A jump starter with a built-in air compressor covers two common roadside problems, a dead battery and a low tire, in a single case. This review of the WOLFBOX MegaVolt 24Air and the WOLFBOX MegaVolt 10Air brings together tests from Popular Science, Car and Driver, and TechGearLab, an owner report from the Expedition Portal forum, and the specifications on the official WOLFBOX product pages. It is written for drivers deciding whether a WOLFBOX jump starter with air compressor is worth buying and which model fits their vehicle.
Is a WOLFBOX Jump Starter Good? The Short Answer
Yes, independent testing supports the WOLFBOX MegaVolt 24Air as a capable 4-in-1 jump starter, air compressor, power bank, and flashlight, and the WOLFBOX MegaVolt 10Air is the smaller, lower-power option for smaller engines, as long as the model matches the engine. The MegaVolt 24Air is rated at 4000A peak (the maximum short burst of current a jump starter can deliver) and carries an 88.8 Wh battery (watt-hours, a measure of stored energy) for gasoline engines up to 10L [1]. The MegaVolt 10Air is rated at 2000A peak with a 37 Wh battery for gasoline engines up to 5.0L [2].
Popular Science jump-started a crossover SUV, a six-cylinder pickup, and a diesel-powered F-350 shop truck with the WOLFBOX MegaVolt 24Air and called the MegaVolt 24Air "a great option for any car emergency kit" [3]. Car and Driver named the WOLFBOX MegaVolt 24Air its Best Inflator/Jumper Combo after timing the unit against a field of portable tire inflators [4].
What Is the WOLFBOX MegaVolt Air Series?
The WOLFBOX MegaVolt Air series is a line of 4-in-1 devices that combine a lithium jump starter, an air compressor (tire inflator), a USB power bank, and an LED flashlight in one case [1][2]. The WOLFBOX MegaVolt 10Air and WOLFBOX MegaVolt 24Air differ mainly in battery size, starting power, and compressor output, and those three specs determine which engines each can start and how quickly each can fill a tire [1][2].
Four terms explain most of the WOLFBOX MegaVolt 24Air and MegaVolt 10Air spec sheets. Peak amps has no industry standard for how brands measure it, so engine-size ratings and real tests are better guides than the headline number [5]. Watt-hours (Wh) show how much energy is stored, so a larger figure means more energy for starts, inflation, and charging devices [1][2]. PSI (pounds per square inch) is tire pressure, and Popular Science notes most passenger vehicles run between 30 and 45 PSI [3]. Airflow in liters per minute (L/min) shows how much air the compressor moves, so a higher figure fills a tire faster [1].
MegaVolt 24Air vs MegaVolt 10Air: How Do the Specs Compare?
The WOLFBOX MegaVolt 24Air has twice the peak current and more than twice the battery capacity of the WOLFBOX MegaVolt 10Air, and that gap decides which vehicles each model can serve [1][2].
Spec |
MegaVolt 10Air |
MegaVolt 24Air |
Peak current |
2000A |
4000A |
Gasoline engine rating |
Up to 5.0L |
Up to 10L |
Battery |
37 Wh |
24,000 mAh / 88.8 Wh |
Starts per charge |
Up to 30 |
Up to 40 (3.0L gasoline vehicle) |
Air compressor max pressure |
150 PSI |
160 PSI |
Airflow |
45 L/min |
USB-C port |
15W, input only |
65W PD, input and output |
USB-A output |
12W |
18W |
LED flashlight |
200 lumens |
400 lumens |
Operating temperature |
-4°F to 140°F |
-4°F to 140°F |
Dust and water rating |
IP64 |
IP64 |
Listed vehicle types |
Sedan, motorcycle, bike |
Sedan, SUV, pickup, motorcycle, bike |
Warranty |
24 months (30 months when ordered from wolfbox.com) |
What Do Independent Reviewers Say About the MegaVolt 24Air?
The WOLFBOX MegaVolt 24Air has been tested by a science magazine, an automotive magazine, and a forum owner, and each focused on a different job: starting, inflating, and everyday use [3][4][6].
What Did Popular Science Find in a Real-World Emergency?
Popular Science reported on February 11, 2026 that the WOLFBOX MegaVolt 24Air fired up a stranger's midsize SUV almost immediately in 0-degree winter weather [3]. Reviewer Stan Horaczek said the unit jump-started three vehicles in total: a crossover SUV in the bakery parking lot, a six-cylinder pickup, and a diesel-powered F-350 shop truck that had sat too long [3]. The WOLFBOX MegaVolt 24Air still had enough charge to start again after the hardest start [3]. The review lists real inflator performance and a high-output USB-C power bank among the strengths, and says the 65W USB-C and 18W USB-A outputs make the unit "legitimately useful beyond phones" [3].
