Dash Cam Buying Guide
WOLFBOX G900TriPro Review 2026: Three Cameras, One Mirror, and Whether It's Worth the Price
The WOLFBOX G900TriPro is a three-channel mirror dash cam that records front, rear, and a third camera simultaneously on a 12-inch IPS touchscreen that replaces the rearview mirror. It installs with rubber straps, requires no drilling, and is available in Cabin (interior third camera) and Bumper (exterior bumper-mounted third camera) versions.
What the G900TriPro Is
The front uses a Sony STARVIS 2 IMX678 sensor at 4K UHD (3840×2160, 30fps). The rear records at 2.5K (2560×1440) using an Omnivision OS04J10. The third channel is where the two variants diverge: Cabin adds a 1080P infrared interior camera with four IR illuminators; Bumper adds an IP67-rated 1080P exterior camera positioned near the front bumper.12 Both variants use identical front and rear cameras. Connectivity: 5.8 GHz WiFi, built-in GPS, voice control (12 commands including clip lock and camera switching). Warranty: 18 months. You can also add an optional 1-Year Extended Warranty for even longer protection at wolfbox.com.1
Specification
Detail
Front camera
4K UHD (3840×2160, 30fps) — Sony STARVIS 2 IMX678, 2.9 µm pixels
Rear camera
2.5K (2560×1440, 30fps) — Omnivision OS04J10
Third camera (Cabin)
1080P FHD, 4 IR illuminators, interior only
Third camera (Bumper)
1080P FHD, IP67 waterproof, exterior mount
Display
Field of view
130° front / 150° rear / 131.8° Bumper / 124.4° Cabin
WiFi
5.8 GHz — wireless clip transfer via WOLFBOX app
GPS
Yes — speed + coordinates in every clip
Voice control
Yes — 12 commands
Rubber strap mount, no drilling
Warranty
18 months
Parking mode
G-sensor triggered — requires WOLFBOX Hardwire Kit (sold separately)
Source: WOLFBOX G900TriPro Cabin and Bumper official product pages.12
Installation: The Real Work Is the Third Camera Cable
The mirror unit mounts over the existing rearview mirror with four rubber straps. Rear and third-camera cable routing varies by vehicle, so confirm a safe path around trim and airbags before installation. A hardwire kit is required only when you want parked recording. Follow the WOLFBOX Hardwire Kit installation guide for installation and battery-protection settings.3
Front Camera: 4K Footage Over 60 Days
In daylight, the Sony IMX678's 2.0 µm pixels capture plates at 40+ feet while moving. WDR processing handles high-contrast scenes — direct sun on the road while the sky is overexposed — and keeps the road surface legible. GPS speed and coordinates are embedded in every clip, reviewable in WOLFBOX GPS Player.1 At night on unlit roads, the IMX678 is the most capable front sensor currently in the WOLFBOX lineup. The Gadgeteer confirmed crisp 4K footage with strong low-light performance in hands-on testing.6 Compared to the G840S, the G900TriPro front channel is a genuine upgrade for night footage quality.
Rear Camera: 2.5K in Real Conditions
The 2.5K rear channel handles the primary rear use case without issue in daylight — plates on vehicles following you are readable, and hit-and-run scenarios produce usable footage. At night on unlit roads at speed, plates on a passing vehicle may not always be fully readable. The Gadgeteer described rear nighttime performance as 'OK' — a fair characterization that applies to 2.5K rear sensors broadly in this price range.6 For documenting rear-end collisions and parking incidents, 2.5K rear is adequate.
Third Channel in Practice
The Cabin camera records at 1080P FHD with four IR illuminators — footage of the interior in complete darkness is visible. For rideshare drivers, this documents passenger incidents, in-vehicle altercations, and damage claims. The display toggles between single-channel and three-way split view by swipe or voice command.1 The Cabin camera is interior-only and not waterproof.
The Bumper camera is IP67-rated for exterior conditions. For a full-size pickup where the rear window catches mostly truck bed rather than the road, the Bumper variant's front-bumper view adds coverage the rear camera alone cannot provide.2
Parking Mode: What It Requires
Parking mode needs the WOLFBOX Hardwire Kit. If purchased separately, it typically costs around $30–$40.3 The kit connects via fuse tap to the fuse box with voltage cutoff (default 11.8V) to protect the car battery. No subscription required. G-sensor triggered clips save locally to the SD card.
