- Ram 1500 trucks built before 2019, along with the Ram 1500 Classic sold through 2024, use a different bed step design than the current Ram 1500.
- The WOLFBOX Retractable Bed Step for the Ram 1500 (09 to 18) and 1500 Classic (19 to 24) bolts on in about 30 minutes with no drilling and holds up to 330 pounds.
- If you drive a 2019 to 2026 Ram 1500 that isn't a Classic, WOLFBOX Power Running Boards are your best current bolt-on option, since the retractable step lineup for that body style covers the Ram 2500 and 3500 instead.
- Ram's optional factory tailgate step is real and works well, but it's a dealer-installed accessory, not standard equipment, and it isn't available on every trim or tailgate type.
- Weigh deployment style, ground clearance impact, weight rating, and install time before you settle on a bed step, a hitch step, or running boards.
Why Bed Access Gets Overlooked on a Ram 1500
A Ram 1500 looks great in the driveway. Getting into the bed of one, though, is a different story. Full-size half-ton trucks like the 1500 stand roughly 77 to 79 inches tall depending on trim, cab, and whether you've added a lift or larger tires, with ground clearance in the 8-inch range. Add a 21-inch-deep bed and you're looking at a real reach every time you need to grab a cooler, check a tie-down, or toss in a bag of mulch.
Most owners deal with this the same way for years. They put a knee on the wheel well, grab the bed rail, and pull themselves up. It works, sort of, until it doesn't. Wet tires, cold mornings, and a truck full of gear make that move riskier than it looks. Repetitive climbing and awkward reaching are exactly the kind of tasks the CDC's National Institute for Occupational Safety and Health flags as contributors to musculoskeletal strain, and its data show tens of millions of U.S. workers report frequent lifting, pushing, pulling, or bending on the job.
So what's the fix? For most Ram 1500 owners, it comes down to three real options: a bolt-on retractable bed step, a hitch-mounted step, or power running boards. Which one makes sense depends heavily on which Ram 1500 you actually own.
Ram 1500 Body Styles Matter More Than You'd Guess
Here's where things get confusing for a lot of shoppers. Ram sells the "1500" under two very different platforms right now, and it has for years.
The older body style, produced from 2009 through 2018, is a completely different frame and bumper design than the truck that replaced it. Chrysler kept building that older design alongside the new one and sold it as the Ram 1500 Classic from 2019 through 2024, mostly to fleet buyers and budget-conscious shoppers. Meanwhile the redesigned Ram 1500 (sometimes called the DT generation) launched for the 2019 model year and continues today, including the current 2025 to 2026 Crew Cab.
That matters because bumper mounting points, frame rail spacing, and exhaust routing aren't the same between these two trucks. A bracket kit built for one won't line up on the other. This is exactly why the WOLFBOX Retractable Bed Step is sold as a vehicle-specific kit rather than a universal part. The Ram 1500 (09 to 18) / 1500 Classic (19 to 24) version is precision-fit to that older frame. It isn't designed for, and won't bolt onto, the current-generation Ram 1500.
If your truck is a 2019 or newer Ram 1500 and it's not a Classic trim, a retractable bed step from WOLFBOX isn't the right fit yet. That's not a small caveat. It's the single most important thing to check before you buy.
Comparing Your Ram 1500 Bed Access Options
Once you know which platform you're working with, the real decision is what type of access solution fits how you use your truck.
Deployment and Convenience
A retractable bed step mounts under the rear bumper corner and deploys with a simple foot tap. No buttons, no motors, nothing to charge. Nudge it with your boot and it swings into position; nudge it again and it tucks itself away.
A hitch step slides into your 2-inch receiver and stays there, which is convenient if you're not towing but a hassle if you are, since most have to come out before you hook up a trailer.
Power running boards work differently. They're motorized side steps that extend when you open the door, mainly built to help with cab entry rather than reaching into the bed itself.
Ground Clearance and Departure Angle
This is where a retractable step earns its keep. Because it tucks flush under the bumper when not in use, it doesn't hang below the factory bumper line and doesn't eat into your departure angle on trails or steep driveways. Fixed steps and permanently mounted hitch accessories can't say the same. They're always there, whether you want the ground clearance back or not.
