A man is wondering: Should he get a dash cam
Why Every Driver Should Have a Dash Cam: 6 Key Benefits
You might be wondering about dash cams and if you should get one too. Dash cams are becoming very important for drivers as they can help you record everything that is happening around your car. The need for dash cam is growing with the increase in insurance fraud and ruthless drivers. There are many benefits of getting a dash cam which we will be discussing in the article.
What Is a Dash Cam?
Dash cam is a small camera that you can attach on the dashboard of your car to record everything that happens around it. It can record the video of your surroundings when you are driving. In case you get involved in any incident such as an accident or fraud attempt, the video recorded by your dash cam can be very useful.
Get an Overview of Dash Cam:
How Do Dash Cams Work
Wolfbox G930 Dash Cam
Why Do I Need a Dash Cam? Key Reasons to Consider
  • Proof in an Accident
    If you have an accident, your dash cam video can show what exactly happened. You can use the video recorded by your dash cam for insurance or legal purposes.
  • Security
    One of the main benefits of the dash cam is that they can add an extra layer of security to your vehicle. You can use them to make your car secure. With modes like Parking mode and Time Lapse, you can record your car 24/7 and even when it is left unattended.
  • Protection from False Claims:
    Nowadays many people try to fake an accident and say it was your fault when it was not. Your dash cam video can show the truth and help you prove yourself innocent.
  • Record Bad Drivers:
    With a dash cam, you can also record the bad drivers on the road that can cause harm to you or others on the road. You can also use the recording to claim insurance if you are involved in an accident.
  • Capture Interesting Things:
    You can also use Dashcam to record your journeys and later view them. You might see interesting things while you drive and with your dash cam recording these things, they can be a good memory for you.
    If you are a vlogger and want to make a video of your journey, you can also use dashcam recording to make timelapse of your ride.
  • Peace of Mind:
    Knowing that you have a dash cam can give you peace of mind as you will know you have a record of what happen around your car.
    You will not have to worry about fraud attempts or any other incidents and drive peacefully. You can also use other modes like parking mode to keep your car secure when you are not using it.
Different Types of Dash Cams: Choosing the Right One for You
There are different types of dash cams options you can choose from. Some dash cams can record only the surroundings while others can also record the interior of your car.
Single-Channel Dash Cams
Single-channel dash cams only come with only one camera that can record the front of your car. You can use this dash cam to record what is happening in the road ahead of your car. If anyone ahead of you applies brakes suddenly and tries to fake an accident, this mode camera can be very helpful. You can use it to protect your car from basic threats.
Dual-Channel Dash Cams: Front and rear coverage
Dual-channel dash cams have two cameras that can record both the front and back / rear of your car. This will help you get better coverage of what happens on the road from both sides. In case anyone hit you from behind while over speeding, you can use this camera to capture important information.
360°Dash Cams: Full-circle surveillance
360° dash cams can be mounted on the top of your car to give a view of everything on the road. These cameras can be very useful if you are a new driver and want to record everything around you to learn better driving.
Wi-Fi and GPS Dash Cams
Some dash cams like Wolfbox 900Pro also have the special feature that lets you connect the dash cam with your smartphone using Wi-Fi. These dash cams also have GPS option which you can use to keep track of your rides.
Features to Look for When Buying a Dash Cam
Mounting Options
Wolfbox has multiple mounting options
There are different ways you can use to mount your dashcam to your car. You can use suctions cups to keep your camera in place or a sticky mount to make it secure. You can also install a hardwiring kit to make sure your camera is ON even when you turn off the engine of your car. You must check if the dash cam has these so you can install dashcam easily.
Battery Types
You can use the battery of your car to charge the dashcam when it is running. If you want to keep the dashcam running for longer time even when you have turned off your car, you can use a hardwiring kit. For this, you should go for external battery if your budget allows it to make sure the original car battery doesn’t get affected.
Video Quality
The dash cam you choose should have good video quality recording. You should go for dash cam that can record in at least 1080p and up to 4k. Your high resolution dashcam can record everything in detail such as number plater, the road signs and much more.
Storage Capacity
If you are willing to use a dashcam for long rides or want to keep a record of your videos for a long time, you should go for a dashcam that can work well with high storage SD Card. This will let you save recordings of multiple weeks before the dashcam starts overwriting the old video.
Audio Recording
You can also find dash cams that can record audios along with the videos for better details. This will let you record your conversations when driving as well.
Related: Does a Dash Cam Record Audio
GPS Tracking and App Connectivity
If your dash camera has GPS tracking and app connectivity, it will make things easier for you. You can use dashcam smartphone app to control your camera and view live feed from anywhere in the world.
Parking Mode
Parking mode is a special feature in dash cam that lets your camera record even when the car is turned off or parked. You should check if your camera has parking mode before buying it so you can record the car even when it is parked for better security.
Related: What is Parking Mode On Dash Cam?
Cost Considerations
Dash cams cost different amounts depending on what features they have. You should find one that has all the basic features and fits your budget. Wolfbox dash cams like Wolfbox G850Pro are budget friendly and have many features for your everyday use.
Dash Cam Use Cases: Who Should Get a Dash Cam?
Everyday Drivers
If you are an everyday driver, you can use dash cam to record your rides and to get evidence in case of any incident.
Commercial Drivers and Fleet Owners
If you are a fleet owner or have to give your car to someone, you can use dashcam to check if they are driving carefully or not. In case of any incident, you will know if the person driving was responsible or not.
Teen Drivers and New Drivers
If you have a teenage driver or are learning to drive, you can use dash cams for extra peace of mind. You can also view the recording later to learn from your mistakes.
Frequent Travelers and Road Trip Enthusiasts
If you are a travel enthusiast and want to capture your rides, you can use dashcam for this. It will help you capture your road trips and also give you protection against accidents.
Comparison: Dash Cams vs. Other Car Safety Features
Dash cams, backup cameras, blind spot monitors, and parking sensors each play distinct roles in enhancing vehicle safety:
Dash cams primarily focus on recording driving events, while backup cameras assist with rear visibility during parking. Blind spot monitors provide warnings for unseen areas, and parking sensors alert drivers to nearby obstacles.
The table below offers a detailed comparison of these technologies, helping you understand their unique features and choose the right solution for your needs.
Feature Dash Cam Backup Camera Blind Spot Monitor Parking Sensors
Records Driving ✔️ ❌ ❌ ❌
Helps with Parking Limited
✔️ Limited
Warns of Blind Spots ✔️ ❌ ✔️ ❌
Helps in Accidents ✔️ Limited
Limited Limited
If you are thinking about getting a dashcam, you must give it a try. They are very useful and can help you with many different things. They can protect you and your car from many things. In case you are ever involved in an accident, you can use the recording to claim insurance or to prove your innocence. They are worth the investment. Wolfbox is a good choice if you want a dashcam with basic to advanced features within your budget.
FAQs: Common Questions About Dash Cams
How Are Dash Cams Powered?
Dash cams can get power in different ways. You can plug them in the car charger or connect them to an external battery or hardwire them.
What Are the Legal Implications of Using a Dash Cam?
Each country has different laws about the use of dashcams. You should check the laws about dash cams in the place where you live before getting them.
How Easy Are Dash Cams to Install?
Most dash cams are very easy to install yourself. If you want to get them installed professionally, you can go to any car store and get it done there.
Are Dash Cams Reliable in Extreme Weather Conditions?
Yes, dash cameras are mostly installed inside your car and are not affected by weather conditions.
Can Dash Cams Be Used to Monitor My Car in Parking?
Yes. You can use dash cameras to monitor your car in parking with a feature called Parking mode.
