D07 FAQs
Find your answer here
Basic Knowledge
D07 provides four resolution options:
Front cam only: 3840*2160P
Front cam only: 2560*1440P
2160P(front) and 1080P(rear)
1440P(front) and 1080P(rear)
The D07 is not equipped with reverse lines or parking assist
1. The front camera is fixed and cannot be moved.
2. The rear camera image can be mirrored or flipped
The current version of D07 does not support zoom function and brightness adjustment.
The current version of the D07 is not equipped with LDWS and ADAS
The current version of D07 is equipped with WIFI and APP.
The APP can be downloaded by scanning the QR code in meanu or on the WOLFBOX official website, or searching for WOLFBOX in the app store
Please note: WIFI needs to be turned on manually before connection.
Usually the rear camera is installed on the rear windshield or above the license plate.
D07 needs power supply and video signal transmission through cables.
The D07 is not rechargeable and needs to be powered via a cable.
The mounting bracket of the D07 is detachable.
The parking monitoring mode of the D07 can provide protection for the vehicle after parking. Parking mode: With this option turned on in the menu, the dahcam will enter the parking monitoring mode after turning off the vehicle. Parking mode provides three options: G-sensor Trigger record/ Timelapse 12H/ Timelapse 24H
PLEASE NOTE: Correct installation of the hardwire kit is required for Parking Monitor Mode to work properly. The basic installation method is that the yellow wire of the hard wire kit is connected to B+ or a fuse with a constant power supply, the red wire is connected to the ACC fuse (12V-24V), and the black wire is grounded.
β Enable Timelapse 12H or Timelapse 24H in the Parking mode option, and "ACC off, then enter G-senor Trigger record" will be displayed on the screen after the car is turned off.
β‘Enable G-senor Trigger record in the Parking mode option. After turning off the car, "ACC off, then enter G-senor Trigger record" will be displayed on the screen.
Possible reasons:
1. The hard wire kit is connected incorrectly. Please contact support for wire connection issues or seek professional installation.
2. The car voltage is lower than 11.8V. The hardwire kit will automatically power off when the car voltage is lower than 11.8V to avoid draining the car battery.
3. The hardwire kit is defective.
4. The option of parking monitor is not turned in menu/ on App.
In order to avoid new videos not being saved and frequent formatting of the TF card when the TF card is full, the dashcam turns on the loop-recording mode by default. In this mode, the recording time of each video can be manually set to 1 min, 3 min or 5 min, and when the TF card is full, the new video will automatically overwrite the old video to achieve loop recording.
2. Insert a new TF card.
1. If the main unit does not turn on after updating the firmware, it may be that the unit has been installed with wrong firmware, please contact support to get the correct firmware.
2. Please confirm whether the power port on the top of the unit is damaged or not.
3. Please unplug the GPS, TF card and the rear camera cable, and use a new charger with a compatible interface to power the main unit to see if it can be turned on.
Please make sure that the layer of film on the lens is torn off and wipe the lens with a cleaner. Get an upgraded WDR rear camera to reduce glare
1. Please try inserting a new TF card.
2. If the new TF card does not make it work, please contact support or get the firmware from WOLFBOX official website.
It is possible that the card speed of the inserted TF card is lower than the requirement. Please use Class 10 and U3 TF cards. TF cards compatible with the product can be purchased on the WOLFBOX website.
1. Please make sure that WIFI is turned on in the menu.
2. After turning on WIFI, please check whether WOLFBOX_ D07 can be found on the WIFI list on the phone.
3. If the App displays "Connection Failed", please find Get Support option in the App and contact us.
Please try to reset the unit or update the firmware, then the password will become the defaultοΌ12345678
More about D07
Display Screen Size | 2.45β |
Video Resolution | 4K and 1080P |
Aperture | Β F1.55 |
Frame Rate | 4K24fps+1080p24fps |
DDR | 4GB |
FLASH | 128Mb |
Weight/lb | 0.22 |
Touch Screen | not Support |
Wi-Fi Connection | Support |
Super Night Vision | Support |
G-sensor | Support |
Loop Recording | Support |
Maximum Storage | 256G |
