Quick Guide:
- Extended Hardwire Kit-20ft
- Gift 4 Fuse Tap Cable-11.5ft
- VoltAdjust Hardwire Kit-11.5ft
- OBD Hardwire kit
Hardwiring kits provide a reliable power source for your dash cam, ensuring it never runs out of battery. They offer a clean and seamless installation without messy cables and adapters. With a hardwiring kit, you can enjoy uninterrupted power for your dash cam, capturing important moments while driving or parked. It's a hassle-free and reliable solution for any driver.
Wolfbox offers a variety of dash cam hardwire kits for you to choose: Extended Hardwire Kit-20ft, Gift 4 Fuse Tap Cable-11.5ft, VoltAdjust Hardwire Kit-11.5ft, OBD Hardwire kit-11.5ft.
However, "Which hardwire kit should I choose and how do I connect and install it with my dash cam?" is a common question that often leaves us confused. In the following sections, I will introduce four different voltage regulator kits and provide installation instructions for each. What are the differences among these hardwire kits?
| Type | Extended Hardwire Kit | Gift 4 Fuse Tap Cable | VoltAdjust Hardwire Kit | OBD Hardwire kit |
| Lengths | 20ft | 11.5ft | 11.5ft | 11.5ft |
| Low Voltage Protection | √ | √ | √ | √ |
| Multi-model adaptability | √ | √ | √ | √ |
| Easy Installation | √ | √ | √ | √ |
| G-Sensor Function | √ | √ | √ | √ |
| 24H Parking Monitoring | √ | √ | √ | √ |
| Multiple Fuse Models | √ | √ | ||
| Adjustable Low Voltage Protection | √ | √ |
Product Features: Low Voltage Protection, Easy Installation, G-Sensor Function, 24H Parking Monitoring
Lengths: 20ft
Bright Spots: This Extended Hardwire Kit offers a longer length, providing convenience for compatibility with various car models and simplifying the installation process. Enjoy greater flexibility and convenience, ensuring a seamless setup for your dash cam.
Product Features: Multiple Fuse Models, Low Voltage Protection, Multi-model adaptability, Easy Installation, G-Sensor Function, 24H Parking Monitoring
Lengths: 11.5ft
Bright Spots: Multiple Fuse Models
The Gift 4 Fuse Tap Cable offers four different fuse models to cater to various vehicle types. Choose the right fuse for your car model and enjoy a seamless installation.
Product Features: Adjustable Low Voltage Protection, Multi-model adaptability, Easy Installation, G-Sensor Function, 24H Parking Monitoring
Lengths: 11.5ft
Bright Spots: Adjustable Low Voltage Protection+Multiple Fuse Models
Distinguished from the Gift 4 Fuse Tap Cable, VoltAdjust Hardwire Kit provides essential protection for your vehicle's battery. It features an adjustable voltage regulator specifically designed for 12V or 24V systems. With three customizable settings (11.6V, 12V, and 12.4V for 12V; 23.6V, 24V, and 24.4V for 24V), it ensures stable performance, prolongs battery life, and safeguards your vehicle's electronics. Shield your battery and enjoy peace of mind with our VoltAdjust Hardwire Kit. (Every time the voltage switch button is adjusted, the display will first show the currently set protection voltage, and then within 2 seconds, it will display the current voltage of the car battery. When the car battery voltage reaches the currently set protection voltage, it will automatically shut off within 5 minutes and stop supplying power to the dashboard.)
The above three hardwire kit step-by-step installation tutorials:
- Before you start installing, make sure you have everything you need and that you're in a safe environment.
- Find your car's fuse box. It's usually located either under the dashboard on the driver's side or in the engine compartment.
- Inside the fuse box, you'll see different slots where fuses are placed. Look for the ACC (Accessory) fuse slot. This slot provides power when you turn on the ignition. Also, find the constant power fuse slot, which provides power even when the ignition is turned off.
- Take the red wire from the hardwire kit and connect it to the ACC fuse slot. This will ensure that the dash cam receives power when you turn on the car's ignition.
Connect the yellow wire from the hardwire kit to the constant power fuse slot. You can use a fuse tap or a fuse adapter to make the connection. This will provide power to the dash cam even when the car's ignition is turned off.
5. Look for a suitable grounding point near the fuse box. It should be a metal surface that is firmly connected to the vehicle's chassis.
6. Connect the black wire from the hardwire kit to the grounding point using a ring terminal or a suitable grounding connector. This ensures that the dash cam has a proper electrical ground.
7. Once all the connections are secure, neatly tuck away any excess wires -and ensure they are safely routed to avoid interfering with the vehicle's controls or causing any hazards.
8. To check if the hardwire kit is working correctly, turn on the car's ignition. The dash cam should receive power and start functioning as expected.
OBD Hardwire kit
Product Features: Adjustable Low Voltage Protection, Wide Capacity, High Compatibility, Low Voltage Protect, Easy Installation, G-Sensor Function, 24H Parking Monitoring
Lengths: 11.5ft
Bright Spots: OBD interface+Adjustable Low Voltage Protection
The OBD Hardwire kit provides essential protection for your vehicle's battery. It features an adjustable voltage regulator specifically designed for 12V or 24V systems. With three customizable settings (11.6V, 12V, and 12.4V for 12V; 23.6V, 24V, and 24.4V for 24V), it ensures stable performance, prolongs battery life, and safeguards your vehicle's electronics. Shield your battery and experience peace of mind with our OBD Hardwire Kit, designed for easy installation.
Installation Guide:
Connect the OBD hardwire kit to the vehicle OBD interface, and connect the Type-C USB to the dash cam. Then start the car, turn on the dash cam, and set the parking monitor mode.
Tips: The most common location of the car OBD interface for the driver is the lower left of the trim panel under the steering wheel. However, the location of the OBD will be slightly different depending on the origin and model year of the vehicle. Some are above the accelerator pedal, or near the driver's side fuse box, some are in front of the shift lever, etc. Please choose the most suitable location for installation.
