Table of content
What is Parking Mode in Dash Cams?
Parking mode in dash cams is a feature that allows constant surveillance of a vehicle even when it is turned off. Unlike normal cameras that only work when driving, these cams with parking mode activate themselves to record any incident or motion near the vehicle. This provides safety for your car in case of any incidents like hit-and-run, theft or accidents. These cameras use time-lapse recording to free the storage while monitoring the surrounding so there is enough space to save the recording in case of incidents.
To work during the parking mode, these cams need to be connected to power source all the time. It can be done by hardwiring to the vehicle’s battery or by providing them with an external supply. Some models also have low-voltage protection that shut themselves off to prevent battery from draining completely. Advanced cams also have GPS trackers and app connectivity that provide real time alerts.
Our Top Picks for Dash Cams with Parking Mode
| Product Name | Best For | Customer Ratings | Cost | Key Benefits |
| G900 Pro Dash Cam | High-Resolution Recording and Advanced Parking Features | ⭐⭐⭐⭐⭐ 4.8/5 | $299.99 | 4K ultra-HD resolution, Sony STARVIS night vision, GPS tracking, 170° wide-angle and buffered parking mode |
| G900 Dash Cam | Versatile Features at a Competitive Price | ⭐⭐⭐⭐☆ 4.7/5 | $249.99 | 2.5K front and 1080p rear, GPS integration, motion-activated parking mode, wide-angle recording and budget-friendly. |
| G850 Pro Dash Cam | Comprehensive Protection with Dual Recording | ⭐⭐⭐⭐☆ 4.6/5 | $169.99 | 4K front and 2.5K rear recording, durable design, motion detection parking mode, Wi-Fi connectivity and a 170° wide lens for broader coverage. |
| G840s Dash Cam | Smart Rear-View Monitoring and Enhanced Parking Features | ⭐⭐⭐⭐☆ 4.7/5 | $239.99 | Mirror-style design, 4K front and 1080p rear resolution, advanced night vision, GPS logging, motion detection and time-lapse parking mode for extended surveillance. |
Note: "4K" refers to exported video files with a resolution of not less than 3840 × 2160.
Read More: How Much is a Dash Cam: Is it Worth It?
G900 Pro Dash Cam
Introduction
The G900 pro dash-cam comes with advanced features that improve the security of vehicles and record driving events. It has a strong build and design that helps the drivers that are looking for reliable video recording and parking supervision. With high-level resolutions and good nigh vision technology, they are a good choice for both day and night. The camera comes with advanced parking mode features that makes it even better.
Parking Mode Feature
The G900 pro cam has a parking mode that continuously protects your vehicle when it’s parked. This feature uses motion detection and impact sensors to start recording whenever it detects any impact or movement. It also records events even if your car is turned off. This makes it the best available option to improve your vehicle’s safety. Its buffered recording saves video many seconds before and after the event is triggered so no moment is missed.
Tech Specifications
| Feature | Details |
| Resolution | 4K Ultra HD |
| Lens Angle | 150 degrees |
| Display | 2.4-inch LCD |
| Night Vision | Yes (Advanced) |
| Loop Recording | Yes |
| G-Sensor | Yes |
| Storage Support | Up to 256 GB |
| GPS Logging | Yes |
| Parking Mode | Motion & Impact |
G900 Dash Cam
Introduction
G900 Dash Cam is an advanced recording solution for drivers that need dependable security features. This cam comes with a high-resolution camera and many other features that make it a good option for improving the safety of vehicles. With a simple to use interface and design, it mixes the aesthetic with usability. This dash cam is famous for its parking mode feature that supports continuous monitoring and protects your parked vehicle.
G900 Dash Camera has an advanced parking mode that is important for vehicles for better security when they are parked for hours. It uses technologies like motion detection and impact sensors to look for any incidents or events. As anything happens, they activate the recording feature to capture these disturbances. They have a built-in G-sensors to capture critical videos of collisions or impacts and save them without overwriting them. This all happens even if your vehicle is turned off which makes it more reliable.
