Choosing the best dash cam for a Ford Bronco comes down to how the vehicle is actually used. The WOLFBOX G900TriPro Bumper and WOLFBOX G900Pro both offer high-resolution front and rear recording, but they are built around slightly different priorities. The WOLFBOX G900TriPro Bumper adds a third camera mounted low at the front, while the WOLFBOX G900Pro keeps things simpler with a two-camera setup.[1][2]
Trail use is where the WOLFBOX G900TriPro Bumper starts to separate itself. On a steep climb, a Bronco's hood can block the driver's view of rocks, ruts, and the next few feet of terrain. The low-mounted bumper camera adds another view of that area, which can be particularly useful on forest roads and technical trails.[1][5]
The WOLFBOX G900Pro still makes a strong case for Broncos that spend most of their time on pavement. Daily driving, fall road trips, and occasional gravel-road use do not necessarily require another exterior camera, so the simpler setup may be the better fit for owners who do not need that low trail view.[2]
The Short Answer
The WOLFBOX G900TriPro Bumper is our top pick for a Ford Bronco that regularly goes off-road, while the WOLFBOX G900Pro is the better fit for a Bronco used mainly on pavement. Both record 4K, or 3840 × 2160 pixels, at the front and 2.5K, or 2560 × 1440 pixels, at the rear.[1][2]
The difference is the third camera. The WOLFBOX G900TriPro Bumper adds a 1080p, or 1920 × 1080 pixel, camera mounted low at the front, giving the driver another view of terrain that can disappear beneath the Bronco's hood.[1][5] The WOLFBOX G900Pro skips that extra camera and the installation work that comes with it, making the simpler setup easier to justify for road-focused owners.[2]
WOLFBOX G900TriPro Bumper vs WOLFBOX G900Pro: Key Specifications
The basic front and rear recording setup is very similar on both cameras. The WOLFBOX G900TriPro Bumper and WOLFBOX G900Pro both use a Sony IMX678 front image sensor, the light-capturing component behind the camera, and both record 4K at the front and 2.5K at the rear.[1][2] Both also use 5.8GHz Wi-Fi for phone connectivity.[1][2] Parking monitoring requires a hardwire connection to the Bronco's fuse box on either model.[1][2]
Specification |
WOLFBOX G900TriPro Bumper |
WOLFBOX G900Pro |
Recording channels |
3: front, rear, bumper [1] |
2: front, rear [2] |
Front recording |
4K, 3840 × 2160 [1] |
4K, 3840 × 2160 [2] |
Rear recording |
2.5K, 2560 × 1440 [1] |
2.5K, 2560 × 1440 [2] |
Additional camera |
1080p bumper camera [1] |
None [2] |
Display |
12-inch touchscreen [1] |
12-inch touchscreen [2] |
Wi-Fi |
5.8GHz wireless connection [1] |
5.8GHz wireless connection [2] |
Voice control |
Yes [1] |
Yes [2] |
GPS |
Supported [1] |
Supported [2] |
Maximum storage |
Up to 512GB [1] |
Up to 512GB [2] |
Parking monitoring |
Fuse-box hardwire connection required [1] |
Fuse-box hardwire connection required [2] |
The numbers make the buying decision simpler than the feature lists might suggest. The WOLFBOX G900TriPro Bumper does not have an advantage because of a larger front-camera resolution number, since the WOLFBOX G900Pro offers the same 4K front and 2.5K rear recording.[1][2] What matters is whether another view at bumper height solves a problem the driver actually has.
Why the Bumper Camera Matters on a Bronco
Mounting the third camera at bumper height gives it a very different view. The WOLFBOX G900TriPro Bumper uses a 1080p exterior camera mounted low at the front, and that camera carries an IP67 rating, meaning the enclosure is designed to resist dust and temporary water immersion under the conditions covered by the rating.[1] The position puts the view much closer to the trail surface than the windshield camera.
Steep climbs are where the extra camera starts earning its keep. Bronco Nation testing of the WOLFBOX G900TriPro Bumper described using the low view to see rocks, ruts, and drop-offs immediately ahead, particularly on a Bronco without a factory front camera.[5] International Business Times highlighted a similar benefit when discussing the WOLFBOX G900TriPro Bumper on rocky terrain and muddy back roads.[3]
The extra camera still has its limits. The WOLFBOX G900TriPro Bumper should be treated as another source of information rather than a replacement for a spotter, because a screen cannot judge every obstacle, tire position, underbody clearance, or changing trail condition. Difficult terrain still calls for normal off-road judgment.
Factory camera equipment can also make the third channel less important. The WOLFBOX G900TriPro Bumper adds less to a Bronco already equipped with Ford's 360-degree camera system, which Ford lists on certain 2026 Bronco trims and packages.[6] On a Bronco without a useful factory forward view, the low-mounted WOLFBOX camera has a much clearer reason to be there.
The WOLFBOX G900Pro Makes More Sense on the Road
If trail visibility is not a priority, the comparison gets much easier. The WOLFBOX G900Pro still provides 4K front and 2.5K rear recording, a 12-inch touchscreen, GPS, voice control, and 5.8GHz Wi-Fi for transferring footage to a phone.[2] Those are the features most likely to matter during commuting, highway driving, and long road trips.
