Not all dash cams suit all vehicles, and the Chevy Silverado and other full-size trucks are no exception. Despite there being options galore, like front-facing single-channel dash cams, dual-channel front and rear dash cams, mirror dash cams, and interior cabin-view dash cams, not all will do the job you need them to do.
From larger windshields and truck bed obstructions to blind spots and overall visibility challenges, trucks like the Chevy Silverado can be a little…tricky, to say the least. So, what is the best dash cam for such vehicles? In this guide, we’ll find out together.
What Challenges Do Truck Owners Face?
To choose the best type of dash cam, you first need to understand the unique visibility challenges truck owners face during everyday driving, hauling, and even a few off-roading adventures.
The Truck Bed Blocks the Rear View
As convenient as a truck bed is for hauling, it can affect what you can see behind the vehicle when using a traditional rearview mirror. Depending on the truck's configuration and load, the bed or cargo can partially block the driver's rearward view.
The WOLFBOX G900TriPro Bumper Version mirror dash cam is designed with a rear camera that provides a live view of the area behind the truck on the mirror display. This gives drivers a clearer way to monitor traffic and the road behind the vehicle while driving.[1]
Different Camera Positioning
Chevy Silverados and other large pickup trucks require different dash cam placement than more traditional daily-driver sedans to achieve the same level of visibility. As a result, traditional dash cam options that work well in sedans aren’t always effective in trucks.
Trucks have larger blind spots, more vibration on rough roads, and challenges keeping the camera clear of driver-assistance sensors. Even cable routing can be challenging, with larger cabins calling for longer cables that not all dash cams come with as standard.
That’s why the WOLFBOX G900TriPro Bumper Dash Cam is such a game-changer for many drivers. The three-channel touchscreen rearview mirror dashcam is designed to eliminate blind spots, maintain 360-degree awareness, and install with far longer camera cables and replacement cables for convenience.[2]
Towing Challenges
Your side mirrors only take you so far when you’re towing trailers, boats, campers, and other large, cumbersome vehicles and items. While you can see a small amount over the truck bed, peace of mind comes from seeing as much as possible.
A rear-view mirror dash cam, such as the WOLFBOX G900Pro, can be an excellent solution for many truck drivers. Once installed, it offers a full, unobstructed view, regardless of tall setups and trailers, and even assists with parking through Reverse Assist, should you need a helping hand.[3]
What to Look for in a Truck Dash Cam
When you’re ready to invest in more visibility and peace of mind for your Chevy Silverado or full-size truck, here are some important features to look for:
Benefit |
4K resolution front recording |
Capture more detail ahead of a large vehicle, such as a Chevy Silverado |
High-resolution rear camera |
Better and more detail behind the truck |
Bumper camera |
Provides a low-mounted front view for closer visibility around the front of the truck |
Large display |
Easier to see what’s around you while reversing or parking |
Wide field of view |
Practical for more visibility around a wider truck |
GPS tracking |
Records your location and speed data |
Parking guard |
Includes a G-sensor and loop recording for every impact, even when parked |
Enhanced night vision |
See clearly in low lighting |
Impact detection |
Protects important footage |
Waterproof rear camera |
Helpful for exterior mounting on bumpers |
Stable mounting |
More robust installation for off-roading adventures and rough roads |
Large microSD support |
Provides longer recording periods |
Best WOLFBOX Dash Cams for Chevy Silverado and Full-Size Trucks
Some models stand out more than others as suitable dash cams for full-size trucks. We’ve compared some of the most top-rated models on the market below to help you make an informed choice.
WOLFBOX G900 TriPro Bumper Dash Cam
The WOLFBOX G900 TriPro Bumper Dash Cam is a three-channel system installed on a truck's bumper, ideal for full-size pickup trucks like the Chevy Silverado, where the truck bed blocks a conventional rear camera view.
- Triple HDR: Whether you’re hauling work supplies or need a close-up view of your terrain on your next off-roading adventure, the WOLFBOX G900 TriPro Bumper Dash Cam delivers with triple HDR. It boasts a 4K front camera, meaning a horizontal display resolution of around 4,000 pixels for a high-definition image. Its 2.5K rear view is nothing to scoff at, either. What’s more, the 1080P bumper-wide field of view captures every detail.[4]
- Dual sensors: You can see clear footage day and night, thanks to the front Sony STARVIS 2 IMX678 and rear Omnivision Purecel® Plus OS04J10 sensors.
- WiFi and app control: Transfer, share, view, and download videos on your phone with the WOLFBOX G900 TriPro Bumper Dash Cam WiFi and app control feature.
- Broad exterior coverage: Bumper installation flexibility provides a broader, more unobstructed rear view, ideal for towing, parking, large trucks, and off-road use.
It comes with:
- G900TriPro Bumper
- 2.5K rear camera
- 33-foot longer replacement cables
- Accessories
- 11.5-foot power supply cable
- Rubber straps
- 1080P extra bumper camera
- 21-foot bumper camera cable
- GPS module
- Basic pack: 4A hardwire kit
- Extended pack: 4a hardwire kit, polarizing lens, rear camera plate bracket, OEM bracket, 18-month extended warranty
WOLFBOX G900 Pro
The WOLFBOX G900 Pro is a simpler alternative to the WOLFBOX G900 Bumper Dash Cam. If you’re a truck owner who needs high-resolution front and rear recording without the extra bumper camera installation, the WOLFBOX G900 Pro is worth considering.
