WOLFBOX vs NOCO Jump Starter 2026: MegaVolt vs Genius Boost — Which Brand Delivers More Power?
Two brands dominate the portable lithium jump starter conversation in 2026: NOCO, the Ohio-based company that defined the category with its Genius Boost lineup over a decade ago, and WOLFBOX, which entered the jump starter market more recently but brought 4,000A peak current and integrated air compression to price points that undercut the established players. Choosing between them means weighing raw power against brand history, multi-function value against single-purpose refinement, and a 30-month warranty against a recognized name. This comparison covers the WOLFBOX MegaVolt24 and MegaVolt 24Air against the NOCO GB70 and GB150 — the mid-range and flagship models from each brand — across power, battery capacity, safety features, extra functions, warranty, and price.[1][6][7]
The Short Answer
If you want maximum peak power per dollar and a longer warranty, buy the WOLFBOX MegaVolt24. At approximately $180, it delivers 4,000A peak — double the 2,000A of the similarly priced NOCO GB70 — and covers up to 10.0L gas and 10.0L diesel engines with a 30-month warranty.[6] If you want a jump starter plus tire inflator in one device, buy the WOLFBOX MegaVolt 24Air. At approximately $280, it adds a 160 PSI compressor, 65W USB-C fast charging, and a 30-month warranty to the same 4,000A platform — capabilities that would require purchasing a separate NOCO jump starter plus a standalone air compressor.[7] If you prioritize brand track record and independent third-party recognition above all else, the NOCO GB70 is the most-reviewed jump starter in the category and the MechanicBase pick for best overall jump starter in 2025 — but with 2,000A peak and a 1-year warranty, it delivers less power and shorter coverage at a higher price.[3]
Brand Backgrounds
NOCO (The NOCO Company) was founded in 1914 and is headquartered in Glenwillow, Ohio. The Genius Boost jump starter series — including the GB20, GB40, GB70, and GB150 — has been on the market for over a decade and is widely distributed through Amazon, auto parts retailers, and big-box stores. NOCO's brand recognition in the jump starter category is the strongest of any manufacturer. The GB70 in particular has thousands of user reviews across retail platforms and is frequently cited as a benchmark in third-party comparison articles, including the MechanicBase 2025 ranking.[3]
WOLFBOX entered the jump starter category more recently but approached it from an existing position in vehicle electronics — the mirror dash cams are established in the 12V aftermarket. WOLFBOX's jump starter strategy has been to offer higher peak amperage (4,000A vs the typical 2,000–3,000A), larger battery capacity, and longer warranties at price points below the established competitors. The MegaVolt24 and MegaVolt 24Air represent the current WOLFBOX jump starter lineup as of 2026.[6][7]
Power Comparison: Peak Amps and Engine Coverage
Peak amps is the most visible specification on any jump starter — the maximum instantaneous current the unit can deliver when the starter motor first engages. It is not the only number that matters (sustained cranking current, battery capacity, and cold-weather performance all affect real-world results), but it is the best single indicator of what size engine the unit can start.[1]
Brand & Model
Peak Amps
Gas Engine Max
Diesel Engine Max
WOLFBOX MegaVolt24[6]
4,000A
10.0L
10.0L
WOLFBOX MegaVolt 24Air[7]
4,000A
10.0L
6.0L
NOCO GB70[3]
2,000A
8.0L
6.0L
NOCO GB150
3,000A
9.0L
7.0L
At the mid-range price point, the difference is stark: the MegaVolt24 delivers 4,000A peak for approximately $180, while the NOCO GB70 delivers 2,000A peak for around $200. The MegaVolt24 covers diesel engines up to 10.0L; the GB70 stops at 6.0L diesel. For a pickup truck owner with a 6.7L Power Stroke or 6.6L Duramax, the GB70 is below the rated threshold — the GB150 at approximately $300+ is the minimum NOCO that covers that engine, while the MegaVolt24 covers it at roughly $180.[3][6]
At the flagship level, the MegaVolt 24Air covers 10.0L gas and 6.0L diesel engines, while the NOCO GB150 covers 9.0L gas and 7.0L diesel engines. The MegaVolt 24Air holds a 1,000A peak advantage (4,000A vs 3,000A), though peak amps above 3,000A provide diminishing returns for most consumer vehicles. The practical difference is margin: the MegaVolt 24Air's extra 1,000A peak provides headroom for severely depleted batteries, extreme cold, and repeated cranking attempts.[1][7]
Battery Capacity and Runtime
Battery capacity determines how many jump starts a unit can deliver on a single charge and how long it can power USB devices or accessories between recharges.
