Best Dash Cam for Electric Cars: Power Up Your EV Experience
When you look for the best dash cam for an electric car, you may want something that works well with your EV and fits into your car's style. Your electric car uses new and different technology, so the camera you pick should not bother how your car works. The good news is, you can add a dash cam for EV cars to your vehicle safely and get so many benefits.
Can I Install a Dash Cam in an Electric Vehicle?
Yes, you can safely install a dash cam in an electric vehicle. It works much like in regular cars, though you may need to consider how your EV's power system handles parking mode and long-term use.
Power Source Compatibility: Your EV uses a 12V battery for its accessories, just like other cars. You can connect your dash cam right to the 12V socket or install it with a special kit so your camera always gets the right power.
Proper Wiring Method: When you use a hardwire kit, you connect the dash cam straight to your car's fuse box. This makes your setup look neat and gives you advanced features such as parking mode.
Battery Management: Some dash cams and wire kits switch the power off if your battery drops to a certain voltage. This keeps your battery from running down and keeps your car safe.
Professional Installation: If you are not sure about setting up wires, you can ask a professional to do it. A pro can connect your camera safely and make sure your car's systems work well.
What's Different About Installing a Dash Cam in an EV
Installing a dash cam for EV cars is almost the same as what you do with a regular car, but you will see a few clear differences.
Power Sources in EVs vs. Gasoline Cars
With a gas car, your dash cam is powered by the 12V battery and this battery charges from your car's alternator while you drive. With an electric car, you still have a 12V battery, but it gets its charge from your EV's main battery with a special converter. Any power your dash cam uses comes from the same source that powers your car.
Parking Mode Management
If you like the idea of your dash cam watching over your car when you are not in it, you will want to set up parking mode. For electric cars, using this feature the right way is very important. Your dash cam can use up your 12V battery if it runs for hours when your car is off.
Installation Differences: EV vs. Gas Car
You may notice some steps are different when you set up a dash cam in an electric car.
Installation in an EV
Installation in a Gas Car
Power Source
Uses a 12V battery, which gets power from the main EV battery pack
Uses a 12V battery, which gets power from the gas car's alternator
Hardwiring
Needs careful fuse selection to keep your car's electronics safe
Usually simple, as most fuses are less sensitive
Parking Mode
Needs a kit that shuts off power at the right battery voltage to save the main battery
Needs a kit for battery protection, but usually not as strict
Energy Use
Dash cam's power use can impact your car's driving range and battery strength
Power use from the dash cam has almost no effect on the car's fuel or battery
Key Considerations When Choosing a Dash Cam for EV Cars
If you want the best dash cam for an electric car, looking at the right features can save you time and hassle.
Discreet and Minimalist Design
Your electric car's interior probably has a smooth, simple look. You do not want a dash cam that sticks out or clutters the view. Look for cameras that are small or have a mirror style. These types fit in with your cabin and do not distract you while driving.
High-Resolution Front & Rear Recording
You want your dash cam to record every moment in clear video. Models that capture video in 4K for the front and high definition for the back are best for seeing license plates and road signs. You get clear pictures, night or day, so you always know what happened.
Low-Power Parking Mode
Your EV battery works hard, so your dash cam should not put extra load when your car is parked. Dash cams with low-power parking modes only run when they detect motion or something hits your car. This way, your dash cam keeps watch and your battery lasts longer.
WiFi and App Connectivity
It is very helpful when your dash cam connects to your phone or tablet. Many new dash cams let you watch live video, save recordings, or change settings from an app. You do not have to take out the memory card. Everything is right at your fingertips.
Superior Night Vision
Good dash cams do not stop recording when it gets dark outside. Sensors with night vision and a wide range let you record clear images even on the darkest roads. This is helpful, especially if you park in places with little light.
Smart Power Management
If you want the best dash cam for an electric car, smart power control is important. You can pick a dash cam and hardwire kit that checks your battery's voltage, then turns off the camera when it goes too low. This way, you never have to worry about your battery.
Top Dash Cam Picks for Electric Vehicles in 2025
When you look for a dash cam, you will see many choices. Some work better for electric cars because they use less power or have smart features.