Who Should Buy Which Version
Buyer Profile
G900TriPro Cabin
G900TriPro Bumper
G900 Pro (2-channel)
Rideshare driver — needs interior evidence
Best fit: IR cabin cam covers passengers
Third cam is at bumper, not inside
No interior coverage
Full-size pickup — bed obstructs rear window
Interior cam useful; rear window still partially blocked
Best fit: bumper cam bypasses bed obstruction
Rear window partially blocked
Family vehicle — monitoring rear seat
Best fit: cabin cam covers rear seat during driving
No interior coverage in this config
Daily driver, sedan, no commercial use
3 channels is more than this use case needs
3 channels is more than needed
Best fit: simpler install, lower cost, same front sensor
Off-road / overlanding — front terrain visibility
Interior cam is lower priority for off-road
Best fit: bumper shows ground ahead
Adequate on-road; no bumper view
The Honest Part
The G900TriPro makes sense when the third channel solves a specific, real problem — interior documentation for rideshare, bed obstruction bypass for a full-size truck, terrain visibility for overlanding. If none of those scenarios apply, the G900 Pro covers front and rear with the same IMX678 sensor at a lower price and a simpler installation. The premium you pay for the G900TriPro is entirely the third camera.
Q: What are the WOLFBOX G900TriPro specs?
A: Front: 4K UHD Sony STARVIS 2 IMX678 (2.0 µm pixels). Rear: 2.5K Omnivision OS04J10. Third channel: 1080P Cabin (IR, interior) or Bumper (IP67, exterior). 12-inch IPS display, 5.8 GHz WiFi, built-in GPS, voice control, rubber strap mount, 18-month warranty.
Q: What is the difference between G900TriPro Cabin and Bumper?
A: Cabin adds a 1080P infrared interior camera for passenger and rear-seat recording. Bumper adds an IP67-rated 1080P exterior camera mounted near the front bumper. Front and rear cameras are identical across both variants.
Q: How long does the G900TriPro take to install?
A: Mirror strap mount: about 20 minutes. Rear camera cable routing: 30–45 minutes. Cabin third camera: 20–30 additional minutes. Bumper version front cable run: 2–3 hours — professional installation is an option.
Q: Does the G900TriPro require a subscription for parking mode?
A: No. Parking mode saves locally to the SD card with G-sensor triggered recording. The WOLFBOX Hardwire Kit (sold separately) is required for continuous power while parked.
Q: What sensor does the G900TriPro front camera use?
A: Sony STARVIS 2 IMX678, recording at 4K UHD (3840×2160) at 30fps. The 2.0 µm pixel size provides strong low-light performance.
Q: Is the G900TriPro Cabin camera waterproof?
A: No. The Cabin interior camera is for interior mounting only and is not waterproof. The Bumper version's third camera is IP67-rated for outdoor conditions.
Q: What is the G900TriPro warranty?
A: 18 months. You can add an extra 12 months of protection to your WOLFBOX product at wolfbox.com.
1. WOLFBOX G900TriPro Cabin Official Product Page: https://wolfbox.com/products/wolfbox-g900tripro-cabin-version-3-channel-dash-camera
2. WOLFBOX G900TriPro Bumper Official Product Page: https://wolfbox.com/products/wolfbox-g900tripro-bumper-version-3-channel-rearview-mirror
3. WOLFBOX Hardwire Kit — Installation Guide: https://wolfbox.com/blogs/news/the-ultimate-guide-to-installing-a-hardwire-kit-for-dashcam-a-step-by-step-tutorial
4. WOLFBOX About Us: https://wolfbox.com/pages/about-us
5. TechRadar — Wolfbox G900 Pro Dash Cam Review:https://www.techradar.com/vehicle-tech/dash-cams/wolfbox-g900-pro-dash-cam-review
6. The Gadgeteer — Wolfbox G900TriPro 3-Channel Mirror Dashcam Review:https://the-gadgeteer.com/2025/05/06/wolfbox-g900-tripro-3-channel-mirror-dashcam-review-this-next-gen-dashcam-sees-all/
7. WOLFBOX Blog — G900TriPro Bumper vs Cabin:https://wolfbox.com/blogs/dash-cams/g900tripro-bumper-vs-cabin-which-three-channel-setup-fits-your-vehicle
8. AutoGuide — Wolfbox G900TriPro Dash Cam Review:https://www.autoguide.com/auto/wolfbox-g900-tripro-dash-cam-review-44623066
Dash Cam for Trucks in 2026: What's Different, What Works, and the Setup That Holds Up
3-Channel Dash Cam Setup Guide: Front, Rear, and Interior — What Each Camera Actually Does