MegaVolt24[6]
MegaVolt 24Air[7]
NOCO GB70[3]
NOCO GB150
Battery capacity
24,000mAh
24,000mAh
~15,000mAh (56 Wh)
88 Wh (≈23,784mAh @ 3.7V)
Jump starts per charge
Up to 40
Up to 40
Up to 40
Up to 80
Recharge time
~1.5 hours (65W USB-C PD)
~2 hours (65W USB-C)
USB-C: ~4.5h @ 2A; 12V XGC: 2–3h @ 3A
USB: ~11h @ 2A; 12V XGC: 2–3h @ 5A
The MegaVolt 24Air's 24,000mAh battery is the largest in the comparison — roughly 60% more capacity than the GB70 and slightly more than the GB150. In practical terms, this translates to more jump starts between charges and longer runtime when using the unit as a USB power bank or running the air compressor.[2][7]
A note on NOCO's battery chemistry: Both the GB70 and GB150 use lithium-ion (Li-ion) cells rather than lithium iron phosphate (LiFePO4). LiFePO4 offers longer cycle life (2,000+ cycles vs 500–1,000 for standard Li-ion) and better thermal stability, but at lower energy density. WOLFBOX uses high-discharge-rate Li-ion cells optimized for the burst current demands of engine starting.[2][4]
Extra Features: The Multi-Function Difference
The biggest differences between these models go beyond peak starting current. Air compressor performance, charging capabilities, power outputs, lighting, and weather resistance all affect how useful a jump starter is in everyday situations.
Tire inflator
The WOLFBOX MegaVolt 24Air features an integrated 160 PSI air compressor with a maximum airflow of 45 L/min. It can inflate a 37×12.5R17 pickup tire from 35 to 40 PSI in approximately 1 minute and 50 seconds. NOCO also offers an integrated jump starter and air compressor in its AX65 Boost Air. The AX65 delivers up to 67 L/min airflow and 100 PSI maximum pressure, with a 2,000A peak starting current. However, it is rated for gasoline engines up to 8.0L and diesel engines up to 6.0L, compared with the MegaVolt 24Air's 4,000A peak current and official engine ratings of up to 10L for gasoline and 6L for diesel. The GB70 and GB150 do not include built-in air compressors, so buyers choosing either model would need a separate tire inflator.[7]
USB-C fast charging
The MegaVolt 24Air supports 65W USB-C Power Delivery for both recharging the unit and powering compatible electronic devices. It can fully recharge in approximately 1.5–2 hours with a compatible 65W or higher charger. The NOCO GB70 and GB150 have USB-C input and output rated at 5V/2.1A, without USB-C PD fast charging. The MegaVolt 24Air therefore offers a substantially higher rating than the GB70 and GB150.[7]
DC output
The MegaVolt 24Air provides a 160W DC output for compatible 12V accessories and other supported devices. The NOCO GB70 and GB150 each feature a 12V, 15A XGC output, equivalent to a maximum rated output of 180W. This means NOCO's GB70 and GB150 actually offer a higher rated 12V output, while the MegaVolt 24Air combines its DC output with 65W USB-C PD charging. Check the voltage and power requirements of an accessory before connecting it.[7]
LED flashlight
The MegaVolt 24Air features a 400-lumen LED flashlight with three modes. The NOCO GB70 delivers 400 lumens, while the GB150 provides 500 lumens; both offer seven lighting modes, including SOS and strobe. The GB150 has the highest stated brightness, while the MegaVolt 24Air matches the GB70 in lumen output with a simpler three-mode setup.[6][7]
Weather resistance and low-voltage starting
The NOCO GB70 and GB150 carry an IP65 rating, while the MegaVolt 24Air is rated IP64. Both IP65 and IP64 ratings indicate dust-tight protection, but IP65 is tested against water jets, whereas IP64 is tested against water splashes. For deeply discharged batteries, the GB70 and GB150 provide a dedicated Manual Override function that forces Boost on when the battery voltage is too low for automatic detection. The MegaVolt 24Air offers a low-voltage BOOST mode, activated by pressing and holding the BOOST control. Both approaches provide a way to attempt starting when normal battery detection does not work, but users should follow each product's safety instructions when using these modes.[7]
Safety Features
Both brands include the essential safety protections expected in a modern lithium jump starter. The differences are in the details of implementation.[3][6][7]
Safety Feature
MegaVolt24[6]
MegaVolt 24Air[7]
NOCO GB70[3]
NOCO GB150
Spark-proof clamps
Yes
Yes
Yes (UltraSafe)
Yes (UltraSafe)
Reverse-polarity protection
Yes (alarm + block)
Yes (alarm + block)
Yes
Yes
Over-temperature protection
Yes
Yes
Yes
Yes
Overcharge protection
Yes
Yes
Short-circuit protection
Yes
Yes
Low-voltage detection
Yes
Yes
Yes (manual override)
Total named protections
10-layer
10-layer
Warranty and Support
This is the single largest non-spec difference between the brands.
