The WOLFBOX MF200 and MetroVac DataVac ED-500 show how differently two electric air dusters can approach the same job. The MetroVac follows the traditional formula with a steel body, single-speed operation, and a 12-foot power cord.[3][4] The WOLFBOX MF200 takes the modern cordless-tool approach instead, with a removable battery, three speed settings, and a 0.84-pound body.[1] MotorTrend also named it the “Most Compact” air blower in its 2026 test, highlighting its impressive power-to-weight ratio.[2]
The real comparison is not which air duster has the more impressive headline number. The WOLFBOX MF200 trades unlimited corded operation for portability and adjustable airflow, while the MetroVac DataVac gives up some mobility in exchange for continuous wall power.[1][3][4] A useful WOLFBOX air duster vs Metro DataVac comparison therefore comes down to where the cleaning happens, what needs cleaning, and how long the tool needs to keep working.
The Short Answer
The WOLFBOX MF200 is the easier air duster to live with for most individual buyers. The WOLFBOX MF200 works without an outlet, offers three speed settings, and weighs roughly two pounds less than the MetroVac DataVac.[1][3][4] Those differences matter when the same tool might clean a keyboard today, a car tomorrow, and camping gear after a late-summer weekend away.
The MetroVac DataVac makes a stronger case when the cleaning always happens in one place. Compared with the battery-powered WOLFBOX MF200, the corded duster has no battery-runtime limit and uses a steel housing.[1][3][4] If several computers arrive at the same bench one after another, never having to think about charging or battery swaps might be a genuine advantage.
WOLFBOX MF200 vs MetroVac DataVac Specifications
The specifications reveal two products built around very different priorities. The WOLFBOX MF200 favors low weight, adjustable output, and battery power, while the MetroVac DataVac favors continuous 120-volt wall power and heavier construction.[1][3][4]
Specification |
WOLFBOX MF200 |
MetroVac DataVac |
Power source |
Removable rechargeable battery [1] |
120V wall outlet [3] |
Published air speed |
210+ MPH [1][2] |
Not directly comparable |
Speed settings |
Three [1] |
One [4] |
Runtime |
100 min low / 20 min medium / 10 min high [2] |
No battery-runtime limit [3] |
Charging |
USB-C, about 2.5 hours [1] |
Not applicable |
Weight |
0.84 lb [1] |
About 2.75–3 lb [3][4] |
Working range |
Cordless [1] |
12-foot power cord [3][4] |
Included tools |
Four nozzles and two brushes [1] |
Concentrator, air flare, micro-cleaning kit [3][4] |
A clean airflow winner cannot be pulled from the published numbers alone. WOLFBOX gives a 210+ MPH air-speed figure for the WOLFBOX MF200, while available MetroVac DataVac specifications use different airflow and motor measurements.[1][3][4] Air speed measures the velocity of the airflow leaving the nozzle, but that figure alone does not tell us how two different blower and nozzle designs will perform in every cleaning job.
In a Car, Cordless Wins by a Mile
Car interiors are where the WOLFBOX MF200 starts to justify the cordless design almost immediately. Dust and grit end up in dashboard vents, cupholders, console gaps, seat rails, door pockets, and the cargo area, and the WOLFBOX MF200 can follow that mess without a power cord running through the garage or across the driveway.[1] At 0.84 lb, the cordless duster is also much easier to angle into tight spaces than the roughly three-pound MetroVac DataVac.[1][3][4]
Late-summer road trips make the WOLFBOX MF200’s cordless portability even more useful. Sand, dry dirt, crumbs, and campsite debris have a habit of settling exactly where a vacuum attachment struggles to reach, and the WOLFBOX MF200 can be carried straight to those areas. The MF200's automotive versatility has also earned industry recognition, with the model selected as a 2025 SEMA Show Media’s Choice Award winner. [5] The MetroVac DataVac can certainly handle vehicle cleanup when an outlet is nearby, but the 12-foot cord still keeps the cleaning area tied to wall power.[3][4]
At a Workbench, the MetroVac Fights Back
A fixed workbench changes the comparison in favor of the MetroVac DataVac. Unlike the battery-powered WOLFBOX MF200, the corded duster needs no charging or battery swaps because wall power keeps the MetroVac DataVac running.[1][3][4] In an IT room, electronics shop, or home workshop where everything comes to the same bench, the biggest disadvantage of a corded air duster largely disappears.
The MetroVac DataVac also makes sense when rugged simplicity matters more than portability. The all-steel body and included concentrator, air flare, and micro-cleaning tools suit focused computer work, while the WOLFBOX MF200’s lower weight matters less at a stationary bench.[1][3][4] The MetroVac may be the older-school design, but for buyers who want a straightforward tool that is always ready when plugged in, simplicity can be a feature rather than a limitation.