Tech Specifications
| Feature | Details |
| Resolution | 1440p Full HD |
| Lens Angle | 160 degrees |
| Display | 3.5-inch LCD |
| Night Vision | Yes (Enhanced) |
| G-Sensor | Yes |
| Storage Support | Up to 512 GB |
| GPS Logging | Yes |
| Wi-Fi Connectivity | Yes |
G850 Pro Dash Cam
Introduction
The G850 Pro Dash cam is a high-level device that delivers unmatchable video recording and parking security. It has advanced features that make it a reliable companion to make your vehicle safe, whether it is on the road or parked. It combines high level video quality, advanced sensors and parking protection. This dash cam is best for drives that want good functionality and smooth recording in different conditions.
The parking feature of the G850 Pro dash cam is second to none. This feature starts by itself when the vehicle is parked and uses motion detection technology with impact sensors to observe its surroundings. If it notices any movement or collision, it will start recording instantly. It also uses buffered recording to save video of before and after the incidents too. It can also operate when the car is turned off because of its backup battery option.
Tech Specifications
| Feature | Details |
| Resolution | 4K Ultra HD Front, 1080p Rear |
| Lens Angle | 170 degrees |
| Display | 3-inch LCD |
| Night Vision | Yes (Advanced IR) |
| G-Sensor | Yes |
| GPS Logging | Yes |
| Parking Mode | Motion & Impact with Buffered Recording |
G840s Dash Cam
Introduction
G840s Dash Cam is one of the most reliable and efficient devices that gives thorough parking supervision and provides road safety. It has a dual camera system that records videos from both and the back of your vehicle to give complete coverage. It comes with advanced features like night vision and GPS logging that makes your vehicle even safer. It has a parking mode that adds another layer of protection which make your vehicle secured at all times.
The intelligent parking mode feature of G840s protects your car even when it is parked. It has advanced sensors and detectors which trigger recording as soon as any motion is detected near your vehicle. It also grants G-sensor technology that saves recording when an impact happens and doesn’t overwrite it unless it is deleted manually. These features make G480s the best dash cam for everyday use.
Tech Specifications
| Feature | Details |
| Resolution | 2K QHD Front, 1080p Rear |
| G-Sensor | Yes |
| GPS Logging | Yes |
Why We Need a Dash Cam with Parking Mode?
1. Protection Against Hit-and-Runs
Hit and run are very common in busy parking areas and with no evidence, it is not possible to identify the culprit. The recordings from dash cams can help identify the responsible part and provide solid proof for insurance claims.
2. Defense Against Theft and Vandalism
In inner cities, car theft and harm are growing every day. These dash cams can warn you by alerting you with their advanced features and provide you with live GPS locations.
3. Reliable Evidence for Insurance Claims
Accidents or damage to your parked vehicle can result in costly repairs. With these recordings from your dash cams, you can get reliable evidence for insurance claims or legal cases.
4. Peace of Mind in Unfamiliar Areas
When you park your vehicle in an unfamiliar place, you are always concerned about its safety. With these dash-cams, you can get peace of mind as your vehicle is always being recorded, even when you are not near it.
Different Types of Parking Modes
1. Impact-Activated Parking Mode
It triggers recording when the dash cam detects an impact or vibration near the car. It takes help of G-sensor to identify physical disturbances like minor collisions or break-ins.
2. Buffered Parking Mode
These modes record the surroundings all the time and keep the recording in temporary memory. But it saves the footage permanently whenever it detects any motion or impact with the coverage of before and after the incidents too.
3. Time-Lapse Parking Mode
This mode can be used to capture videos at set intervals like two frames per second. This mode makes a condense recordings of long periods which saves storage.
4. Low Bitrate Mode
It captures constantly but at low video quality to save energy and storage. But due to their low resolution which can make it difficult to identify details, it is a less popular option.
