G850 FAQs
Find your answer here
Basic Knowledge
The G850 provides three resolution options:
 4K(front) and 1080P(rear)
 2.5K(front) and 1080P(rear)
 1080P(front) and1080P(rear)
The reverse line of G850 can be adjusted by sliding the line on the screen according to the actual situation. It supports two reversing modes: Full-screen display and Panorama display, which can be switched by clicking the icon in the lower right corner of the reversing image. With the Full-screen display turned on, the reversing image will be automatically enlarged by 1.5 times. With Panorama display turned on, the reversing image will not be enlarged and show the actual distance.
Please note: Under Panorama display, the reverse line cannot be adjusted and saved.
1. The front camera behind the mirror can get more angles by moving it slightly, and the rear camera by changing the installation position.
2. Swipe the the screen up and down to get more viewing angle.
3. The rear camera image can be mirrored or flipped
The brightness of the screen can be adjusted by clicking the "brightness icon" on the screen.
 The current version of the G850 does not support the zoom function.
The WDR rear camera is waterproof, and you can get a clearer view in the rain by spraying water-repellent spray on the lens. It is recommended to protect the camera when washing the car, as high-pressure water vapor may seep into the inside of the camera.
The current version of the G850 is not equipped with LDWS and ADAS
The current version of G850 is not equipped with WIFI and APP
Usually the rear camera is installed above the license plate to get the best viewing angle and image, it can also be installed inside the car. License plate brackets are currently available on our website.
More about G850
Display Screen Size12"
Video Resolution4Kand 1080P
Aperture1.5F
Frame Rate4K30fps+1080p25fps
DDR2GB
FLASH128Mb
Weight/lb0.83
Touch ScreenSupport
Super Night VisionSupport
G-sensorSupport
Loop RecordingSupport
Reversing AidSupport
Parking Monitoring with hardwire kitSupport
Maximum Storage256G
