Full-size trucks like the Ram 1500, Ford F-Series, or the Chevy Silverado 1500 present unique visibility difficulties. The long hood profiles, beds, and obstructed rear glass when hauling or towing mean that the standard windshield-mounted cameras can leave critical blind spots unmonitored.
A dash cam setup for these vehicles is essential, but it is also essential to get the right one to ensure you see everything all the time. A great setup is one that offers wide dynamic range, reliable low-light plate clarity, and multi-channel modular systems to avoid missing any blind spots. To help you with your search, we’ve compiled a list of the 5 best dash cams for the Ram 1500 and other half-ton trucks.
Quick Overview of The Best Dash Cam for the Ram 1500 and Half-Ton Trucks
We picked some of the best models on the market, but each one is different, so let’s take a quick look at what each offers
WOLFBOX G900TriPro Bumper |
WOLFBOX G900Pro |
VIOFO A229 Pro 2CH |
BlackVue DR970X-2CH Plus Box |
Garmin Dash Cam Live |
Form Factor |
12-inch Smart Streaming Mirror |
Discreet Windshield Wedge |
Modular Cylindrical Lenses and Separate Locked Box |
Compact Standalone Windshield Unit |
Channels |
3 Channels (Front, Rear, Bumper) |
2 Channels (Front, Rear) |
1 Channel (Front Only) |
Front Camera Resolution |
4K UHD (3840×2160) @ 30fps |
1440p 2K QHD (2560×1440) @ 30fps |
Front Image Sensor |
Sony STARVIS 2 IMX678 (8MP) |
Sony STARVIS 2 IMX678 (8MP, f/1.7) |
Garmin Clarity HDR Optics |
Secondary Camera(s) |
Rear: 2.5K (OmniVision OS04J10)Bumper: 1080p Full HD |
Rear: 2.5K (OmniVision OS04J10) |
Rear: 2K QHD (Sony STARVIS 2 IMX675) |
Rear: 1080p FHD (Sony STARVIS) |
None |
Exterior Waterproof Rating |
IP67 (Rear and Bumper lenses) |
IP67 (Rear lens) |
Cabin-mounted standard (IP67 rear available via A229 Pro-W) |
Cabin-mounted (IP69K rear available via Truck edition) |
Cabin-mounted only |
Field of View (FOV) |
Front: 130°, Rear: 150°, Bumper: 131.8° |
Front: 130°, Rear: 150° |
Front: 140°, Rear: 160° |
Front: 146°, Rear: 131° |
Front: 140° |
Connectivity |
5.8GHz, 2.4GHz Wi-Fi + GPS |
5GHz, 2.4GHz Wi-Fi + Quad-GPS |
5GHz Wi-Fi + GPS + Built-in LTE Box Port, Cloud |
Always-On LTE (Cellular) + Wi-Fi + GPS |
Power Storage |
Supercapacitor |
Supercapacitor |
Supercapacitor |
Supercapacitor |
Supercapacitor |
Subscription Required? |
No |
No |
No |
Optional (Free basic Cloud tier, paid for heavy live streaming) |
Yes (Paid monthly LTE plan required for live view, tracking, and vault) |
Truck Cab Cabling Needs |
Extensive (runs through engine bay, cabin, and to tailgate) |
Moderate (runs along headliner or frame to rear tailgate) |
Simple (thin coaxial cable tucks into headliner) |
Complex (runs both cameras to concealed locking box) |
Easiest (single power cable around windshield) |
Primary Advantage for Half-Ton Trucks |
Clears low front-grille blind spots and overcomes cargo-blocked rear view |
Replaces rearview glass with wide live feed past cargo beds and toppers |
Maximum license plate legibility day/night, preserves OEM mirror controls |
Tamper-proof, locked-away brain, vehicle security against break-ins/theft |
Standalone 24/7 job-site tracking and theft alerts without rear-cable runs |
The WOLFBOX G900TriPro Bumper Version is engineered specifically for trucks and off-road enthusiasts, offering excellent ground-level spatial awareness along with the standard highway surveillance. It straps directly over the factory rearview mirror or can replace it in some situations, offering a massive 12-inch anti-glare IPS touchscreen. The front camera utilizes the 8MP Sony STARVIS 2 IMX678 sensor, capturing in native 4K, while the rear one uses the OmniVision OS04J10, capturing in 2.5K. In addition to that, you’re also getting an IP67-rated exterior camera shooting in 1080p.[1]
For truck owners, the bumper channel on the WOLFBOX G900TriPro Bumper Edition eliminates blind zones on the front, regardless of whether you’re on the trail or avoiding tight garage obstacles. The system operates off a heat-resistant supercapacitor, supports a fast Wi-Fi protocol for quick downloads, and also logs GPS movements.[1]
Pros
- Dedicated IP67-rated bumper camera
- Native 4K front sensor and 2.5K rear sensor
- 12-inch streaming touchscreen mirror display
Cons
- Running the cables for each camera makes for a slightly complicated installation process
WOLFBOX G900Pro
The WOLFBOX G900Pro is a streamlined dual-channel digital mirror dash cam designed for truck owners who want to overcome the rear visibility issues with these kinds of vehicles without the need for a third camera. It features the 4K Sony STARVIS 2 IMX678 sensor paired with a 2.5K waterproof rear camera. Included in the package is a 12-inch touchscreen that streams a continuous rear feed, completely replacing the limiting cab rearview mirror.[2]
In these kinds of vehicles, cargo in the back or taller camper shells limit visibility, which is where the rear camera comes into play. Mounting it by the license plate gives you an unobstructed view of everything that’s happening behind. The system features voice commands, making it a true hands-free unit. In addition to that, it offers loop recording, dual-band Wi-Fi connectivity, as well as G-sensor impact detection.[2]
Pros
- Sharp 4K front and 2.5K rear recording
- Digital rearview streaming for unobstructed view out the back
- Voice commands and fast Wi-Fi connectivity
Cons
- Limited to front and rear recording, with no support for additional camera angles.