Weight Capacity and Durability
The WOLFBOX Retractable Bed Step is rated for 330 pounds and built from die-cast aluminum and steel with an e-coat plus powder-coat finish for corrosion resistance. Generic aftermarket hitch steps vary widely, often somewhere between 200 and 350 pounds depending on the brand and materials. Running boards used for cab access are typically rated higher, generally in the 300 to 500 pound range, since they're designed to support a full step-in, step-out motion rather than a quick foothold.
Here's an easy one. A no-drill retractable bed step bolts to existing factory mounting points, uses basic hand tools, and takes most owners about 30 to 45 minutes with a helper. A hitch step is even simpler since it just slides in. Running boards, being electrical and heavier, generally take longer and are more commonly installed by a shop, though DIY kits do exist.
Cost
Retractable bed steps from WOLFBOX run right around $185, with regular sales bringing that down further. Generic hitch steps can be found for less, often in the $50 to $150 range, though quality and weight ratings vary a lot at that price point. Power running boards are a bigger investment, generally starting well over $1,000, which reflects the motors, wiring, and mounting hardware involved.
| Feature | Retractable Bed Step | Hitch Step | Power Running Boards |
| Deployment | Foot-activated, mechanical | Slides into receiver | Motorized, door-activated |
| Ground clearance impact | None when retracted | Reduces clearance | Minimal, tucks under body |
| Weight capacity | Up to 330 lbs | Roughly 200 to 350 lbs | Roughly 300 to 500 lbs |
| Installation | 30 to 45 minutes, no drilling | Under 10 minutes | Longer, often shop-installed |
| Price range | Around $185 | Roughly $50 to $150 | Generally $1,000 and up |
| Best for | Daily bed access, clean look | Occasional use, must remove before towing | Cab entry, family and passenger use |
None of these is objectively "better." A contractor who tows a trailer three days a week is going to get more out of a bed step than a hitch step. A family that mostly uses the truck for the school run and grocery runs might value running boards more for getting kids in and out of the cab.
Installing a Retractable Bed Step on Your Ram 1500
If your truck is the 2009 to 2018 Ram 1500 or a 2019 to 2024 Classic, here's roughly what the install looks like.
The kit uses your truck's existing frame mounting points, so there's no drilling, cutting, or welding involved on most trims. You'll want a basic socket set and a torque wrench, plus a second pair of hands to hold the bracket in place while you thread the bolts. Most owners finish in well under an hour.
One thing worth double-checking before you order: trucks with factory dual exhaust or an aftermarket exhaust system sometimes need a different bracket configuration to clear the extra piping. Always check the fitment table on the specific product page before you buy, not just the general compatibility blurb.
If You Have a Newer Ram 1500: Running Boards Are Your Best Bet Right Now
Own a 2019 or newer Ram 1500 that's not a Classic? Don't worry, you're not out of options.
WOLFBOX Power Running Boards are built for the 2019 to 2024 Ram 1500 and 2019 to 2023 Ram 1500 TRX, using pre-existing factory mounting points for a no-drill install. If you've got the very latest truck, there's also a version built specifically for the 2025 to 2026 Ram 1500 Crew Cab, designed to align with that model's updated body lines and preserve factory ground clearance.
These won't replace a bed step for reaching straight into the cargo area. What they will do is make climbing in and out of the cab dramatically easier, which matters just as much if you've got kids, pass gear back and forth, or just want a solid foothold when the truck's wet or muddy.
WOLFBOX is continuing to expand its bed step lineup, so it's worth checking back if you're set on that specific style of access for a new-body 1500.
What About the Factory Multifunction Tailgate Step?
Some Ram 1500 owners already have a factory option worth knowing about. Ram's available Multifunction Tailgate, first introduced for the 2019 model year, uses 60/40 split swing-away doors that open close to 88 degrees for easier loading. Mopar offers a dealer-installed bed step designed specifically to work with that tailgate, deploying from under the rear bumper with a foot tap and rated for up to 350 pounds.
It's a genuinely clever piece of engineering. But it has real limitations worth knowing before you count on it.
