Dash Cams That Record When Car if Off
Do Dash Cams Record When Car is off?
You might want to know if your dash cam can still record videos even if you turn off your car. The short answer is Yes, but it depends on what dash cam you are using. Everyone wants to protect their car even when they are not driving it. In this article, we will talk about how dash cams can record even when your car is turned off and if they can record 24/7.
You can use dashcam to record what is happening near your car when you're driving. But you can also dashcams to record when your car is parked. This is called parking mode and it can help you record important events like hit-and-runs or vandalism.
How Do Dash Cams Record When the Car is Off?
Some dash cams have special features that can record surrounding of your car even when it is turned off. You can use this mode to protect your car when you are parking it somewhere new or overnight.
Features
  • Parking Mode
    With this mode, your dashcams can record even when your car is parked. You can configure its settings to record all the time or only when there is some movement near the car.
    Recommend: Best Dash Cams with Parking Mode
  • Motion Detection
    With this dash cam feature, your camera will use a sensor (G-sensor) to detect movement around your car. If it detects something moving near the car, it will start recording.
Dash Cams with motion detection
  • G-Sensor
    The G-sensor is used to detect any sudden impacts or movements like if someone bumps into your car. When it detects something, it will send a signal to the dash cam to start recording.
  • Buffered Recording
    Some dash cams with parking mode also have buffered recording. This means they can constantly record a short loop (1, 3, 5 minutes) and when an event happens near the car, it will save that loop. With this, you can make sure that the camera will record the moments leading up to the event as well.
  • Low Bitrate Recording
    This feature lets the camera to record continuously at a lower quality to save storage space when it is parked. It is not recommended as it is difficult to identify anything in low recording.
Learn More: Does Dash Cam Record Audio?
Power Sources
If you want to record your car when it is off, your dash cam will need a power source.
  • Hardwiring
    You can hardwire your dashcam directly to your car's battery. This will let it get power even when the engine is off. But you will need to use a hardwire kit with a voltage cutoff so your car’s main battery is safe and doesn’t drain completely.
    Hardwire kit with voltage cutoff feature
  • External Battery Pack
    You can also use a separate battery pack to power your dash cam. This is a good choice if you don’t want to use the main battery of your car.
external battery for dash cams
  • OBD-II Connector
    You can also power some dash cams through your car's OBD-II port. However, this method can also drain your car battery if you are not using it correctly.
Can a Dash Cam Record 24/7?
The short / direct answer is yes, but there are some things you need to know.
Continuous recording means that your dash cam is always recording, whether your car is on or off. This is very useful if you want to record everything that is happening around your car. But it can use a lot of storage space and can also drain your car battery if you don't have the right setup.
How Long Can Dash Cams Record Without Car Power?
  • Battery Size:
    If you are using an external battery pack, the bigger the battery, the longer it will last.
  • Recording Settings:
    If you are recording videos of higher quality, it can use more storage and battery power.
  • Parking Mode Settings:
    If you are using parking mode with motion detection, your dash cam will only record when it detects something which can save a lot of power.
Power Source Approximate Recording Time
Hardwired (without voltage cutoff) Until your car’s battery is drained.
(Not recommended)
Hardwired (with voltage cutoff) Until car battery reaches cutoff voltage
External Battery Pack (small) Several hours
External Battery Pack (large) Can record overnight.
Supercapacitor Very short time after power loss
What Happens to Your Car Battery When Dash Cam Records 24/7?
If your dash cam is constantly drawing power from the main battery of your car, it can drain the battery. This can also make your car dead and you will need another backup source to recharge your battery or to start the car. Completely draining your battery can also affect its health and lower its lifetime. This is why it’s important to use a hardwire kit with a voltage cutoff.
Battery Consumption During Continuous Recording
Dash cams can use different amounts of power depending on their features. Some use more power than others. If you are using parking mode or motion detection, it will use less power.
How to Avoid Battery Drain Issues
  • Use a Hardwire Kit with Voltage Cutoff
    You can use a hardwiring kit to stop the dash cam from taking power once the voltage of your car battery reaches a certain level. Dash cams from Wolfbox come with hardwire kit.
  • Use an External Battery Pack
    You can also use an external battery only for your dash cam to avoid using your car's battery altogether. This battery will be charged when your car is running and supply power to cam when it is off.
  • Choose a Dash Cam with Efficient Parking Mode
    Some dash cams also have more efficient parking modes that use less power. Wolfbox dash cams like the G900 and G900 Pro also have efficient parking modes.
  • Check Your Car Battery Regularly
    You should also check your battery health regularly to make sure your car battery is in good condition.
Benefits of Having 24/7 Dash Cam Recording
Monitoring for Theft, Vandalism, and Accidents
If someone tries to steal your car, vandalize it or hits it while it’s parked, without parking mode you will never know how it happened. But with your dash cam recording all the time, it will capture the event. You can use these recording proofs for insurance claims or police reports.
Peace of Mind When the Car is Parked
When you know that your dash cam is recording all the time, even when you’re not there can give you peace of mind. You can relax knowing that your car is being monitored in case anything bad happens.
Dash Cam Features for Effective 24/7 Surveillance
Loop Recording
Loop recording means that your dash cam will records over old footage when the memory card is full. You can use this mode for continuous recording because you don’t have to manually delete files. It will overwrite the oldest unsaved recording to make space for the newer recording.
Time-Lapse Recording
With this mode, your dash cam can record at a lower frame rate which saves storage space. It’s good for long-term monitoring. This mode can also record videos in fast formats (1.5x / 2x) to save space in your dash cams.
Motion Detection
With this feature, your dash cam will look for events near your car. It will only record when it detects movement which can save both storage space and battery power.
Do You Need a Dash Cam That Records When the Car is Off?
If you’re worried about the security of your car when it’s parked, a dash cam that records when the car is off is a good idea.
When Parking Mode is Essential
Parking in Public Areas
If you are parking in public area where there is a lot of traffic, you should use parking mode to secure your car.
Remote Areas
If you have to park in remote area that you are not familiar with, you should always have your dash cam in recording mode.
Overnight
You never know when something bad can happen to your car. If you park your car outside your home, you must have dash cam ON.
Choosing the Right Dash Cam for 24/7 Monitoring
  • Parking Mode
    You must make sure the dash cam has a parking mode with motion detection and/or G-sensor. Wolfbox dash cams come with parking mode features like the G900 Pro and the G850 which has both front and rear recording.
  • Hardwire Kit Compatibility
    You should also see if the dash cams are compatible with a hardwire kit with a voltage cutoff.
  • Good Video Quality:
    You should go for the dash cams that can record clear videos even at night.
  • Reliable Power Source:
    It is better to buy an external battery source if you want to use the continuous recording mode in your dash cam all the time.
Is a Dash Cam That Records 24/7 Right for You?
If you have a dash cam that can record 24/7, it can provide security to your car and peace of mind. You can use it to record important things even when you’re not there. If you are concerned about the safety of your car, dash cam is something you should have. Wolfbox has a range of dash cams that can meet your needs with models that also have parking mode like the Wolfbox G900, G900 Pro, and the G850.
