Dash cams are a very important thing to have and are becoming more and more common in cars. They can record what is happening on the road and will help you in case of an accident. But a question that many people ask is should I get a front dash cam or a rear dash cam? Or do I need both? This article will look at the differences between front and rear dash cams and will help you decide which one is right for you.
Why Choose a Dash Cam?
Dash cams are very useful devices that can record video and capture events when you are driving. They can help you in many ways like providing evidence in case of accidents and capturing interesting moments on the road. You can also use the dash cameras to capture your journeys. You can later use these recordings to make the vlog as well. You can also view the recordings to improve your driving.
Importance of Dash Cams in Modern Driving
In today’s busy roads, accidents can happen at any time and anywhere. If you have a dash cam, they will record these accidents and can act as an independent witness by recording exactly what happened. This recording will help you with insurance claims, legal disputes or even just remembering a road trip. Now a days, insurance frauds are becoming very common and people get charged for that. But with the dash cams, you can prove your innocence.
Read More:
How Do Dash Cams Work?
What is a Front Dash Cam?
A front dash cam is a camera that you mount on your front windshield of your car. You can use it to record the road ahead of you. This is the most common type of dash cam and almost everyone using the dashcam has it.
Features
Feature | Description |
Wide Angle Lens | They can capture a wide view of the road between 140-170 degrees. |
High-Resolution Recording | They can record clear video in 1080p or higher resolution. |
Loop Recording | This mode will overwrite the old footage when the memory card is full. |
G-Sensor | It can detect impacts and saves the recording permanently. |
Night Vision | They can even record clear video in low-light conditions. |
Benefits
Evidence in Front-End Collisions: In case you are involved in an accident, you can use Front dashcam as clear evidence of what happened in front-end accidents.
Protection Against False Claims: They can also protect you from false insurance claims by showing what actually happened.
- Recording Road Incidents: You can use these cameras to record road rage incidents, reckless driving or other events on the road. The cameras with higher resolution can also capture number plates which will be very helpful for you.
Ideal Use Cases for Front Dash Cams
Front dash cams are good for:
- Daily commuters who want to protect themselves from accidents.
- If you drive in busy areas with heavy traffic.
- People who just want to record their road trips.
What is a Rear Dash Cam?
Features
Wide Angle Lens | They can capture a wide view of what’s behind your car. |
Weatherproof Design (for external cameras) | They are made to withstand rain, snow, and other weather conditions. |
Night Vision | They can also record clear video in low-light conditions. |
Benefits
Rear dash cams offer these benefits:
Evidence in Rear-End Collisions: If a car hit you from behind, these cameras can be used for clear evidence of what happened in rear-end accidents.
Protection Against Tailgating: They can also record events like tailgating by other drivers.
- Recording Parking Incidents: You can use them to record incidents that happen while your car is parked such as hit-and-runs.
Ideal Use Cases for Rear Dash Cams
Rear dash cams are good for:
- People who park their cars in public places.
- If you are concerned about tailgating.
- People who want extra protection against accidents.
Front vs. Rear Dash Cam: Key Differences
Both front and rear dash cams have their own advantages. But their usage depends on what features you want and the level of protection you are looking for.
Coverage and Angle of View
Front dash cams focus on what is in front of your car, while rear dash cams focus on what is happening behind your car. The angle of view is also different for both cameras. Front dash cams have a wider angle to capture more of the road ahead as compared to rear dashcams.
Protection from Accidents
Front dash cams are best for recording accidents that happen in front of you. You can use rear dash cams to record rear-end collisions and tail-gating incidents.
Evidence for Insurance Claims
You can use both front and rear dash cams for important evidence for insurance claims depending on the type of accident you were involved in. Make sure to secure the videos after the incident so you can have them whenever you need.
Is a Front or Rear Dash Cam More Important?
Both front and rear dash cams are important for the safety of your car. They can record whatever happens around the car from both front and back. A front dash cam can help you prove your innocence in a front-end collision and a rear dash cam can do the same for a rear-end collision.
Scenarios Where Each Camera is Crucial
If you are driving safely and the car in the front pressed the brakes suddenly, you might be accused of accident from behind such as over speeding. With a proper record of the event, you will be able to prove your innocence. Whereas if a car is tailgating you are hit you when over speeding, you can use the rear dash cam recording to claim insurance.
Do You Need Both Front and Rear Dash Cams?
Having both front and rear dash cams can be very useful in many events. They will record every event happening around your car and protect it.
Advantages of a Dual Dash Cam Setup
While one camera can do the work, having more is always recommended. A dual dash cam setup will provide complete coverage of what happens around your car. You can use them in complex accident scenarios like getting rear accident in case of traffic jam. You can also use them to record everything that happens while you drive.
When a Rear Dash Cam Becomes Essential
- When you are Parking your car in areas where it is likely to get hit.
- If you drive in areas with high traffic density.
- If you want the best protection against all types of accidents.
Factors to Consider When Choosing a Dash Cam
Driving Habits and Lifestyle
Budget and Installation
Dash cams are available in different price ranges. Basic front dash cams are cheaper than rear or dual dash cam setups. You must buy the camera after considering your budget and whether you want to install the dash cam yourself or have it professionally installed.
Wolfbox Front and Rear Dash Cams
Wolfbox makes many good dash cams with options for both front and rear recording.
Wolfbox G900 Pro
The Wolfbox G900 Pro is a high-quality dash cam that can record in 4K resolution to capture videos with great details. It can also give you clear video and has features like night vision and parking mode for better safety and recording.
Feature | Specification |
Front Camera | 4K |
Rear Camera | 2.5K (1440p) |
Night Vision | Yes |
GPS | Yes |
Parking Mode | Yes |
Wolfbox G900
The Wolfbox G900 is another great camera by Wolfbox that can record videos in high 4K resolution. It has many of the same features as the G900 Pro but at a more affordable price.
Front Camera | 4K |
GPS | Yes |
Wolfbox G850
The Wolfbox G850 is a good choice if you want a dashcam with both front and rear recording. It also has Wi-Fi connectivity with which you can upload videos on cloud and view them anywhere. With this feature, you can get alarms and notifications if something happens to your car when it’s parked.
Front Camera | 4K |
Rear Camera | 1080p |
Wi-Fi | Yes |
Which Dash Cam is Right for You?
Choosing between a front and rear dash cam depends on your needs and budget. A front dash cam is a good starting point for most drivers, whereas a dual dash cam setup provides the best protection. Wolfbox offers a range of dash cams that can meet your needs.