- 4K front resolution, 2.5k rear resolution
- 12-inch display
- Waterproof IP67 rear camera
- Voice control
- GPS
- Support for up to 512GB microSD
- Reverse assist
It comes with:
Extended package:
- G900Pro
- Hardwire kit
- Polarizing lens
- Rear cam bracket
- One-year warranty
Basic package:
- G900Pro
- Hardwire kit
- 2.5K rear camera
- Car wire trim tool
Truck camper package:
- G900Pro
- Hardwire kit
- 2.5K rear camera
- 10-foot extension cable
WOLFBOX G840S
The WOLFBOX G840S is a more budget-friendly dash cam option for Silverado owners and other large-truck drivers who want a large rear-view display with front and rear recording. It combines the functionality of a mirror dash cam with a straightforward setup, making it a practical choice for everyday driving.[5]
Classed as more of an entry-level dash cam than its G900TriPro Bumper and G900Pro counterparts, the G840S is simple yet effective in its technology and installation.
- 4K exported video files
- Large mirror display
- Front/rear recording
- Backup camera functionality
- Simple installation
- Lower complexity
It comes with:
- 12-inch mirror dash cam
- 1080P rear camera
- Car wire trim too
- 20-foot rear camera cable
WOLFBOX X5 Duo
If you use your pick-up truck for commuting rather than hauling and off-roading, a simple, compact dash cam like the WOLFBOX X5 Duo could be the solution you need. The X5 Duo is a small windshield-mounted system with a 4K front and 2.5K rear camera that suits truck owners with no need or desire for a mirror-style dash cam.[6]
- 4K front camera, 2.5K rear camera at 30 FPS
- Image stabilization
- Two-channel HDR
- STARVIS 2™ tech for night vision
- Smart voice control
- Built-in WiFi app control
- GPS route tracking
- Loop recording
- Smart touch screen
It comes with:
- X5 Duo Dash Cam
- GPS bracket
- 2.5K rear camera
- Adhesive mount
- USB-C power cable
- Rear cam cable
- USB-C power/data cable
- User manual
At a Glance: WOLFBOX Dash Cam Comparison
Dash Cam Model |
Front Camera |
Rear Camera |
Extra Camera |
Display |
Best For |
G900TriPro Bumper |
4K
2.5K |
1080P bumper |
12 inches |
Maximum truck coverage |
G900Pro |
4K |
2.5K |
N/A |
12 inches |
Front and rear recording |
G840S |
4K (video download) |
1080P |
N/A |
12 inches |
A simple mirror setup |
X5 Duo |
4K |
2.5K |
N/A |
2.35 inches |
A traditional dashcam setup |
Purchasing a Dash Cam: G900TriPro Bumper vs. G900 Pro vs. G840 S vs. X5 Duo
Based on the challenges that Chevy owners face during daily commutes, off-road adventures, and hauling goods, the best dash cam for large pickup trucks is the G900TriPro Bumper.
It solves one of the most common complaints: an obstructed rear camera view. This dash cam solves this issue by adding a dedicated bumper camera that provides a direct view behind the truck, rather than mostly showing the bed. This angle is especially useful when towing, driving off-road, and parking.
1. What is the best dash cam for a Chevy Silverado?
For many Chevy Silverado owners seeking a three-channel system with unobstructed rear views, the WOLFBOX G900TriPro Bumper is the best dash cam.
2. What’s the difference between the WOLFBOX G900TriPro and the WOLFBOX G900 Pro?
The WolfBox G900Pro is a dual-channel mirror dash cam, whereas the WOLFBOX G900TriPro Bumper is a three-channel system. It supports an extra cabin or bumper camera for unobstructed rear views beyond the truck bed.
3. Does the WOLFBOX G900 have GPS?
Yes. It includes GPS functionality to record your vehicle’s driving route, speed, and direction.[7]
4. Is a mirror dash cam better than a traditional dash cam?
Yes. If you’re a truck driver with or without a towed load, a mirror dash cam provides a more direct view of the road and vehicle.
5. Does the G900 dash cam work at night?
Yes. The WOLFBOX G900 dash cam is designed for driving in night-time and low-light conditions.
- WOLFBOX G900TriPro Bumper Version https://wolfbox.com/products/wolfbox-g900tripro-bumper-version-3-channel-rearview-mirror
- Automotive Interiors World - WOLFBOX New Dash Cam Technology https://www.automotiveinteriorsworld.com/news/wolfbox-launches-new-dashcam-technology-to-aftermarket.html
- WOLFBOX G900 Pro https://wolfbox.com/products/wolfbox-2024-g900-pro-wifi-touch-screen-parking-monitoring-dash-cam-smart-mirror-with-starvis-678-sensor
- RVTravel - Best RV Backup Camera https://www.rvtravel.com/video-best-rv-backup-camera-2671/
- WOLFBOX G840S https://wolfbox.com/products/wolfbox-g840s-12-4k-mirror-dash-cam-2160p-full-hd-smart-rear-view-camera-mirror-dash-cam
- WOLFBOX X5 Duo https://wolfbox.com/products/wolfbox-x5-duo-4k-2-5k-starvis-2-imx678-front-and-rear-mini-dash-cam
- Autoblog - WOLFBOX Aftermarket Upgrades for Jeep Wrangler https://www.autoblog.com/features/jeep-wrangler-aftermarket-upgrades-wolfbox
