If you often feel that your regular dash cam does not help you see everything clearly, you are not the only one. Many drivers look for the best digital rear view mirror to make driving safer and easier. A digital rear view mirror gives you more than just recording video. It works as your mirror, your dash cam and helps when you drive in reverse. You might want to know what is a digital rear view mirror and why it could be better for you than a basic dash cam. In this guide, you will see the differences so that you know what suits your car best.
What Is a Digital Rear View Mirror?
Before making a choice, you need to understand exactly what a digital rear view mirror, also called a mirror dash cam, can do. With a digital mirror dash cam, you replace your regular mirror. Your display is bright and shows live footage from the front and rear. This is more than just a reflection. You can record your journeys, keep an eye on your car and see the road better.
When you choose brands like Wolfbox, your rear view digital mirror will help you stay safe and add style to your car. Popular models such as the G900 Pro and G900 Tripro are designed to fit well and look like they always belonged in your car. If you are asking, “Are digital rear view mirrors worth it?” the answer is yes—you get extra safety and more features in one easy package.
Mirror Camera vs Traditional Dash Cams: Key Differences
It is helpful to compare how a rear view digital mirror is different from your regular dash cam.
1. Functionality
With a regular dash cam, you normally get video from one or sometimes two directions. With a digital rear view mirror, you have a mirror, a dash cam and a backup camera, all in one. This means you can see live footage and enjoy extra helpful features with just one device.
2. Design
A standard dash cam sits on your windshield and might block your view a bit. In contrast, a rear view digital mirror takes the place of your mirror or attaches over it, keeping your dashboard free and your car looking tidier.
3. Installation
Setting up a dash cam often involves wires and sticking it firmly to your windshield. With a digital rear view mirror, the setup is usually easier. For example, Wolfbox mirrors go over your current mirror using straps and simple wiring. Both cameras connect without causing a mess.
4. Viewing Angle
If you use a regular 1-channel dash cam, the camera lens can only show one set area and may not help much with blind spots. By switching to a 3-channel digital rear view mirror, you get a wider view and can see past usual blocks like passengers or headrests, and front and rear views at once.
5. Multi-Use Convenience
A normal dash cam focuses on just recording. A digital rear view mirror lets you do much more. You can watch a live feed, record and use it as a backup camera when you reverse. This makes it an easy pick for those wanting the best digital rear view mirror for daily use.
Pros and Cons of a Dash Cam vs Mirror Dash Cam
When you look at both options, you will find both good points and things to think about. Each type has its strengths and limits that matter for your driving experience.
Pros of a Mirror Dash Cam
- Multi-function convenience: Your digital rear view mirror gives you a mirror, dash cam and parking camera together. You get all this without making your car messy.
- Cleaner interior design: You no longer need a bulky camera on your windshield. With a mirror replacement, your car has a finished and neat look.
- Wide viewing angles: Your rear view digital mirror helps cover blind spots. You will see behind people, bags or tinted glass that might stop your view with a normal mirror.
Backup safety: The backup camera view in your mirror dash cam helps you reverse safely. You will not need a different parking camera or extra sensors.
Cons of a Mirror Dash Cam
- Higher cost: A digital rear view mirror usually costs more at first than a simple dash cam. But you get more functions for your money.
Screen glare: Some mirrors might be hard to see if sunlight hits them. Brands like Wolfbox work to fix this with better screens and anti-glare film.
Pros of a Traditional Dash Cam
- Lower cost upfront: Buying a regular dash cam costs less than a mirror model. You pay only for the basic recording.
Simple focus: These dash cams record and do not have extra screens to distract you. This is good if your only goal is to keep a video record.
Cons of a Traditional Dash Cam
- Limited features: Standard dash cams do not give live mirror feeds or parking help. You may end up needing more add-ons.
- Obstruction issues: With a camera stuck to the windshield, part of your view might be blocked. It looks less tidy next to a digital rear view mirror.
- Small screen size: Standard dash cams often have 2–3 inch displays, which are mainly for setup and quick playback. Watching footage in real time is less practical compared to the larger full-screen view of a digital rear view mirror.