1. WOLFBOX G900 Pro
The WOLFBOX G900 Pro changes your regular mirror into a smart dash cam. This camera is simple and does not get in your way while giving you a clear picture of what's ahead and behind.
Spec
Detail
Front Resolution
4K UHD (3840 x 2160P)
Rear Resolution
2.5K FHD (2560 x 1440)
Display
12" IPS Touch Screen
Field of View
Front 170°, Rear 150°
GPS
Built-in
Wi-Fi
Built-in (5GHz)
2. WOLFBOX G900 TriPro Cabin Version
You get three cameras in one with the WOLFBOX G900 TriPro Cabin Version. It covers the front, interior, and rear, so you do not miss anything. It's designed for rideshare drivers, families, or anyone who wants a clear view inside the car as well as outside.
Specification
Resolution
4K, 2.5K, 1080P
Display
Field of View
Front 170°, Interior 160°, Rear 150°
GPS
Built-in
Parking Mode
24-Hour with Hardwire Kit
Connectivity
WiFi & App Control
3. WOLFBOX G900 TriPro Bumper Version
With the WOLFBOX G900 TriPro Bumper Version, you get a full 3-channel system designed for advanced coverage: front, rear, and a front bumper view to capture everything around your vehicle.
Specification
Resolution
4K, 2.5K, 1080P
Display
12″ IPS Touch Screen
Field of View
GPS
Built-in
Parking Mode
Third Camera
Adjustable, Waterproof
4. Redtiger F17 Elite
The Redtiger F17 Elite is a smaller camera with strong features. You get very clear video and it is easy to use the app.
Specification
Redtiger F17 Elite
Video Resolution
Front: 4k, Interior: 1080p, Rear: 2.5k
Night Vision
Full-Color Night Vision (Front & Interior)
Field of View
360°
GPS
Built-in
Parking Mode
Connectivity
WiFi & App Control
Benefits of Choosing the Right Dash Cam for your EV
Sometimes, your electric car may come with built-in cameras, like a Tesla. But those are often basic and may not give you all the features or good quality you want.
Access to Advanced Recording Features
Most aftermarket dash cams record much better quality than what you get built-in. With options for 4K, wide-angle views, and night vision, you are more likely to catch every important detail. This is great for keeping track of your drives and for recordings you might need later.
More Flexible Parking Mode Options
Integrated camera systems, like Tesla's, often use a lot of energy in parking mode. When you add a separate dash cam with a special kit from WOLFBOX, you can make parking mode use much less power and turn off when your battery gets low.
Greater Control and Accessibility
If you want to handle your dash cam videos, pick a model with a good app. You can get your footage, edit it, and manage it any time you want. There is no need to use the main car display or take out any SD cards.
Front, Rear, and Interior Coverage
With a dash cam you pick yourself, you can add more views. Many built-in cameras only face forward or to the side. Your aftermarket dash cam gives views to the front, back, and even inside your car for total safety.
Do Dashcams Drain EV Batteries?
Many people worry about dash cams using up their car's battery. Today's dash cams are made to use as little energy as possible. If you set up your camera with a hardwire kit that has voltage monitoring, you do not need to worry. It will turn off before your EV battery drops too low and will not hurt your car's main systems. As long as your setup is correct, you can enjoy constant recording and still start your car with no trouble.
When you put the right dash cam in your electric car, you get peace of mind and a safer ride. It is helpful to focus on things like power-saving mode, sharp video, and good battery protection. You will find the best dash cam for an electric car to match your life and car. WOLFBOX has great choices that work well with EVs, keeping you covered every time you drive. Your dash cam stands watch, so you do not have to worry, even when you are away from your car.
1. Can you put a dash cam in an electric car?
Yes, you can. Use a special kit with voltage protection, and you will connect your dash cam safely to your EV's 12V system.
2. What power source options work for electric cars?
You can use the 12V outlet in your car or connect through a hardwire kit to your fuse box. The hardwire kit is good for hiding wires and getting more features.
3. Do I need a dashcam if I have a Tesla?
Even if your Tesla has built-in cameras, an extra dash cam can give you clearer video, more storage, and parking mode settings that you control.