How Did Car and Driver Rate the MegaVolt 24Air as an Inflator?
Car and Driver named the WOLFBOX MegaVolt 24Air its Best Inflator/Jumper Combo in a tire inflator test updated in February 2026, placing the unit fourth-fastest behind the Milwaukee, Slime, and Viair inflators [4]. The editors praised the sturdy build, tactile buttons, and included carrying case of the WOLFBOX MegaVolt 24Air, and they listed a short hose as the only con [4].
What Did an Expedition Portal Owner Report After Two Weeks?
An Expedition Portal member reported in June 2026 that the WOLFBOX MegaVolt 24Air held a full 100 percent charge after sitting unused for more than 10 days, while the owner's earlier packs had shown charge loss by day 7 [6]. The same owner charged a phone in about 30 minutes and a tablet in about 35 minutes at the same time [6]. The owner did not test the jump function because no vehicle with a weak battery was available, and concluded that the unit gets the job done for the average overlander but is not recommended for rock crawlers with oversized tires [6].
How Do Inflation Times Compare Across Tests?
Inflation time depends mostly on tire size and how many PSI are added, so the WOLFBOX MegaVolt 24Air results below are consistent rather than contradictory [1][3][4][6].
Source |
Tire |
Pressure change |
Time |
WOLFBOX product page [1] |
275/75R17 SUV tire |
30 to 36 PSI |
1 min 40 sec |
37×12.5R17 pickup truck tire |
35 to 40 PSI |
1 min 50 sec |
195/65R15 sedan tire |
30 to 36 PSI |
39 sec |
Popular Science [3] |
SUV tire (size not stated) |
25 to 35 PSI |
About 1 min |
Car and Driver [4] |
245/50 R20 tire |
Starting at 10 PSI |
3 min 12 sec to reach 30 PSI, 6 min 10 sec to reach 45 PSI |
Expedition Portal owner [6] |
17-inch mud-terrain tires |
16 to 37 PSI |
About 6 min 30 sec |
Adding 5 to 10 PSI to passenger and SUV tires takes roughly 40 seconds to under 2 minutes per the WOLFBOX product page and Popular Science's on-the-road test, while filling a tire from a very low starting pressure takes about 3 to 6.5 minutes in Car and Driver's bench test and the forum owner's real-world use [1][3][4][6]. For how many tires one charge can fill on each model, see WOLFBOX's guide, How Many Tires Can a Jump Starter Inflate on One Charge?.
Which Model Fits Your Vehicle: MegaVolt 10Air or MegaVolt 24Air?
The WOLFBOX MegaVolt 24Air fits SUVs, pickups, and larger engines, while the WOLFBOX MegaVolt 10Air fits sedans, motorcycles, and tight storage. Engine displacement should drive the choice.
Which Vehicles Suit the MegaVolt 24Air?
Choose the WOLFBOX MegaVolt 24Air if your vehicle has a gasoline engine larger than 5.0L or if you drive an SUV or pickup. It supports gasoline engines up to 10L and is suitable for larger vehicles. Its 65W USB-C Power Delivery port also provides portable charging for devices beyond phones, a feature that Popular Science described as "legitimately useful beyond phones." [1][3].
Which Vehicles Suit the MegaVolt 10Air?
Choose the WOLFBOX MegaVolt 10Air if your vehicle has a gasoline engine of 5.0L or smaller and you have limited storage space. With 2000A peak current, it is suitable for sedans, motorcycles, and bikes. Its 37Wh battery offers less than half the capacity of the MegaVolt 24Air. [1][2].
Does a Built-In Compressor Weaken the Jump Starter?
The MegaVolt 24Air combines jump-starting and tire inflation in one device. Popular Science described it as "not just a jump starter that happens to have an inflator." [3] TechGearLab noted that adding a compressor can sometimes result in "two mediocre performances," but described the WOLFBOX MegaVolt16 Air as "a can't-go-wrong package." [5]
What Are the Downsides of the WOLFBOX MegaVolt Air Series?
The WOLFBOX MegaVolt 24Air offers convenient jump-starting and tire inflation in one portable device. A few usage considerations are worth noting:
- Hose length: The 20-inch inflation hose may feel a little short when reaching the tires on some larger vehicles. [3][4]
- Operating noise: The air compressor produces noticeable noise during inflation. Car and Driver measured 84.0 dBA during operation. [4]
- Off-road use: For off-road drivers who frequently air down and reinflate oversized tires, especially when managing multiple tires in succession, a dedicated high-capacity air compressor may be more suitable. [6]
Frequently Asked Questions About WOLFBOX Jump Starters
Is a WOLFBOX jump starter good?
