Dash Cam with Backup Camera: Enhance Your Safety and Convenience
In the era of smart driving, a dash cam with backup camera is not only a convenience, but it is a necessity. Regardless of whether you need to memorize road incidents, reverse safely, or park accurately, combining these functions in a single device is of exceptional value.
But which options are best, and can a backup camera with dash cam be a better option than having dedicated systems? Let’s explore everything you need to know.
What is the Difference between Reverse Camera and Dash Cam?
To understand further, it is necessary to be familiar with the functions of a backup camera with dash cam system as compared to standard individual devices.
  • The key feature of a dash cam is to have a video recording of the road ahead or behind all the time. It is mostly used to provide evidence in case of accidents, disputes, or road incidents.
  • A backup camera (reverse camera) is a device that is specifically designed to offer a live video display of the ground behind the vehicle when backing up. It helps in parking, navigating around obstacles, and avoiding accidents.
While both cameras record visuals, their operating principles are different: one is intended to document, the other is capable of providing active parking assistance.
Can a Dash Cam Be Used as a Backup Camera?
A lot of drivers wonder if it’s practical to use dash cam as backup camera. Here is what you need to know:
Pros
  • Continuous Rear Recording: Some dash cams have a rear lens allowing constant recording that also serves as a backup in a rear-end collision.
  • Night Vision Capability: Premium models improve visibility during reversing in low-light conditions.
  • Parking Mode: Most models have an inbuilt motion or impact detector so that when the car is parked, it can detect the activity automatically.
Cons
  • Small Screen Display: The screen size of most dash cams is usually limited. Hence, real-time reversing is less effective.
  • No Dynamic Guidelines: Dedicated backup camera with dash cam systems often include on-screen parking lines, absent in most dash cams.
  • No Auto-Switch: Dash cams do not automatically switch to rear view when shifting into reverse.
  • Potential Lag: Live feed from a dash cam backup lens could have minor delays, which decrease safety.
To conclude, some dash cams are also capable of serving partially, as a reverse camera, but cannot substitute the dedicated feature unless specially made, such as a mirror dash cam with a backup camera.
Why Mirror Dash Cams Work Better for Reversing
A rear view mirror dash cam is often a smarter choice when you require actual reversing assistance.
These innovative devices replace or overlay the conventional rearview mirror with a screen that displays a live camera feed from the rear of the vehicle. This overcomes the small screen limitation of regular dash cams and typically includes:
  • Wide View Angle: Covering blind spots better than conventional mirrors.
  • Auto-Switching Display: Instantly switches to the backup camera when backing.
  • Parking Guidelines: Dynamic gridlines assist you in parking accurately.
The mirror dash cam with backup camera is a combination of safety, technology and convenience in one sleek package.
Benefits of Dual Dash Cam Systems Beyond Reversing
Choosing a dual system, a dash cam with reverse camera, is beneficial in several ways:
  • Incident Recording: Simultaneous front and rear recording to have full coverage.
  • Evidence for Accidents: Insurance claims can be handled faster using clear footage.
  • Parking Surveillance: There are motion detection and parking modes to avoid theft or vandalism.
  • Driving Analytics: Some models provide GPS tracking and speed monitoring.
Thus, a rear view camera dash cam makes you safer on the road and even off the road.
Best Mirror Dash Cam with Backup Camera
Among the premium dash cam with backup camera, Wolfbox is a leading example. These are our best models:
WOLFBOX G900 Pro
  • 12-Inch IPS Touchscreen: WOLFBOX G900 Pro offers large, clear display for real-time rearview.
  • 4K Front Camera & 2.5K Rear: High-definition recording for both ends.
  • Smart Parking Guidelines: Adjusts dynamically according to movement.
  • Auto Reverse Mode: Switches to rear camera view when you shift into reverse.
WOLFBOX G900 TriPro Cabin Version
  • Triple Channel Recording: WOLFBOX G900 TriPro model provides front, rear, and interior cabin protection.
  • GPS Tracking: Records speed and location data.
  • Superior Night Vision: Captures clear videos even in the dark.
  • Adjustable Parking Lines: Customize based on the size of your vehicle.
Other Brands
While Wolfbox leads the market, other competitors like Vantrue and Kingslim offer alternative best dash cam with reverse camera options. But Wolfbox models excel in reliability, video clarity, and user-friendly features.
How to Install Dash Cam with Backup Camera
Installing a dash cam with backup camera might sound technical, but it can be done easily with the right steps:
1. Mount the Dash Cam:
Begin by securely mounting the dash cam on your vehicle’s windshield or rearview mirror. Place it at the center so you have a wide and crystal clear view of the road. Adjust the angle slightly downward to reduce exposure of the sky. Make sure it is fastened well to avoid vibrations that could blur video recordings.
2. Install the Rear Camera:
Attach the backup camera near the rear license plate for an optimal rear view. Fix the camera in position using the provided screws or adhesive. Adjust the lens to have a horizontal clear view. This posture assists in a precise representation of parking space, obstructions, and blind spots during reverse driving.
3. Wiring:
Carefully route the rear camera’s cable from the back of the vehicle to the dash cam unit. Conceal the wiring inside the panels or under the carpet for a neat installation. Ensure that the wires are attached using cable clips to prevent them from interfering with vehicle controls or passenger comfort.
4. Connect to Reverse Light:
To enable automatic activation when reversing, connect the power line of the rear camera to the reverse light circuit of the vehicle. This ensures the backup camera feed displays when you put the car in reverse. Ensure that the connections are insulated and fastened properly to prevent electrical problems or technical disconnections during regular vehicle operations.
5. Power Connection:
Connect the dash cam to the vehicle power through the cigarette lighter socket or a hardwiring it to the fuse box to give a seamless appearance. Hardwiring can also allow parking mode functions to track your car while parked. Make sure the connection is stable so that there is no power interruptions.
6. Test the System:
Check the dash-cam and back camera after being installed. Make sure that the video feeds are clear with the right angle adjustment. Verify that the rear view automatically activates when reversing. Adjust the camera angles and settings to ensure comprehensive coverage and reliable performance during daily use.
Dash cam with a backup camera is not just an accessory but rather a safety measure. From continuous recording to stress-free parking, the advantages are undeniable. When you seek high-end solutions, there is nothing better than the Wolfbox models that have a sleek design and function in alliance with smart technology.
Can I just use my rear dash cam as a reverse camera?
While you can technically view rear footage, most dash cams are not optimized for real-time reversing. A dedicated rear view mirror dash cam with a backup camera is more efficient.
Does a dash cam conflict with backup camera?
No. Modern solutions such as the Wolfbox G900 Pro integrate both functions seamlessly without interference, providing dual functionality.
What about choosing a Wolfbox mirror dash cam?
By choosing Wolfbox, you have access to the latest technologies, high-quality videos, parking instructions, and switching to the backup feed automatically to ensure your safety when driving and parking.
