach, offering 2,500A of peak starting power driven by a 76Wh lithium polymer battery. It’s rated to be capable of cranking gasoline engines of up to 8.5 liters and diesel engines of up to 6.5 liters. Housed in a rugged casing, this model also features an advanced battery management system that protects against reverse polarity, short circuits, and thermal spikes.
LOKITHOR equipped the JA302 with a 150 PSI integrated air compressor capable of delivering airflow of 35 liters per minute, powered by a turbocharged motor designed to minimize operating vibration and noise. The digital system detects pressure levels in the tires and automatically stops as soon as it reaches the preset pressure. Like the previous two models, it features an LED flashlight for working in darker scenarios.
Pros
  • Turbocharged motor design to minimize noise and vibrations
  • Precise digital tire gauge that shuts off automatically
  • Excellent standby battery retention
Cons
  • It doesn’t recharge as fast as some of its rivals
DeWalt DXAEJ14
Campers and trailer operators who favor heavy-duty commercial equipment over consumer models will find the DeWalt DXAEJ14 an excellent choice for their needs. It’s a proven recovery station that operates on a sealed lead-acid (SLA) battery capable of delivering 1,600A peak battery / 700A instant starting current. This kind of setup does well on anything from a smaller inline-4 engine all the way up to a big displacement V8. [3]
The built-in air compressor on the DXAEJ14 features DeWalt’s threaded brass Sure Fit nozzle as well as the AUTOSTOP technology. Both of these combined mean fitment won’t be an issue, and you won’t have to worry about hitting the optimal tire pressure. One of the most handy features this model has is the ability to test the charging system. While it won’t eliminate any problems, you’ll at least know if the alternator is working properly.[3]
Pros
  • Heavy-duty industrial housing
  • Integrated alternator tester
  • Threaded brass nozzle for an airtight connection
Cons
  • Noticeably bigger and heavier than most lithium-ion jump packs
JF.EGWO 4000A
The JF.EGWO 4000A is designed specifically for campers who tow heavymulti-axle trailers or toy haulers with big displacement trucks. It’s driven off a high-capacity 28,000mAh battery capable of generating 4,000A of peak current. This heavy-duty output means it should be able to crank any engine up to 10.0 liters. This is true even in colder situations like an autumn overlanding adventure.
The integrated 150 PSI air compressor of the JF.EGWO 4000A offers an airflow of 35 L/min with dual digital readouts, showing target and live pressure. A massive advantage with this model for trailer owners is the extended air hose assembly. Like most in its class, you’re getting LED spotlights to make sure you can see what you’re doing in the dark.
Pros
  • Up to 4,000A cranking power
  • Extended air hose kit
  • Versatile charging options
Cons
  • The compressor can run hot under heavy loads
What is The Best Jump Starter With Air Compressor for Fall Camping and Trailers?
All 5 models on this list are excellent, but they fit different categories and needs:
  • WOLFBOX MegaVolt 24 Air: Best for trailers and tow vehicles, thanks to its excellent starting power and the built-in air compressor, combined with a big battery and bidirectional fast charging
  • WOLFBOX MegaVolt 16 Air: Ideal for SUVs, crossovers, and campers who need something that’s compact but can still offer solid cranking power and comes with an air compressor
  • LOKITHOR JA302: The option you’d go for if you’re often doing overlanding and you need to power multiple devices, thanks to the low idle discharge along with the quiet and low-vibration compressor
  • DeWalt DXAEJ14: Best for utility situations and job sites where you want the traditional AGM reliability, durable construction, and the option to test the charging system on a vehicle [3]
  • JF.EGWO 4000A: The best option for high-displacement fleet or truck recovery, thanks to the excellent cranking capability, multiple charging options, as well as the extended hose kit
Can a portable jump starter compressor inflate trailer tires?
Yes, most jump starters with built-in air compressors should be able to inflate trailer tires. Unlike regular tires, these need to be inflated a lot more, some even reaching 80 PSI. The higher-rated compressors will handle this with no issues.
Does cold autumn weather affect batteries in a jump starter?
Yes, cold weather can affect the batteries in a jump starter. As the temperatures drop, the chemistry inside the battery changes slightly, and the output is reduced. With that said, prominent manufacturers implement features that help minimize this to make the jump starters usable even when it’s colder.
Can a portable jump starter damage my car’s electronics?
No, modern portable jump starters cannot damage your car’s electronics. They’re designed with smart clamps or a system that monitors things in case you switch the clamps. In addition to that, even though they can output a massive amount of current, the vehicle will only get the amount it needs, eliminating any risk to the electronics.
[1] 4-in-1 Jump Starter with Air Compressor Tire Inflator | Exclusive 30-Month Warranty– Wolfbox MegaVolt 24Air https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
[2] WOLFBOX MegaVolt16 Air Portable 4-in-1 Jump Starter with Air Compressor https://wolfbox.com/products/megavolt16-air-portable-all-in-one-air-compressor-with-jumper-starter
[3] MAJOR JUMP STARTER BRANDS RANKED WORST TO BEST https://www.slashgear.com/1944212/jump-starter-brands-ranked-worst-best/
Cold-Morning Tire Check: A Jump Starter With Inflator for the First Fall Chill
WOLFBOX vs Stanley: Jump Starter with Air Compressor Value Compared