MegaVolt24[6]
MegaVolt 24Air[7]
NOCO GB70[3]
NOCO GB150
Warranty length
30 months
30 months
1 year
1 year
WOLFBOX warrants both the MegaVolt24 and MegaVolt 24Air for 30 months — 2.5 times longer than NOCO's standard 1-year warranty across the entire Genius Boost lineup. The base term is 24 months, and every order placed through the WOLFBOX store adds a free 6-month extension, bringing both models to 30 months. For a device that lives in a vehicle trunk through summer heat and winter cold — conditions that stress lithium batteries — the warranty difference is not a paperwork detail.[6][7][3]
WOLFBOX vs NOCO at a Glance: Full Comparison
MegaVolt24[6]
MegaVolt 24Air[7]
NOCO GB70[3]
NOCO GB150
Peak amps
4,000A
4,000A
2,000A
3,000A
Gas engine max
10.0L
10.0L
8.0L
9.0L
Diesel engine max
10.0L
6.0L
6.0L
7.0L
Battery capacity
24,000mAh
24,000mAh
~15,000mAh (56 Wh)
Tire inflator
No
160 PSI, 45 L/min
No
No
USB charging
65W USB-C PD + USB-A
USB-C in, USB-A out + 12V XGC
USB in, USB-A out + 12V XGC
DC output
No
160W (12V/10A)
12V 15A XGC
12V 15A XGC
LED flashlight
Yes
400 lumens, 7 modes
400 lumens, 7 modes
500 lumens, 7 modes
Water/dust rating
IP64
IP64
IP65 (ports closed)
IP65
Operating temp
-4°F to 140°F
-4°F to 140°F
-4°F to 122°F (-20°C to 50°C)
Warranty
30 months
30 months
1 year
1 year
Approx. price
~$180
~$280
~$200
~$300+
Which Brand Should You Choose?
Choose WOLFBOX MegaVolt24 if you want the most peak cranking power at the lowest price. At approximately $180 with 4,000A and coverage for 10.0L gas and 10.0L diesel engines, it starts larger engines than the more expensive NOCO GB70 while costing less. The 30-month warranty triples NOCO's coverage.[6]
Choose WOLFBOX MegaVolt 24Air if you want one device that replaces a jump starter, tire inflator, power bank, and flashlight. The integrated 160 PSI compressor means you address both of the most common roadside emergencies — dead battery and flat tire — with a single charged device. The 65W USB-C port charges a laptop. Both WOLFBOX models carry the 30-month warranty, the longest in the category. At approximately $280, it costs less than a NOCO GB150 alone — and the GB150 does not include an air compressor.[7]
Choose NOCO GB70 if brand track record and third-party validation matter more to you than spec sheets. The GB70 has more user reviews across more retail platforms than any competing jump starter. It has been the MechanicBase "Best Jump Starter Overall" pick in the outlet's 2025 ranking. It is sold at more physical retail locations. For a buyer who values an established reputation and widespread availability above peak power per dollar, NOCO is the safer psychological choice — even if the specs do not lead on paper.[3]
Choose NOCO GB150 if you need the highest IP rating available (IP65 vs IP64 on WOLFBOX) and want 3,000A peak — sufficient for any consumer vehicle — from the most recognized brand in jump starters. The GB150's manual override button is the most straightforward implementation for deeply discharged batteries. At approximately $300+, it is the most expensive option in this comparison and does not include a tire inflator.[3]
For a deeper dive into how cranking amps translate to engine size requirements — which applies regardless of which brand you choose — see WOLFBOX's guide to jump starter amperage.[10]
Is WOLFBOX as reliable as NOCO for jump starters?
