Where Can I Mount a Car Camera in California? Stay Legal & Secure
If you want to make your car safer and keep track of any incidents, a dash cam can help. You might wonder, "where can I mount a car camera in California?" Understanding the rules ensures your camera stays legal, safe, and effective. Here's what you need to know about the best mounting spots, size limits, and tips for clear, worry-free recordings.
Are Dash Cams Legal in California?
You might wonder if you are allowed to put a camera in your car. The good news is you are permitted as long as you follow certain rules. California sets guidelines to keep your view of the road open and free of distractions.
Lawful Device Usage
California lets you use video recorders in your car. These are especially for safety or to help in case you need to show what happened during an accident.
Specific Size Restrictions
Your dash cam cannot be too large. The law says the camera on the driver's side should fit in a five-inch square and on the passenger's side, a seven-inch square. So, check the size of your camera before you attach it.
Audio Record Rules
If your camera records sound, all people in your car must know about it and agree. This rule helps protect everyone's privacy, so remember to tell anyone who rides with you.
Safe Airbag Deployment
Mounting your dash cam away from areas where airbags are stored keeps you and everyone in your car safer. This way if there is a crash, the camera will not turn into a danger.
For a more complete overview of dash cam regulations, check out our guide Are Dash Cams Legal to see key dash cam laws in each state.
California Vehicle Code and Mounting Requirements
Knowing the law helps you keep your camera in the right place. The California Vehicle Code Section 26708 talks about where can i mount a car camera in California. The goal is to keep your windshield as clear as possible so you can see the road.
Location
Maximum Allowed Size
Condition
Driver's Side Lower Corner
5-inch square
Must not block view
Passenger's Side Lower Corner
7-inch square
Must not block view
Upper Center Windshield
5-inch square
Near rear-view mirror
Primary Legal Mounting Zones on the Windshield
You have some safe and simple choices for your camera's spot. Picking the right location makes driving safer and keeps you from breaking the law. Most cars have three legal zones where you can place your dash cam. No matter what you drive, you can find a place that fits. Pick the area that is easiest for you to reach and see.
Lower Left (Driver's Side) Corner
You can set up your dash cam in the lower left part of your windshield. This is the area closest to the driver and is limited to a five-inch square. This spot is good if you want to quickly check your camera or use the buttons.
Lower Right (Passenger Side) Corner
If you do not want your camera near your main view, you can use the lower right corner. Here you have a bit more space, up to a seven-inch square. It is far from your direct sight line, so it will not distract you as you drive.
Center Upper Windshield Area
This spot is high up, right behind your rearview mirror. You get up to a five-inch square here. It is a smart area if you want the camera to catch a wide view of the road and stay mostly out of sight.
Alternative Mounting Locations
Sometimes, you may want to try a different spot than the windshield. Placing your camera somewhere besides the glass is possible. Many people put their dash cam right on the dashboard or even on the mirror itself. If you use a Wolfbox mirror dash cam, it can clip over your regular mirror or take its place fully. Doing this keeps the windshield totally clear and sticks to dash cam legal in california rules. You still get a great picture without wires or blocks in your way.
Primary Legal Mounting Places for Rear Cameras
Rear cameras are helpful if something happens behind your car. These cameras give you peace of mind when you drive or park. Your camera should never block your view out the back window. With Wolfbox waterproof rear cameras, you get options for inside or outside mounts, ensures reliable recording in all weather conditions. Think about what works best for your car when you set up your system. The right spot helps you catch everything that happens behind you.
Mounting Style
Pros
Cons
Interior Top Center
Safe from weather
Tint can make view darker
Exterior License Plate
Clear view, helps park
Gets dirty more often
Car-Interior Mounting
If you want to mount your rear camera inside, the top center of your back window works well. The camera stays high, does not get dirty, and covers a wide angle. If the middle is blocked, use one of the top corners for a clear shot.
Car-Exterior Mounting
The outside of your car can also work for your rear camera. Placing it near your license plate helps you see what is directly behind. Some cameras sit above the license plate, others fit in a handle or on the tailgate of trucks. This keeps the camera steady and makes it easy to spot cars coming close. Be sure to choose a waterproof camera for exterior mounting to ensure reliable performance in all weather conditions.
Why Placement Matters: Visibility, Safety, and Evidence Quality
Having your camera in the right spot is important for safety and getting good evidence. When your camera is out of the way, you can see the road and avoid any surprises. It also means your camera will have a better view to show what really happened if there is a crash.
Unobstructed Driver Vision
Always keep your camera out of the way of your view. If something blocks your line of sight, it is harder to spot people, pets, or bikes. You want nothing in your way.
Optimal Viewing Angles
A camera in just the right spot on your car helps catch what happens around you. High spots or the center get the full road and make it easier to use the picture for evidence.
Adherence to Safety Standards
The right spot for your dash cam also keeps airbags and safety features working for you. If a camera or wire sits in the wrong place, it could make these systems weaker. Keeping everything tidy helps protect your family and anyone who rides with you.
Best Practices for Dash Cam Installation
You might wonder about the best way to put your dash cam in place. When you take care with setup, everything works better, and your camera stays where you want it. Good installation means wires do not dangle, and the camera will not get in your way. Wolfbox dash cams are easy to set up so you can enjoy a clean dash and clear footage on every trip.
Secure the Mount Firmly
Before you add your camera, clean where you want to stick the mount. This helps it hold tight so the dash cam stays safe, even if the road is rough or bumpy. A solid grip keeps your camera steady.
Hide and Route Cables
Wires are easy to keep out of sight. Tuck them behind your car's trim or up along the roof liner. This keeps your cabin neat and means cables will not distract you or get tangled.
Check Airbag Clearance
When you run your camera's wire, do not cover or cross the spot where the airbag opens. This way, if you ever need your airbag, it works fine, and nothing blocks it.
Test the Camera View
Once you place your dash cam, check the video screen. Make sure it shows the road and not just the hood or dash. Try to get the camera as level as possible for the best view. For more detailed instructions on installing both standard and mirror dash cams, check out How to Install Dash Cam for step-by-step guidance.
You now understand the basics of dash cam laws in california and how to set things up the right way. Your camera will keep you more secure on the road when you follow these simple laws. A Wolfbox dash cam gives you extra security and fits easily within the allowed spaces on your car. You can enjoy peace of mind every time you hit the road. Use these tips and drive with confidence, knowing you are following the law.
Where can I mount a car camera in California?
You can put your camera in a five-inch square in the lower left part of your windshield, a seven-inch square on the passenger side, or a five-inch square in the upper center.
Can I mount my dash cam at the top center of the windshield?
Yes, if the camera fits inside a five-inch square and sits close to the rearview mirror. This keeps it away from your main view but still covers the road.
Can you have a dash cam in california
Yes, you can use a dash cam in your car if you follow the simple laws about placement and privacy. Keep it small and out of your main view for safety.
Do I need to inform passengers about audio recording?
Yes, you must tell everyone in your car if the device records sound. California law says passengers need to know before you record any voices.