This factory step isn't standard equipment. It's an optional, dealer-installed accessory, which means plenty of Ram 1500s on the road simply don't have it, especially older or lower trim models. It's also designed around the multifunction tailgate specifically, so it's not compatible with a truck running the standard tailgate. If your truck came without it, an aftermarket bed step remains the more practical route to the same convenience.
Keeping Your Bed Step Working for the Long Haul
A mechanical, no-wiring step is about as low-maintenance as truck accessories get, but a few habits help it last. Rinse road salt and mud off the mounting bracket during regular washes, especially if you live somewhere with harsh winters. Check the mounting bolts for torque once or twice a year, particularly if you drive on rough roads often. And step onto it gently rather than jumping.
That last one matters more than people think. Dynamic loading, like jumping down onto a step, generates forces two to three times your body weight. A step rated for 330 pounds of static weight isn't necessarily built for repeated hard impacts at that same limit.
Won't This Void My Warranty?
It's a fair question, and one we hear often. Under the Magnuson-Moss Warranty Act (15 U.S.C. § 2301), a dealer can't void your Ram 1500's factory warranty just because you installed an aftermarket accessory. A bolt-on bed step that uses existing frame mounting points, with no drilling, cutting, or electrical splicing, doesn't create the kind of permanent modification that would give a dealer grounds to deny coverage elsewhere on the truck. The only real risk is if a poorly installed part directly damages something else, which is a good reason to follow the included torque specs closely and not skip steps during install.
Ready to Stop Climbing Into Your Bed?
Whether you're working a job site five days a week or just tired of scraping your shin on the tailgate, the right access upgrade makes a real difference every single time you load or unload. Take a look at the full lineup of WOLFBOX Truck Steps to find the fitment that matches your Ram 1500, and check the fitment table on each product page before you order to make sure it's built for your exact body style and year.
Does the WOLFBOX Retractable Bed Step fit every Ram 1500?
No. WOLFBOX currently offers a retractable bed step built specifically for the 2009 to 2018 Ram 1500 and the 2019 to 2024 Ram 1500 Classic. It does not fit the redesigned Ram 1500 sold from 2019 onward. A separate bed step is available for the Ram 2500 and 3500 (2019 to 2026). Always confirm your exact model year and trim against the fitment table on the product page before ordering.
What's the difference between the old-body Ram 1500 and the new Ram 1500 for fitment purposes?
The Ram 1500 built through 2018, and kept in production as the "Classic" through 2024, uses a different frame, bumper, and mounting point layout than the redesigned truck that launched for 2019. Aftermarket accessories built for one generation generally won't bolt onto the other without modification.
How much weight can a Ram 1500 bed step hold?
The WOLFBOX Retractable Bed Step is rated for 330 pounds of static weight, which covers most adults along with work boots and tools. Dynamic loading, like jumping onto the step rather than stepping gently, creates significantly higher forces and should be avoided.
Will adding a bed step affect my Ram 1500's ground clearance?
No, not when it's a retractable design. The step tucks flush under the bumper line when not deployed, so your truck's original ground clearance and departure angle stay intact. Fixed steps and permanently mounted hitch accessories, by comparison, do reduce clearance since they're always in position.
Can I install a Ram 1500 bed step myself?
Yes, in most cases. The WOLFBOX step uses a 100 percent bolt-on installation with no drilling required, using your truck's existing frame mounting points. Most owners complete the job in 30 to 45 minutes with basic hand tools and a helper.
Does Ram offer a factory bed step for the 1500?
Ram offers an optional, dealer-installed bed step through Mopar that's designed to work with the available Multifunction Tailgate. It isn't standard equipment on every trim, and it's built specifically for trucks that have that tailgate option, so it won't work on a standard tailgate setup.
Will installing an aftermarket bed step void my Ram 1500's warranty?
No, not on its own. Under the Magnuson-Moss Warranty Act, a dealer cannot void your vehicle's warranty simply because you added an aftermarket accessory. A no-drill, bolt-on bed step that doesn't involve cutting, drilling, or electrical modification doesn't create grounds for a dealer to deny unrelated warranty coverage.
