In terms of providing a seamless experience when using your dash cam, a hardwire kit for dash cam is a game changer. Most dash cams also include a simple power adapter that goes into the cigarette lighter, but you can give yourself an upgrade by hard-wiring your dash cam directly into the fuse box of your car.
Such configuration provides constant powering, even with your car being off, which provides 24/7 surveillance. So why should you give it a thought? Let’s dive into the details and explore how a hardwiring kit for dash cam can boost your dash cam's functionality.
What is a Hardwire Kit for Dash Cam?
Hardwire kit for dash cam is a set of tools that wires your camera with dash directly to the fuse box of your car. The hardwire kit will supply constant power, unlike the cigarette lighter, which only functions when the vehicle is operating, so your dash cam will stay on, even when the engine is not running. Typically, the kit contains fuse taps, a voltage regulator, and wiring, which allows for a seamless connection to both constant and ignition-controlled power sources.
What’s Inside a Typical Hardwire Kit?
A dash cam installation hardwire kit commonly consists of a number of the following major parts:
1. Fuse Taps and Fuse Holder:
These assist in the wiring of the connection between your dash cam and fuse box, the first button tap is wired to a continuous source of power (this keeps the dash cam federated as long as the car is charged) and the second is an ignition controlled source of power (the dash cam only turns on when the car is turned on).
2. Voltage Regulator or Cutoff Module:
This part will make sure that your dash cam is not consuming a lot of power which can damage your car battery.
3. Ground Cable and Add-a-Fuse Leads:
These are required in order to be correctly grounded and fitted into the fuse box. All of the mentioned components are crucial when it comes to providing your dash cam with an adequate supply of power without any harm done to your car.
How a Hardwire Kit Works?
The hardwire kit installations with dash cam allow you to connect your dash cam with the electricity to the vehicle via its fuse box. And here is how it works in stages:
1. Connection to Fuse Box:
The kit connects to the fuse box with the help of the fuse taps that attach to the constant power source or the ignition-controlled power source.
2. Power Conversion:
The voltage regulator simply reduces the amount of power produced by the 12V system in your car to 5V, which is what your dash cam requires.
3. Wires in the Kit:
The three primary wires in the kit are ACC (which supplies power when ignition is on), VCC (constantly powered), and GND (or ground) wire, which makes sure that the dash cam receives the appropriate power supply at any time.
This installation enables constant surveillance even when your automobile is off and parked.
Key Benefits of Using a Hardwire Kit
What are the reasons to invest in a hard wire kit for dash cam? The following are some of the main benefits:
1. 24/7 Parking Monitoring:
A hardwired dash cam will keep recording when you are parked, providing a shield of protection against possible thefts or accidents when you are away.
2. Cleaner Look & Cabin Safety:
A hard wired dash cam eliminates unsightly cables hanging off the cigarette lighter and gives a neater, more secure appearance in your vehicle.
3. Freed-Up 12V Socket:
Hardwiring your dash cam leaves the cigarette lighter socket free to make use of other gadgets such as chargers, which come in handy.
4. Battery Drain Prevention:
The voltage regulator ensures that the battery of your car is not drained out due to overload.
How to Install a Hardwire Kit for Dash Cam: Step-by-Step Guide
Hardwire kit dash cam is easy to install. So here is simple step-by-step guide to get out of it:
1. Turn off the Vehicle:
Before you start installation, always make sure the battery is disconnected and the car is turned off. This is a safety consideration to prevent any electrical accidents.
2. Locate the Fuse Box:
Usually, the fuse box is behind the dashboard or is somewhere close to the driver. Check the handbook of your vehicle in case you do not know where it is.
3. Install the Fuse Taps:
The fuse taps should be inserted into the fitting fuses. Place the continuous power fuse under constant monitoring and ignition-controlled fuse under monitoring when the vehicle is on.
4. Connect the Wiring:
Make connections to corresponding fuses and follow the wires to the location of the dash cam. This step will have to take a bit of wires leading out to the dash cam and fuse box depending on where you have your fuse box located and where you set up your dash cam.
5. Ground the System:
Connect the ground cable to a metal component of your car as this will close the circuit. This will make the electrical system to be well grounded avoiding future electrical problems.
6. Test the Setup:
Reconnect the battery and start your vehicle to check whether the dash cam consumes electricity properly. All you have to do is correctly configure your dash cam and when you start the car, it should turn on and start recording (or keep in parking behavior, but it depends on your adjustments).
After installing, your dash cam will be ready for continuous monitoring, ensuring you have constant security.
Hardwire Kit vs Cigarette Lighter: Which Power Option is better?
When it comes to powering your dash cam, you can either hardwire it or use a cigarette lighter to supply power. But there are some noticeable differences:
1. Cigarette Lighter:
It is simple to operate but it can only operate with power when the car is running. That implies that your dash cam will not be capable of recording when you are parked. This system is comfortable to use during the short-range trip, but it is not as convenient as the wired dash cam with 24/7 capacity.
2. Hardwiring:
Offers continuous power, ensuring that your dash cam can capture 24/7, even when your car is not running. There is also a cleaner connection and it does not drain the battery, by the use of a voltage regulator. In the case of long-term security and reliability, hardwiring clearly dominates.
In brief, each method has compelling advantages, but hardwiring is preferable to those interested in reliable power, enhanced functionality, and peace of mind.
If you want to learn more about installation, especially the wiring process, check out our detailed guide on how to wire a dash cam.
Conclusion:
A hardwire kit for dash cam provides 24/7 protection, seamless installation, and better battery management. It provides you with peace of mind because you know that your dash cam operates all the time with or without your car turned on. Upgrade now with Wolfbox for reliable, continuous monitoring and enhanced security for your vehicle every day, all day.
Do you need a hardwire kit for a dash cam?
While not mandatory, a hardwiring kit has significant benefits, including 24/7 monitoring, better functionality, and neater arrangement.
Is hardwiring a dash cam bad for the battery?
No, so far as the kit comes with a voltage regulator in it, it avoids overloading on the power which may unnecessarily destroy the battery of the vehicle.
What is an alternative to hardwiring a dash cam?
The primary alternative is using the cigarette lighter, but the only problem is that it supplies energy when the vehicle is running, which means you won’t have the same level of continuous protection.