Independent testing backs up that road-focused argument. TechRadar praised the WOLFBOX G900Pro's 4K front footage, rear-camera detail, bright display, and wireless transfer performance during testing.[4]
For everyday driving, the WOLFBOX G900Pro already provides the core features most Bronco owners need, including high-resolution front and rear recording, GPS, a large 12-inch display, voice control, and convenient footage transfer. For commuting, highway driving, road trips, and other routine driving situations, its capabilities are sufficient.
The Extra Camera Comes With Extra Installation
The third camera adds a few extra installation steps, mainly because the WOLFBOX G900TriPro Bumper uses an exterior front camera that connects back to the mirror system. The camera needs to be mounted in a suitable position and the cable routed into the vehicle, but the overall installation remains relatively straightforward with proper cable routing and mounting.[1][5]
The WOLFBOX G900Pro also requires some wiring, including the mirror display, rear camera, power connection, and GPS hardware. TechRadar noted the wiring involved during installation, but the setup does not require complicated modifications to the vehicle.[4]
Parking monitoring requires one additional step on both the WOLFBOX G900TriPro Bumper and G900Pro: connecting a hardwire kit to the Bronco's fuse box so the system can receive power while the vehicle is parked.[1][2] Owners who do not want to hardwire the Bronco should not expect parking monitoring to work in the same way as normal driving recording.
Which WOLFBOX Dash Cam Should a Bronco Owner Buy?
Regular trail use is the strongest reason to choose the three-camera setup. The WOLFBOX G900TriPro Bumper makes particular sense on a Bronco without a useful factory forward camera, where the low-mounted third channel has a clear job instead of duplicating an existing view.[5][6]
Daily driving points the other way. The WOLFBOX G900Pro keeps the front and rear recording, digital-mirror display, and connected features that matter on the road without adding exterior hardware the owner may rarely use.[2][4]
Neither model is automatically the right choice just because a Bronco can go off-road. The WOLFBOX G900TriPro Bumper is harder to justify when the vehicle rarely leaves pavement, while the WOLFBOX G900Pro gives up the low forward view that can be useful on steep or technical trails.[1][2]
Final Verdict
The third camera gives the WOLFBOX G900TriPro Bumper a genuine reason to exist on a trail-driven Bronco. The WOLFBOX G900TriPro Bumper keeps strong front and rear recording for normal driving, then adds another perspective for the moments when the pavement disappears and the hood starts hiding the ground ahead.[1][5]
For mostly road use, simpler is probably better. The WOLFBOX G900Pro gives up the bumper view but keeps the recording quality, digital-mirror display, and connected features that matter during ordinary driving.[2][4] The decision ultimately comes down to whether the Bronco spends enough time on trails to make that third camera worth installing.
What is the best dash cam for a Ford Bronco?
The WOLFBOX G900TriPro Bumper is our preferred option for a Ford Bronco that regularly goes off-road. The WOLFBOX G900TriPro Bumper adds a 1080p bumper camera to the front and rear recording system, giving the driver another view when the trail disappears beneath the hood on steep climbs.[1][5]
Does the WOLFBOX G900TriPro Bumper record in 4K?
Yes. The WOLFBOX G900TriPro Bumper records the main front view at 3840 × 2160, commonly called 4K, while the rear camera records at 2.5K and the bumper camera records at 1080p.[1]
Is the WOLFBOX G900TriPro Bumper camera useful for off-roading?
Yes. The WOLFBOX G900TriPro Bumper camera can show rocks, ruts, and terrain immediately ahead when the Bronco's hood blocks the normal view, although the additional camera should not replace a spotter on difficult obstacles.[3][5]
Is the WOLFBOX G900Pro better for daily driving?
The WOLFBOX G900Pro is the simpler choice for a road-focused Bronco. The WOLFBOX G900Pro keeps 4K front and 2.5K rear recording without requiring the additional bumper-camera installation used by the three-channel system.[2][4]
Does parking mode require hardwiring?
Yes. The WOLFBOX G900TriPro Bumper and WOLFBOX G900Pro require a fuse-box hardwire connection for parking monitoring while the vehicle is switched off.[1][2]
[1] WOLFBOX, “WOLFBOX G900TriPro Bumper Version” https://wolfbox.com/products/wolfbox-g900tripro-bumper-version-3-channel-rearview-mirror
[2] WOLFBOX, “WOLFBOX G900Pro” https://wolfbox.com/products/wolfbox-2024-g900-pro-wifi-touch-screen-parking-monitoring-dash-cam-smart-mirror-with-starvis-678-sensor
[3] International Business Times, “Adventure Ready: How the G900 TriPro's Bumper Cam Takes Off-Roading to the Next Level” https://www.ibtimes.com/adventure-ready-how-g900-tripros-bumper-cam-takes-off-roading-next-level-3780706
[4] TechRadar, “Wolfbox G900 Pro is a high-quality mirror dash cam, but just be sure it's the right fit for your vehicle” https://www.techradar.com/vehicle-tech/dash-cams/wolfbox-g900-pro-dash-cam-review
[5] Bronco Nation, “Wolfbox G900 Tri Pro - Install & Review: Is The Front Bumper 3rd Camera Worth It?” https://thebronconation.com/accessories-n.136/wolfbox-g900-tri-pro-install-review-is-the-front-bumper-3rd-camera-worth-it-t.22616/
[6] Ford, “2026 Ford Bronco SUV” https://www.ford.com/suvs/bronco/