Top Benefits of Upgrading to a Digital Rear View Mirror
Upgrading to a digital rear view mirror can offer some clear benefits for your driving.
1. Touchscreen Control & Live Display
If you use the Wolfbox G900 Pro, you have a large touchscreen. Changing settings, watching recordings and checking video feeds is quick and stress-free. This makes your drives smoother every day.
2. Cleaner, OEM-Style Look
The Wolfbox rear view digital mirror will either replace or fit on your original mirror. It matches your car’s design, giving a nice and tidy look inside. From the first day, it feels like a natural part of your car.
3. Built-In Backup Camera Function
Each time you go into reverse, the mirror switches right away to a clear camera view. Parking is simpler and safer with no guessing about what is behind you.
4. Multi-Function Convenience
A digital rear view mirror saves wiring and space. You do not have to install different gadgets. One mirror gives you a live view, recording and a reversing camera.
5. Wide Field of Vision
A digital mirror lets you see more than you would with a regular mirror. You can spot cars and objects in places others might miss, helping you drive more safely and with confidence.
Choosing the Best Digital Rear View Mirror: 5 Key Factors
If you decide you want the best mirror dash cam, you should know what to look for to make the choice easier and better.
1. Video Resolution & Night Vision
Pick a mirror dash cam that records in 2K or 4K and has night vision. For instance, Wolfbox G900 Tripro delivers clear videos even at night, so your footage is always sharp.
2. Screen Size & Display Quality
Bigger screens, like 12 inches or more, make it easy to use controls and see everything. Wolfbox uses IPS screens that deliver clear colors and wide viewing angles for better visibility in any lighting.
3. Field of View & Coverage
A wider field of view means less risk of missing something. Look for coverage close to 170° on both cameras. Wolfbox mirrors are made to let you see more.
4. Easy to Install
Make sure your digital rear view mirror is simple to put in place. Wolfbox mirrors use straps that go right over your existing mirror, with wires for the cameras that are easy to hide. This keeps your car looking neat and saves time.
5. Additional Features
Features like GPS tracking, parking mode and smart controls make a big difference. The Wolfbox G900 Pro has all these, making it simple to see why it is called one of the best digital rear view mirrors in 2026.
Digital Mirror vs Traditional Dash Cam
Digital Rear View Mirror (Wolfbox)
Traditional Dash Cam |
Functions |
Mirror, dash cam, backup camera |
Video recording only |
Design |
OEM-style, clean look |
Bulky, windshield mount |
Field of View |
Wide, covers blind spots |
Narrow, limited |
Installation |
Quick strap-on |
Separate mounts |
Price |
Higher, more features |
Lower, fewer features |
By upgrading to a digital rear view mirror, you get more than just a way to record video. You will enjoy live video, a tidy design, reversing help and many advanced features in one small device. Wolfbox leads with models such as G900 Pro and G900 Tripro. If you want to know, “Are digital rear view mirrors worth it?” the answer really is yes. Try a Wolfbox for safer, smarter driving every day.
1. What is a digital rear view mirror?
A digital rear view mirror is a device that works as a mirror, dash cam and reversing camera, giving you live views and recordings from front and rear cameras.
2. Are digital rear view mirrors legal?
Yes. It is normal to ask, "Are digital rear view mirrors legal?" Most places allow them as long as visibility rules are followed. Wolfbox mirrors follow those safety rules.
3. Are digital rear view mirrors worth it?
If having more safety options, a wider view and more conveniences matter to you, then yes, a digital rear view mirror is a smart choice.
4. How to install digital rear view mirror?
If you want to know how to install digital rear view mirror, it is usually easy. Just strap over your car's current mirror and connect a few wires. Wolfbox mirrors are simple for most people to set up.
5. What is the best digital rear view mirror in 2026?
Wolfbox G900 Pro and G900 Tripro are great picks for the best digital rear view mirror in 2026. They give you a clear picture, parking support and very good coverage.