6. Radar-Assisted Parking Mode
This mode takes help from radar sensors to detect motion near the car and only record if it gets triggered. This is energy-efficient and reduces any unneeded recording by only capturing incidents.
How to Choose the Best Dash Cam with Parking Mode?
1. Camera Channels
The number of camera channels tells about the coverage range provided by the dash cam. A single channel cam records only the front of vehicle. Dual channel dash cams covers both the front and rear of the camera. Three-channel dash cam records the vehicle’s interior as well.
2. Video Quality
The quality of the video is also important to get the detailed coverage of the incident. Minimum resolution of the camera for good video should be 1080p. For better quality videos, choose 2k or 4k Cameras.
3. Parking Mode Options
Make sure the dash cams have advanced parking modes like motion-triggered, impact-activation and buffered recording. Buffered recording gives a continuous loop and save footage before and after the incident too.
4. Night Vision Capability
Night vision is needed to monitor the vehicle in low visibility conditions. Dash cams must have high infrared sensors to provide clear recording at night.
Recommended: Best Dash Cams with Night Vision
5. Power Source and Battery Protection
Parking mode records video even when the vehicle is turned off. Therefore, the need for a constant power supply is must. Having a separate backup power source and low-voltage protection also save your battery from draining completely.
6. Storage and Loop Recording
The storage capacity of the dash cams is important for parking mode. Use the models that can handle high-capacity SD cards(128 GB and more). Loop recording overwrite the older footage, but with high storage, you can store recording for longer periods.
How to Avoid Draining Your Car Battery with Parking Mode?
1. Use a Hardwiring Kit
You must always get your dash cam connected directly to fuse box of vehicles. This allows dash cam to get constant power without overloading. Most kits also have low voltage cutoff feature that stops the supply when battery’s charging is low.
2. Invest in an External Battery Pack
If possible, always use an external battery pack for dash cams this will make sure that your vehicle is recording for longer periods without draining main battery. They get charged when engine is running.
3. Optimize Parking Mode Settings
Adjust the parking mode settings in your dash cam to get the perfect balance between consumption and performance. Modes like motion detection use less energy than constant recording.
4. Use Low-Voltage Protection
Low voltage is very important for vehicle that rely on the main battery. This feature cut off the power supply to dash cam before the battery charge reaches the critical levels.
Final Thoughts
Dash cams are the best way to add extra layer of protection on your vehicle. They make sure your car is always safe, even when it is parked. They have different features that records any event or incidents that happens near the vehicle. Their additional features allow let you modify the dash cam according to your needs.
1. What is the best dash cam with parking mode?
The best dash cam with parking mode depends on your needs. Models that offer 4K resolution, buffered recording and G-sensors are perfect. Cameras with low-voltage protection and radar-assisted monitoring guarantee safety and energy efficiency.
2. Does parking mode drain the car battery?
Parking mode takes power from your car battery, but low-voltage protection or an external battery prevents excessive drainage. Using a hardwiring kit with voltage cutoffs saves your car battery.
3. Can I leave my dash cam on 24/7?
Yes, you can leave your dash cam on 24/7 if it supports parking mode and has a constant power source. The device should have features like low-voltage protection to avoid draining your car battery.
4. How does buffered recording work in parking mode?
Buffered recording continuously stores video in the temporary memory of the camera. When motion or impact triggers recording, the dash cam saves a few seconds before to after the event for a complete timeline.
5. Is a dual-channel dash cam better for parking mode?
Yes, dual-channel dash cams are better for parking mode as they provide front and rear coverage. This provides comprehensive monitoring of your vehicle in case of incidents from any side.
6. What is intelligent parking mode?
Intelligent parking mode uses advanced motion and impact sensors to start recordings only during occurrence of events. Some models also have radar-assisted activation to improve accuracy and reduce unnecessary footage.