VIOFO A229 Pro 2-Channel
The VIOFO A229 Pro 2-Channel is a traditional windshield-mounted dual dash cam that’s often considered to be the industry benchmark for video surveillance and license plate legibility. It mounts discreetly to the windshield glass next to the factory console and features true 4K recording in the front and 2K recording in the rear. This combination offers an excellent HDR balance, taming highlights and lighting darker areas. [3]
For owners of the Ram 1500 and similar vehicles who have a digital rearview mirror or want an unobstructed setup, the VIOFO A229 Pro 2-Channel is the setup that integrates seamlessly. The rear coaxial cable is thinner than most analog ones, making it easier to route it through headlines and weatherstripping. The unit also features voice notifications, dual-band Wi-Fi, and a precise quad-mode GPS module. [3]
Pros
- Dual Sony STARVIS 2 sensors for clear and highly detailed recordings
- Ultra-thin coaxial rear camera cable
- Discreet setup
Cons
- The rear camera’s recording quality can take a hit if the rear glass is tinted
The BlackVue DR970X-2CH Plus Box is designed for truck owners who prioritize tamper resistance, security, and commercial build quality. The system separates the lenses from the recording box, allowing you to hide it and ensure that even if someone breaks into your vehicle, it will remain hidden. The front camera uses the Sony STARVIS 2 IMX678 for a crisp 4K capture, while the rear one is more compact, meaning you’re getting only 1080p.
Since these are the kind of vehicles that are often a target for break-ins or hit-and-runs, the BlackVue DR970X-2CH Plus Box’s parking surveillance with the optional LTE cloud functionality offers excellent peace of mind. With native voltage monitoring built in, you can be sure that the truck’s battery won’t end up drained, and it also means you won’t need to consider third-party shutoff boxes.
Pros
- Separate lockable recording box
- 4K recording on the front camera
- Robust cloud connectivity with the option to view remotely
Cons
- Carries a premium price point compared with conventional systems
The Garmin Dash Cam Live is a compact, single-lens dash cam designed for truck drivers who want real-time security without needing to run cables and worry about complex setups. It captures 2K video across a wide 140-degree field of view using Garmin Clarity HDR optics. The thing that sets it apart is the built-in LTE connectivity, allowing you to tap into the live feed from anywhere, as well as receive notifications and track the vehicles.
For Ram 1500 owners who often park in unsecured locations, the Garmin Dash Cam Live acts as an active security beacon. The camera automatically tags saved incidents with date, time, and GPS coordinates before storing them on the cloud server. The best part is that all of this comes in a compact package that can be left out of sight, making it a setup for those who want a clean install.
Pros
- Always-on LTE connection for real-time view and logging incidents
- Very compact packaging
- Voice commands are available
Cons
- The LTE features require an active subscription
What is the Best Dash Cam for the Ram 1500 and Half-Ton Trucks
All 5 models on today’s list are great, but they’re not all great for everything, meaning each one’s advantages are aligned with different use cases:
- WOLFBOX G900TriPro Bumper Edition: Ideal for overlanders and off-road enthusiasts who need to eliminate front bumper blind spots [5]
- WOLFBOX G900Pro: Best for everyday truck owners who haul tall cargo and want an unobstructed view out the back [4]
- VIOFO A229 Pro 2-Channel: The best option for drivers who want video evidence and license plate identification while preserving the OEM rearview mirror [3]
- BlackVue DR970X-2CH Plus Box: An ideal option for commercial contractors, fleet operators, or owners of trucks in high-theft areas who are mainly interested in security
- Garmin Dash Cam Live: Best for drivers who want remote surveillance and tracking from a setup that’s compact
Can I mount a rear camera on the outside of my truck?
Yes, you can mount a rear camera on the outside of the truck, but not every camera is designed to be operated in those conditions. If you need to install a camera on the outside, you need to make sure it’s rated for that, so you’ll need to be looking at IP67- or IP68-rated cameras that can handle dust and water.
Will the parking mode drain my truck's battery?
No, modern and reputable dash cam setups won’t drain your truck's battery. The reason for this is that they’re all equipped with a feature that monitors the state of the 12V battery and cuts off as soon as it reaches a certain threshold. This is to ensure you have enough juice to start the truck when you need it.
Will the digital mirror dash cam interfere with the sensors on a RAM 1500?
No, the digital mirror dash cam won’t interfere with the sensors on the RAM 1500. On the latest generation, all the sensors are enclosed in a plastic shroud attached to the windshield glass above the mirror. This means that if you install a dash cam, it won’t obstruct the sensors in any way.
[1] WOLFBOX G900TriPro Bumper Version 3 Channel Rearview Mirror https://wolfbox.com/products/wolfbox-g900tripro-bumper-version-3-channel-rearview-mirror
[2] WOLFBOX G900Pro 12MP WiFi Touch Screen Rear View Mirror Dash Cam Smart Mirror https://wolfbox.com/products/wolfbox-2024-g900-pro-wifi-touch-screen-parking-monitoring-dash-cam-smart-mirror-with-starvis-678-sensor
[3] Prime Day Is the Best Time to Buy a Dash Cam https://www.roadandtrack.com/gear/g65265918/dash-cam-prime-day-deals-2025/
[4] Wolfbox G900 Pro Review https://forums.practicalcaravan.com/threads/wolfbox-g900-pro-review.72431/
[5] The best camera system for your RV https://www.rvtravel.com/video-best-rv-backup-camera-2671/
