If you are thinking about buying a 360 dash cam for your car, you are not alone. Many people want to see as much as possible around their car, not just what is in front, but also behind and even inside. A 360 dash cam for car is made to catch every angle at once. This is helpful when parking, driving in busy traffic or if something happens and you need to know exactly what took place.
You might wonder, is there a 360 dash cam that really works well? Or which one is the best 360 dash cam? The answer is, there are a few options out there and each one has good things and bad things. Wolfbox does not make a true 360-degree camera yet, but our special 3-channel dash cams give you almost the same coverage, with some extra bonuses.
Before you look at buying a dash cam, it’s useful to know how a 360 degree dash cam works and what makes it different from other cameras.
Most 360 dash cams use two super wide-angle lenses. For example, you can have a 210° lens in the front and a 210° lens in the back. This covers the area all around your car. The camera brings the video from all the lenses together, so you get a single very wide picture.
The camera’s computer (sometimes called software) takes those two (or more) videos and “stitches” them together. What this means is, it blends the overlapping parts of each video into one single, seamless view. When you go back and watch something that happened, you can see what was going on all around your car at the same time, without missing anything.
Some brands like 70mai Omni, have cameras with just one main lens that moves. The lens can spin left, right, up or down, so it can catch action in every direction. This way, the camera does not need to use more than one lens, but instead relies on its lens moving around to look at different parts of your car and the road.
A lot of these cameras also have a way to record what is happening inside your car at the same time as what is outside. This is perfect for rideshare drivers (like Uber or Lyft), for taxi drivers or for you if you just want to keep an eye on your passengers or even on your bags.
Many of the best cameras now offer 360 degree dash cam with parking mode. When your car is parked and turned off, the dash cam keeps working. It can notice if someone bumps your car or if something moves near your doors. If anything happens, it records everything going on all around your car, so you have all the proof you need.
If you want the best 360 dash cam, you need to look for certain features. These features will help you get the best results and the most protection for your car.
The camera’s resolution is the first thing to check. For clear details like reading license plates and seeing faces, get a camera that can record at least in 1440p (also called Quad HD). Some cheaper cameras only have 1080p (which is called Full HD) which are okay, but with 4K, you will have the best quality.
The frame rate tells you how many frames (or pictures) the camera records each second. If you drive in traffic or fast highways, a higher frame rate like 60 frames per second, makes your video look much smoother.
If you drive at night or in shade, good low-light performance is important. Some dash cams have special sensors like Sony Starvis, that make sure your video is clear even when it gets dark. You want a camera that shows details at night just as well as in the day.
When you drive over bumps or rough roads, your video can look shaky. Some 360 dash cams have built-in image stabilization which helps smooth out the video so you can clearly see what happened.
Check to see if the camera has buffered recording. This means the camera saves a few seconds of video before and after something happens which makes reviewing accidents much easier.
Some 360-degree dash cams stick on your windshield and some might sit on your dashboard. The way you mount it can change what the camera sees. Make sure you pick a style that fits your car and gives you the best view.
Many modern dash cams let you connect your phone directly to the camera over Wi-Fi. This means you can quickly look at your videos, change settings or send an important clip to someone without removing the camera or the memory card.
Why would you want a 360 dash cam? There are some great reasons why this kind of camera might be the right choice for you.
One of the biggest advantages is that you can see every angle around your car in one recording. This is especially helpful if an accident happens and you need to show exactly where another car or a person came from.
If someone scratches or bumps your parked car, a 360° dash cam can record it, no matter which side they approach from. Ordinary cameras often miss what happens on the sides of your car, but with 360° coverage, you get the whole story.
If there is ever confusion about a traffic incident, a 360-degree camera can help show more detail. You can prove what really happened from every direction which can help with insurance claims or even in court.
Some 360° cameras also record what’s inside your car. This is not only good for rideshare drivers, but also for families who want to keep an eye on pets, kids or even for making sure nothing goes missing from the car’s cabin.
70mai Omni |
1080p |
Rotating |
Yes |
Yes |
360° rotating lens |
Vantrue Nexus 5 |
1440p+ |
Dual fixed |
Yes |
Yes |
Dual 210° lenses |
Rexing 360 |
1440p |
Multi-lens |
Yes |
Yes |
Cabin + exterior view |
The 70mai Omni uses a rotating lens for full coverage. It is small and easy to use, with a phone app for quick setup and downloads.
Vanture Nexus 5 dashcam uses two fixed lenses to make a super-wide view. It delivers great detail and is a good choice if you want high quality.
Rexing 360 catches views outside and inside your car all at once. It is a bit bigger, but you get a lot of coverage.
If you drive a lot in city streets or crowded neighborhoods, a 360 car dash cam helps you see cars, bikes and people coming from any side. This can help you feel safer and drive with more confidence.
People who drive rideshare (like Uber, Lyft), taxis or work as part of a delivery fleet benefit from 360° dash cams. You can monitor passengers and protect yourself from false claims.
If you often park your car in places where theft or damage is a risk, you will appreciate the parking mode of a 360 camera.
With a 360-degree camera, you don’t need to stick on three or more cameras to get every angle.
Wolfbox is known for its strong 3-channel dash cams like the Wolfbox G900 TriPro. These cameras do not join all views into one seamless video like a true 360 cam, but they do record the front, rear and inside of your car all at once.
360° Dash Cam |
Full Surround View |
Yes |
Partial (front/rear/cabin) |
Clarity per View |
Medium |
High |
Night Vision |
Good (depends on model) |
Excellent |
Moving Parts |
Sometimes (rotating models) |
No moving parts |
A 360 dash cam lets you record everywhere around your car and is good for tricky parking lots, busy city driving and making sense of difficult situations. Still, it’s not the only answer. Wolfbox’s 3-channel dash cams are also a strong pick, especially if you want great image quality, good night vision and less worry about moving parts breaking over time.
Yes, some models come with Sony Starvis sensors or special night vision, so you get clear video in low light. Always check real-life video samples before you buy, to see how the camera performs when it’s dark.
Top options are the 70mai Omni and the Vantrue Nexus 5. Your choice depends on whether you like a moving lens or prefer fixed lenses for coverage.
3-channel dash cams can actually give you clearer video for each view because they don’t have to “stitch” everything together. But if you want a single seamless panoramic replay, the 360 cam is better for that.
No, Wolfbox does not make a true 360-degree dash cam yet, but our 3-channel cameras are great at catching all the important angles with sharp quality.
Many of them do, but you should always look at the brand and model. Make sure the camera offers motion or impact detection in parking mode for best results.