WOLFBOX has a shorter track record in jump starters than NOCO, which has sold the Genius Boost series for over a decade. However, WOLFBOX backs its jump starters with longer warranties — 30 months on both the MegaVolt24 and MegaVolt 24Air, compared to 1 year on all NOCO models — which transfers the reliability risk from the buyer to the manufacturer. A longer warranty does not prove higher reliability, but it does mean the manufacturer is willing to cover the product for longer, which is a meaningful signal for a product stored in harsh vehicle environments.[3][6][7]
Can the MegaVolt 24Air's air compressor really replace a separate tire inflator?
For most users, yes. The 160 PSI compressor inflates a 315/70 R17 pickup truck tire from 30 to 36 PSI in 2 minutes and 30 seconds, which is competitive with dedicated portable compressors. It is not a replacement for a shop compressor or a hard-mounted onboard air system — it is designed for topping off low tires and addressing flats at the roadside, not for running air tools or inflating from zero after an off-road air-down. For daily driving and road trips, it eliminates the need to carry a separate inflator.[7]
Which brand is better in cold weather?
Both brands use lithium battery chemistry that performs at reduced temperatures. The MegaVolt 24Air is explicitly rated for operation down to -4°F (-20°C), and the NOCO GB70 and GB150 are rated for -4°F to 122°F (-20°C to 50°C). In practice, all lithium jump starters lose capacity in extreme cold — keeping the unit inside the vehicle cabin rather than the trunk or truck bed, where temperatures are moderated, makes a larger difference than the brand.[2][7]
Will a 4,000A jump starter damage a smaller engine?
No. A jump starter does not push current into the vehicle — the starter motor draws only what it needs. The peak amp rating is the maximum the jump starter can deliver if demanded, not an amount it forces into the electrical system. A 4,000A jump starter connected to a 1.5L four-cylinder engine will supply exactly the current the starter motor requests, which is a fraction of the jump starter's maximum. Using an oversized jump starter is electrically safe; using an undersized one is the risk.[1]
[1] Jump start (vehicle), Wikipedia. https://en.wikipedia.org/wiki/Jumpstart(vehicle)
[2] Lithium-ion battery, Wikipedia. https://en.wikipedia.org/wiki/Lithium-ionbattery
[3] 10 Best Portable Jump Starters of 2025, MechanicBase. https://mechanicbase.com/reviews/best-jump-starter/
[4] Lithium iron phosphate battery, Wikipedia. https://en.wikipedia.org/wiki/Lithiumironphosphatebattery
[5] How to Prolong Lithium-Based Batteries, Battery University. https://batteryuniversity.com/article/bu-808-how-to-prolong-lithium-based-batteries
[6] WOLFBOX MegaVolt24 4000A Jump Starter, WOLFBOX Official Product Page. https://wolfbox.com/products/wolfbox-megavolt24-jump-starter
[7] 4-in-1 Jump Starter with Air Compressor Tire Inflator — WOLFBOX MegaVolt 24Air, WOLFBOX Official Product Page. https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
[8] Jump Starter Collection, WOLFBOX Official Store. https://wolfbox.com/collections/jump-starter-1
[9] Jump Starter With Air Compressor Collection, WOLFBOX Official Store. https://wolfbox.com/collections/jump-starter-with-air-compressor
[10] How Many Amps Does It Take to Jump Start a Car?, WOLFBOX Official Blog (jump-starter). https://wolfbox.com/blogs/jump-starter/how-many-amps-to-jump-start-a-car
Best Jump Starter for V8 and V6 Engines: Power Requirements by Engine Size 2026
Best Jump Starter for Toyota Trucks and SUVs: Tacoma, 4Runner, Tundra 2026