Yes, for most drivers, provided the model matches the engine size. Popular Science and TechGearLab reported strong jump-starting results for WOLFBOX models, and Car and Driver named the WOLFBOX MegaVolt 24Air its best inflator and jump starter combo [3][4][5].
Can the WOLFBOX MegaVolt 10Air start an SUV or pickup?
Only if the engine is within 5.0L gasoline. WOLFBOX lists sedans, motorcycles, and bikes as the vehicle types for the WOLFBOX MegaVolt 10Air, and SUVs and pickups for the WOLFBOX MegaVolt 24Air [1][2].
Can the WOLFBOX MegaVolt 24Air start a diesel truck?
Yes, in one published test. Popular Science jump-started a diesel-powered F-350 shop truck with the WOLFBOX MegaVolt 24Air, but diesel limits are listed separately on the WOLFBOX product page and should be checked for the specific engine [1][3].
Can a WOLFBOX MegaVolt jump starter charge a tablet or other larger devices?
Yes, with the WOLFBOX MegaVolt 24Air. The MegaVolt 24Air has a USB-C port rated for 65W Power Delivery in and out, and an Expedition Portal owner charged a tablet in about 35 minutes [1][6]. The WOLFBOX MegaVolt 10Air has a 12W USB-A output, and the 15W USB-C port is input only [2].
Does a WOLFBOX MegaVolt jump starter hold its charge in storage?
Yes, but top up the pack periodically. Popular Science reported that the WOLFBOX MegaVolt 24Air kept a charge for several weeks through winter temperature swings and recommended topping up the pack every six months, and the Expedition Portal owner measured 100 percent after more than 10 idle days [3][6].
Does the WOLFBOX MegaVolt 24Air work in freezing weather?
Yes, down to the rated limit. WOLFBOX lists an operating range of -4°F to 140°F for the WOLFBOX MegaVolt 24Air, and Popular Science reported the unit working at 0°F [1][3].
Is a WOLFBOX MegaVolt jump starter safe?
The WOLFBOX MegaVolt 24Air features 10 built-in safety protections to help ensure safe and reliable operation. [1]
What warranty comes with the WOLFBOX MegaVolt 10Air and 24Air?
Both models come with a 24-month base warranty, and orders placed through wolfbox.com receive an additional 6 months for a total of 30 months. [1][2].
Final Verdict: Is a WOLFBOX MegaVolt Air Jump Starter Worth Buying in 2026?
The WOLFBOX MegaVolt 24Air is worth buying for SUV, pickup, and larger-engine owners who want one case for starting, inflating, and charging, and the WOLFBOX MegaVolt 10Air is worth considering for sedan and motorcycle owners who accept thinner independent evidence. Skip both WOLFBOX MegaVolt models if the use is rock crawling with oversized tires, if a diesel engine's displacement exceeds the limit on the product page, or if the lightest possible pack matters most [1][2][6].
Before buying a WOLFBOX MegaVolt unit, run four checks:
- Compare the engine's displacement with the rated limit on the product page [1][2].
- Check that the 20-inch hose on the MegaVolt 24Air reaches the valve stem on the largest tires [3][4].
- Plan to top up the pack every six months [3].
- Store the pack in a heated space during sub-zero cold.
[1] WOLFBOX. MegaVolt 24Air Jump Starter with Air Compressor. Official product page, accessed November 18, 2026. https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
[2] WOLFBOX. MegaVolt 10Air | 4-in-1 Jump Starter with Air Compressor | 2000A. Official product page, accessed November 18, 2026. https://wolfbox.com/products/wolfbox-2000a-jump-starter-with-air-compressor-wolfbox-megavolt-10air
[3] Popular Science. I tested the Wolfbox 4-in-1 Jump Starter with Air Compressor during a real-world emergency. Stan Horaczek, February 11, 2026. Independent editorial review. https://www.popsci.com/gear/wolfbox-4-in-1-jump-starter-with-air-compressor-review/
[4] Car and Driver. Best Portable Tire Inflators of 2026, Tested. Jon Langston, updated February 17, 2026. Independent product test. https://www.caranddriver.com/car-accessories/g42589683/best-portable-tire-inflators-tested/
[5] TechGearLab. The Best Jump Starters of 2026. Chris Maxcer, updated April 29, 2026. Independent lab test. https://www.techgearlab.com/topics/tools/best-jump-starter
[6] Expedition Portal Forum. Wolfbox MegaVolt 24 Air Compressor/Jump Starter Review. Thread by FrenchieXJ, June 13, 2026. Owner report. https://forum.expeditionportal.com/threads/wolfbox-megavolt-24-air-compressor-jump-starter-review.251435/
