How to Install a Rear Dash Cam in Your Car
Your dash cam videos can only tell half the story if you don’t have rear footage. Rear cameras can help you record what happened behind your car during incidents, parking or highway traffic. When you know how to install a rear dash cam in your car, you get a complete view of what might have happened.
If you want to capture more angles and feel safer on the road, you can go for a rear dash cam, which is one of the best decisions you can make. This guide will help you understand why it matters and how to install a rear dash cam by yourself.
Why Should I Add a Rear Dash Cam?
Before you begin, here are some key reasons why a rear camera improves your driving experience.
Expanded Safety Coverage
With a rear camera, you can record the vehicles behind you. This helps if someone hits your car from behind and tries to claim it was your fault. Your rear dash cam videos offer clear proof.
Better Parking Assistance
Rear cameras help while reversing or parallel parking. You can avoid hitting objects behind your car. Some models from Wolfbox even display real-time video to your screen for better control.
More Protection When Parked
When your dash cam supports parking mode, rear coverage captures break-ins or bumps. Dash cam videos from the rear camera can show license plates or the person behind damage.
Ideal for Ride-Sharing and Fleets
If you drive for a rideshare service or run a small fleet, rear dash cams protect you and your passengers. You get full visual evidence if something happens in or around your car.
Peace of Mind in Heavy Traffic
On highways or in bumper-to-bumper traffic, rear dash cams capture tailgaters or drivers who may try dangerous maneuvers. Understanding how to install dash cam with a rear camera will help you get the full picture.
Tools and Materials Needed for Rear Dash Cam Installation
You will need several tools and items to complete your rear camera setup neatly and safely.
  • Rear Dash Cam Unit: This is the actual camera that records the back view. It connects to your front dash cam or display.
  • Power Cable: Supplies power from your fuse box or front camera.
  • Video Cable (Long): Transfers video from the rear camera to the front unit. Trucks and SUVs might need longer cables.
  • Fuse Tap Kit: Lets you connect your dash cam safely to your car’s fuse box for power.
  • Trim Removal Tool: Helps you lift panels without damage to hide wires.
  • Cable Clips or Zip Ties: Keeps your wires in place so they don’t hang loosely.
  • Alcohol Wipes or Cleaner: Cleans the surface before mounting your camera.
  • Double-Sided Tape or Screws: Used to mount the rear camera on your windshield or rear window.
How to Install a Rear Dash Cam in Your Car: General Steps
Let’s walk through how to install a rear dash cam in your car in a sedan or small car. Each step is important for a clean and working result.
Plan the Cable Route
Start by deciding how the video and power cables will travel from the front to the rear of your car. Tuck the wires under the roof lining, side panels, or along the floor.
Mount the Rear Camera
Clean the inside of your rear window with alcohol wipes. Peel off the tape and stick the camera firmly in place. Mount it near the center, just above the rear defrost lines for a balanced view.
Run the Video Cable
Run the video cable from the rear camera to the front camera. Tuck it under the roof liner or carpet trim using a trim removal tool. Secure with clips or zip ties.
Connect the Cable to the Front Unit
Plug the video cable into the main dash cam or display unit. Make sure the connection is tight. Most Wolfbox cameras have labeled ports, which makes this step easier.
Power the Dash Cam
Use a fuse tap to connect the power cable to an ACC fuse in your fuse box. This way, your dash cam video system powers on with your car.
Test the Camera
Start your car and check if the rear camera works. Look at the feed on your dash cam screen to confirm the view and adjust the angle if needed.
How to Install Rear Dash Cam on SUV or Truck
Key Differences from Standard Cars
If you want to know how to install rear dash cam in SUV or how to install rear dash cam on truck, you might have to take care of some unique things.
  • Longer Cable Length: Larger vehicles need extended cables to reach from back to front.
  • More Routing Obstacles: Trucks and SUVs often have extra trim panels or roof pillars to work around.
  • Higher Mounting Point: You may need to mount the rear camera higher for a full view.
  • Tailgate Openings: If the wire goes through a tailgate, you might need to use a rubber grommet or weatherproof seal.
  • Extra Power Needs: Some trucks use separate fuses or 12V sockets that affect your wiring plan.
Vehicle-Specific Tips
  • Trucks: Route cables under floor panels or behind rear seats where possible.
  • SUVs: Use the top edge of the rear window for a centered mount with fewer obstructions.
  • Cargo Vans: Rear doors may require flexible wire looms to avoid pinching.
  • Roof Racks: Avoid placing wires near rack mounts or roof holes.
  • Double Cab Designs: Expect to remove more interior panels for full access.
How to Install Rear Dash Cam on Hatchbacks and Convertibles
Unique Installation Challenges
When you know how to install rear dash cam on hatchback or how to install a rear dash cam on a convertible, it will help you avoid problems.
  • Hatchback Hinges: Moving hinges can stress wires if not routed correctly.
  • Convertible Tops: Limited interior trim makes hiding wires harder.
  • Glass Rear Windows: Some convertible windows don’t support adhesive mounts.
  • Tight Interiors: Fewer places to tuck wires without visible bulges.
  • No Fixed Headliner: Some convertible models lack full ceiling trim, limiting clean routing options.
Installation Tips
  • Flexible Wires: Use soft, bendable wires that won’t snap with motion.
  • Secure with Clips: Add more clips to keep wires still during top movement.
  • Low-Mount Placement: Place camera low if high mount isn’t possible.
  • Add Grommets: Use rubber grommets if drilling is needed for a clean finish.
  • Test with Roof Movement: Open and close the roof to confirm wires move freely.
How to Install Rear Dash Cam on License Plate Area
If your rear camera is a license-plate style unit, you should know how to install rear dash cam on license plate.
  • Get a weatherproof mount.
  • Route wires through existing license plate light holes.
  • Seal cable entries to prevent water damage.
Tips for an Aesthetically Clean Rear Dash Cam Installation
Use Factory Trim Lines
Run cables along the vehicle’s natural trim lines. This hides wires and prevents sagging over time.
Avoid Windshield Obstruction
Mount your rear camera at the top of the window without blocking your rear view mirror or defroster lines.
Match Cable Color to Interior
Use black or grey wires that blend into your headliner or floor for a neater appearance.
Don’t Block Airbags
Avoid running cables near side curtain airbags. You don’t want wires to interfere in an emergency.
Use Zip Ties and Clips
Bundle excess wire with zip ties and clip them under seats or panels to stop loose cable from moving.
If you're wondering how to install rear dash cam for a neat and professional finish, these tips will help you.
When you have a rear dash cam, you can get a better view of what is happening behind your vehicle. Now that you know how to install a rear view dash cam, you can take the next step and secure your ride today.
Rear cameras will help you with the safety of your car, driving and peace of mind. Brands like Wolfbox have reliable, easy-to-install systems that give you everything in one box. Whether you need a camera for a hatchback, sedan or SUV, you now can install your rear cam like a pro.
Is it worth getting a rear dash cam?
Yes. Dash cam will help you record accidents, parking bumps and improve the full-coverage safety for your vehicle.
Where is the best place to put a rear dash cam?
The best place to put a rear dash cam is the center of your rear windshield, just above the defrost lines. This place works best for most vehicles.
Can you install your own rear view camera?
Yes. If you have basic tools and a step-by-step guide, you can install it yourself without professional help. You can follow the steps mentioned in this guide to install it easily.
Should rear dash cam go inside or outside?
It is better if you install it inside because exterior mounts are harder to protect from rain and theft.