Three Speeds Are More Than a Spec-Sheet Bonus
Adjustable airflow becomes genuinely useful when the cleaning job keeps changing. The WOLFBOX MF200 provides three speed settings, allowing lighter airflow for loose surface dust and stronger output when debris is packed into a vent, seat rail, or workshop corner.[1][2] Changing the airflow at the tool is especially useful when moving between delicate electronics and dirtier automotive work.
Single-speed operation makes the MetroVac DataVac simpler, but also less adaptable. The DataVac has one speed, so nozzle choice, distance, and the length of each burst become the practical ways to moderate airflow.[4] That works for repetitive bench cleaning, while the WOLFBOX MF200 is better suited to jobs that keep changing.
Battery Life Is the Price of Cordless Freedom
Cordless convenience comes with a clear runtime limit on the WOLFBOX MF200. WOLFBOX rates the MF200 at about 100 minutes on low, 20 minutes on medium, and 10 minutes on the highest setting per battery.[2] The removable battery makes that easier to live with because the WOLFBOX MF200 can accept a charged spare, while USB-C charging takes about 2.5 hours.[1][2]
Unlimited runtime remains the MetroVac DataVac’s cleanest win. Compared with the battery-powered WOLFBOX MF200, the corded duster can keep working without a charging break as long as wall power is available.[1][3][4] A technician cleaning several machines back-to-back may value that far more than cordless freedom, while someone using the WOLFBOX MF200 for a few minutes in several places probably will not.
Neither Air Duster Is Right for Every Job
The WOLFBOX MF200 is not a replacement for a workshop air compressor or a high-volume vehicle dryer. WOLFBOX positions the MF200 as a portable electric air duster for cars, electronics, household cleaning, inflation, and outdoor tasks, with maximum runtime rated at about 10 minutes on the highest setting.[1][2] Air-powered tools, long production-line cleaning sessions, and blowing an entire car dry after a wash belong to a different category of equipment.
The MetroVac DataVac is not the natural choice when the cleaning area keeps moving. At roughly 2.75 to 3 lb with a 12-foot power cord, the corded machine adds more setup to cars, driveways, campsites, and multi-room cleaning than the WOLFBOX MF200.[1][3][4] The MetroVac works best when the work comes to the tool.
Final Verdict: Pick the Design That Fits the Job
The WOLFBOX MF200 makes the most sense as one air duster for several kinds of cleaning. Three speed settings, a 0.84-pound body, USB-C charging, and a removable battery make the WOLFBOX MF200 easy to move between cars, computers, household equipment, and outdoor gear.[1][2] For most individual buyers, that flexibility is likely to matter more than unlimited corded runtime.
The MetroVac DataVac remains the better specialist for a fixed station. Continuous wall power, steel construction, and a straightforward single-speed layout make the MetroVac easy to recommend when every cleaning job happens at the same bench.[3][4] The WOLFBOX MF200 has the broader appeal not because the cordless duster wins every task, but because fewer of those tasks have to be arranged around an outlet.
Is the WOLFBOX MF200 more powerful than the MetroVac DataVac?
No direct numerical winner can be established from the published specifications. The WOLFBOX MF200 is rated at up to 210+ MPH air speed, while available MetroVac DataVac specifications use different airflow and motor measurements.[1][3][4]
How long does the WOLFBOX MF200 battery last?
The WOLFBOX MF200 lasts about 100 minutes on low, 20 minutes on medium, or 10 minutes on the highest setting per battery according to WOLFBOX.[2]
Can the WOLFBOX MF200 clean a computer?
Yes. WOLFBOX lists computers, keyboards, and other electronics among the intended uses for the WOLFBOX MF200.[1]
Can the WOLFBOX MF200 replace canned air?
Yes, for most routine dusting. The rechargeable WOLFBOX MF200 can replace disposable canned air while providing three adjustable speed settings for different cleaning jobs.[1]
Does the MetroVac DataVac ED-500 have variable speed?
No. The standard MetroVac DataVac is a single-speed model, while the WOLFBOX MF200 provides three speed settings.[1][4]
[1] WOLFBOX, “WOLFBOX MF200” https://wolfbox.com/products/compressed-air-duster-mf200
[2]MotorTrend, "Best Air Blowers for 2026 Tested: Compact Blowers Ranked" https://www.motortrend.com/gear-reviews/best-air-blowers-2026-tested
[3] B&H Photo Video, “MetroVac DataVac Electric Duster” https://www.bhphotovideo.com/c/product/599911-REG/METRO_DataVac_ED_500_DataVac_Electric_Duster_Model.html
[4] Manuals+, “MetroVac DataVac Instruction Manual.” https://manuals.plus/metrovacop/ed500-datavac-electric-duster-manual
[5] SEMA, "2025 SEMA Show Media's Choice Award Winners" https://www.sema.org/news-media/enews/2025/45/first-ever-sema-show-medias-choice-award-winners-revealed/-25ss
