What’s in the Box:
MegaVolt 24Air Host, Smart Battery Clamps, Air Hose,
3x Air Nozzles, C-to-C Fast Charge Cable, EVA Storage Bag, User Manual.
"It was exactly what was represented and easy to use every car should have one. As a female you won't have to rely on strangers for help."
"Gives Me Peace of Mind as a Woman Driver. Perfect little kit to be your own road side assistant if needed."
"Great to Have in Case of Emergencies. Compact and fully functional—quick tire inflation and reliable jump starter make it a fantastic road companion."
"Effortlessly jump-starts my SUV even in freezing weather, plus the built-in air compressor is precise and user-friendly. Small but Powerful and Handy."
"Reliable jump starter that saved me when my battery died—plus a handy tire inflator for trips."
"I charged it by using a 64W usb charger and then placed it in my wife's SUV just in case. We had a dead battery experience before, but we are ready this time if the battery dies again."
Yes, and very fast! The MegaVolt 24Air is equipped with a high-speed USB-C PD (Power Delivery) 65W port. It doesn’t just charge phones; it has enough output to power up your MacBook, iPad, or Dell XPS at near-wall-charger speeds. It’s the perfect companion for road trips, camping, or working from your vehicle.
Press the power button for 2 seconds to turn off or it will auto shut down after 2 minutes of inactivity.
Once fully charged, WOLFBOX MegaVolt24 Air Two-in-One Jumper Starter with Air Compressor can jump starter up to 40 times, depending on your vehicle type and battery condition.
Absolutely. The MegaVolt 24Air delivers a massive 3000A peak current, specifically engineered to tackle heavy-duty engines. Whether you’re driving a Ford F-150, a RAM 2500, or a large diesel SUV, this power bank can jump-start up to 9.0L Gas and 8.0L Diesel engines. Even if your battery is at 0V, our dedicated "BOOST" function will force the power through to get you back on the road in seconds.
Speed is where the MegaVolt 24Air outshines the competition. It can inflate a standard 18-inch tire from 0 to 36 PSI in just about 3 minutes. For a quick top-off (from 30 to 36 PSI), it takes less than 1 minute. Simply preset your desired PSI on the digital screen, and the smart sensor will automatically shut off once it reaches the target, preventing over-inflation while you wait.
The WOLFBOX Megavolt 24 Air supports 65W fast charging. With its 65W USB-C port, 18W USB-A port, and upgraded 160W DC output, it can be fully charged in as fast as 2 hours under optimal conditions.
We know American weather can be brutal. The MegaVolt 24Air uses high-discharge lithium-polymer cells that operate reliably from -4°F to 140°F (-20°C to 60°C). Thanks to its ultra-low self-discharge technology, it can hold its charge for up to 12 months on a single full charge. Toss it in your trunk and forget about it—it’ll be ready when you’re in a pinch.
While devices like AirMoto are great for small tasks, the MegaVolt 24Air is a comprehensive Roadside Emergency Solution. AirMoto is only an inflator. WOLFBOX gives you four essential tools in one: a 3000A Jump Starter (which AirMoto cannot do), a high-speed Tire Inflator, a high-capacity Power Bank (PD 65W fast charging), and a 400-lumen Emergency LED. It’s the difference between having a tool and having a survival kit.
The Wolfbox jump starter with air compressor offers an industry-leading 3.5-year warranty, giving you exceptional reliability and peace of mind.
